Toyota Tundra dirty little towing secret
Discussion in 'Towing & Hauling' started by Markbvbb, Jun 22, 2019.
  1. Jun 22, 2019 at 10:50 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t have this issue on my 15. What year are all your older trucks?
  2. Jun 22, 2019 at 11:06 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
  3. Jun 22, 2019 at 11:10 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    GLWTS then?
    Rica25, Ostrich, 4x4_Angel and 5 others like this.
  4. Jun 22, 2019 at 11:11 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Hey Mark, sell the Tundra and buy the Ram. Done deal. Then move over to the Ram forum and complain about that truck over there.
    I have a class A CDL license and I prefer to not use cruise while towing for many reasons. But, I have used it with my Tundra while on open highway and flat ground and had zero issues.
    Rica25, Ostrich, 4x4_Angel and 6 others like this.
  5. Jun 22, 2019 at 11:11 AM
    15whtrd
    15whtrd Mr. Blonde
  6. Jun 22, 2019 at 11:14 AM
    SnrDisregardo
    Wade
    IL
    I’m not normally like this, but A LOT has changed thru the years. Can you use cruise while towing? Sure. Is it a good idea to leave a part of you control, I.e. you controlling the throttle, to a computer while you are towing thousands of extra pounds? Probably not. Look, I do think you can tow and use cruise, and I’m sure everyone does it, but it’s not a fatal blow to the tundra as you have made it seem. Congratulations on the new truck. I hope you hold on to it as they are really great trucks, aside for some text in a book and legal coverage of ass by the manufacturer.
  7. Jun 22, 2019 at 11:16 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Perhaps, but I like to remain hands on and in control.
    Now if the AC didn't work while towing - I would bitch about it.
  8. Jun 22, 2019 at 11:26 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Welp just got back from taking my boat to storage. Pulling it with my 2018 Platinum WITH TSS and Dynamic Cruise Control I had zero issues turning on the cruise control. Zero. None. Worked just fine.
    Challenger1, Rica25, Ostrich and 6 others like this.
  9. Jun 22, 2019 at 11:34 AM
    15whtrd
    15whtrd Mr. Blonde
    Well I stand corrected, they didn’t implement this as a safety feature. Sounds like something is wrong with his truck. That won’t happen with the Dodge though!
    Rica25, 4x4_Angel, Quicktan66 and 4 others like this.
  10. Jun 22, 2019 at 2:33 PM
    Interesting thread to say the least.
    I was never able to use CC with my Tundra while towing (unless if was flat or downhill), and I have been with a few friends with different makes of 1/2 ton trucks that can’t use CC while towing either. Just because it doesn’t say it in the manual, doesn’t mean it will actually work. At least Toyota gives you the heads up. The only modern 1/2 ton I have been in that can use CC with pretty heavy weight is the Ford EB. The torque hits down low like a diesel and holds gears.
    This is all on geographic location as well. Towing the same TT in Nebraska vs Colorado will vary greatly in towing performance and the ability to use CC.
    I use CC all the time. I also used CC towing up to 105k lbs in a commercial setting. Nothing wrong with using CC while towing when appropriate.
  11. Jun 22, 2019 at 2:41 PM
    15whtrd
    15whtrd Mr. Blonde
    I think the main thing there is “when appropriate”. That’s using experience and good judgment.
    I was able to use it on my truck but I was only hooked up to a four pin towing an old ski boat. I only tried it out on the flats just because it was steady. I wonder if plugging into the seven pin overrides the CC?
  12. Jun 22, 2019 at 2:51 PM
    No, it doesn’t disable it, not to my knowledge.
  13. Jun 22, 2019 at 5:31 PM
    Ericsopa
    Ericsopa Old man and the sea
    BS! If you're so physically taxed by driving without the cruise, you should pull over for the day.
  14. Jun 22, 2019 at 5:33 PM
    Ericsopa
    Can you "unlike" a post, even when you didn't initially "like" it? :rofl:
    2manytoys, Rica25, 4x4_Angel and 3 others like this.
  15. Jun 22, 2019 at 5:37 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I had never used the cruise control while towing until the other day in my 2nd gen. I hated it! Damn truck acted like money grew on trees. I swear it though it was a drag race every time there was the slightest incline... Lol not sure why anyone would want to use cruise when you tow
    15whtrd, Mr Swervlin and Ericsopa like this.
  16. Jun 22, 2019 at 5:54 PM
    ...on a gas V8, I would agree.
    15whtrd and Black Wolf like this.
  17. Jun 22, 2019 at 5:55 PM
    TruckyTruck
    Gary
    Yeah, I guess I should say in a second gen tundra. It's the only thing I have experience towing in
  18. Jun 22, 2019 at 5:59 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    You guys are apparently not telling the OP what he wants to hear.
  19. Jun 22, 2019 at 6:04 PM
    Rex Kramer
    Georgia
    I rarely use CC, almost never in the '02 and the cruise in my '07 remains non-functional. I turn the OD off in my '02 when towing, then on and off as needed. I imagine towing in the '07 would entail putting in 4th gear and shifting in and out of the two available over drives as needed.
  20. Jun 22, 2019 at 6:05 PM
    #50
    That RAMs suck????
    Ostrich, 4x4_Angel, cnoyes72 and 5 others like this.
  21. Jun 22, 2019 at 6:52 PM
    #51
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Hey there, @Migraine . Somebody is feeling better about life. Good to hear a little sarcasm from you, Margaret! :D
    4x4_Angel, 15whtrd and Migraine like this.
  22. Jun 22, 2019 at 6:55 PM
    #52
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I rarely ever use CC towing, I rather gauge distance and anticipate with gas pedal control.
  23. Jun 22, 2019 at 8:07 PM
    #53
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I drove this...
    from Pissburgh to Bristol, Virginia twice with the adaptive cruise control armed and the Xmission in Hoe/Tall mode.
    It fought long hills and stayed in lower gears maintaining 70mph and backed off the throttle itself when I started creeping up on the vehicle in front of me.
    Fun fact: OEM brake controller gain was set at 7.5.
  24. Jun 22, 2019 at 9:29 PM
    #54
    devdomski
    devdomski New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
    The contrast in grammar usage is amazing in this one
    Mickeydog, 4x4_Angel, Sunnier and 7 others like this.
  25. Jun 22, 2019 at 9:31 PM
    #55
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I was trying not to point that out.:eek2:
  26. Jun 22, 2019 at 9:38 PM
    #56
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Pretty sure you can tow just fine with CC. My 17 will let me do it but, can you stop in time if you really had to. That is the real concern for Toyota. Reaction time is probably lacking for most people when driving in CC.
    Boerseun likes this.
  27. Jun 22, 2019 at 9:40 PM
    #57
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    I call shenanigans
  28. Jun 22, 2019 at 10:42 PM
    #58
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I never tow in auto shift or cruise control haha. I’m always in S mode keeping smooth rpm in a torque heavy zone.
  29. Jun 22, 2019 at 10:42 PM
    #59
    Tracy Perry
    Tracy Perry New Member
    Tracy
    East Texas
    2019 MGM TRD Off-Road 4x4
    That's normally a pretty good indicator that you need to pull off the road and stretch your legs.
    15whtrd likes this.
  30. Jun 22, 2019 at 11:22 PM
    #60
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    O.K.
    15whtrd likes this.
