Well dang, this can't be good.
Discussion in '1st Gen Tundras (2000-2006)' started by SoCalPaul, Jun 21, 2019.
  1. Jun 21, 2019 at 6:48 PM
    SoCalPaul
    SoCalPaul [OP] New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Looks like anti-freeze. I'm guessing water pump time.
  2. Jun 21, 2019 at 6:52 PM
    Aerindel
    Aerindel New Member
    Montana
    Maybe. Have to trace it down, several other places where it could be leaking from to end in that spot.
    JohnLakeman likes this.
  3. Jun 21, 2019 at 7:25 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Failing water pumps usually leave an excessive pink scaly trail underneath the pumps weep hole. Minor periodic leakage at weep hole is considered normal according to Toyota due to (solid) particles getting trapped between seal surfaces and purged by minor leakage as a normal process.
  4. Jun 21, 2019 at 7:32 PM
    Time to get that skidplate off.
    NewImprovedRon and P-Factor like this.
  5. Jun 21, 2019 at 7:57 PM
    SoCalPaul
    Paul
    Yep, tomorrow.
  6. Jun 21, 2019 at 8:28 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Check your coolant overflow. Could be radiate failure causing pink milkshake.
  7. Jun 21, 2019 at 8:43 PM
    SoCalPaul
    Paul
    No, both radiator & overflow look good. I’m pretty sure it’ll be the water pump. I’ll know tomorrow.
    lsaami[QUOTED] likes this.
  8. Jun 21, 2019 at 9:27 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Sorry to see that Paul. Fingers crossed it's a hose versus a water pump
    JohnLakeman and Pinay like this.
  9. Jun 22, 2019 at 5:33 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Rut row! Bummer man.
  10. Jul 5, 2019 at 12:00 AM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Figure this out? How much coolant validates changing the pump? I have some crust in there, but no puddles and the coolant level when the truck is warm is only about 2 " below the full line.
  11. Jul 5, 2019 at 1:43 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Obvious leakage on the driveway or garage floor is a clue that you need to address the issue quickly. Prior to that, you probably will not even be aware of the pink crust. If Toyota says it's normal to have a pink crust under the weep hole, then that's saying you don't need to change the water pump...yet. But, I would start watching for puddles, and monitoring coolant level closely if I knew the crust was there.
    Slight water pump leakage is an annoying inconvenience, but not a serious engine problem. The real problem is significant coolant loss without the owner's knowledge. How long that coolant loss takes depends on severity of the water pump leak. Once the water pump begins to leak, it can advance to significant coolant loss quickly. If the pump is not replaced, coolant loss can result in overheating and severe engine damage (recent thread here), so it's better to change a leaking water pump as soon as you know it's real, i.e. coolant on the ground that's clearly leaking from the water pump.
  12. Jul 5, 2019 at 1:59 AM
    P-Factor
    P-Factor New Member
  13. Jul 5, 2019 at 7:51 AM
    Sangre Kid and BestGen like this.
  14. Jul 5, 2019 at 7:54 AM
    minter66
    minter66 2007 TSS CrewMax
    Mine wasn't even leaking that much and I changed it.
    Yes, it sucks, but its worth it.
    I'd have to search for it, but a member on this very site had the same issue (leaking less I believe) and he decided to risk it for the biscuit and take it on a road trip... destroyed his engine on the way back when the WP let go.
    For a 2nd gen, the Aisin is $78 and roughly 5 hours of knuckle bleeding time. Cant be that much more for a 3rd gen. Shoot, maybe they untied the knots of hoses and its easier for you.
  15. Jul 5, 2019 at 8:02 AM
    All well and good, but this is a 1st gen(best gen) page! :cool:
  16. Jul 5, 2019 at 8:09 AM
    minter66
    I apparently got lost.
    Savvy.
    Sangre Kid and bmf4069 like this.
  17. Jul 5, 2019 at 8:14 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Good luck. Hopefully nothing major and easily addressed
  18. Jul 5, 2019 at 8:25 AM
    Dilsky
    Shawn
    Edmonton, Alberta
    Yea I debating it is 100 bucks. I watched a video of one guy struggling in the tight space, but would it be easier to just pull the rad and wouldn't you just have a straight view of the pump?
    Sangre Kid likes this.
