Optimum. Tire and wheel coating done today
Discussion in 'Detailing' started by Pudge, Apr 19, 2019.
  1. Jun 17, 2019 at 8:14 AM
    #61
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I will add that they look great again too.
  2. Jun 17, 2019 at 8:33 AM
    #62
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Did you ask optimum how to remove it. I'm curious what they say.
  3. Jun 17, 2019 at 8:40 AM
    #63
    War Machine
    War Machine SSEM # 5 3MW
    I sent an email this morning with pictures, asking if they could tell what caused it. @Pudge did get a response on removal in a previous post.
    Pudge[OP] likes this.
  4. Jun 17, 2019 at 9:14 AM
    #64
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I say this once a day for some reason or another.
    My optimum tire coating will be here later today. Lol.
    War Machine likes this.
  5. Jun 17, 2019 at 10:31 AM
    #65
    Pudge
    CT
    Make sure you clean the shit out of those tires. If you have shine supply wise guy, that's your best bet, clean them 3 or 4 times over. Whatever you may have for a cleaner make sure you really get them as perfect as possible. Maybe even rub down with a magic eraser. The coating is absolutely amazing in terms of looks and longevity but its picky when it comes to sticking evenly and will flake off in places. I will still continue to use it but I will bemore careful about cleaning
  6. Jun 17, 2019 at 10:33 AM
    #66
    Pudge
    CT
    I haven't given up. I will be more diligent now. I actually got a second email back after I replied with my disappointment in the flaking and inability to remove. The guy was kinda testy
    Sean, TPC is a Coating, not a tire dressing, and has 6 - 12 months durability. For that longevity it needs to be robust and not easily removed by chemicals. If you liked the results and recommended it to friends, why do you want to remove it? Like all serious products, TPC has a learning curve and correct application is essential for great results. I indicated it's difficult to remove, not impossible, and TAR is the best way to accomplish that. I'm attaching a video that shows proper application::
    https://www.youtube.com/watch?v=Ea8BPQyhdyU
    hope this helps...
    Ron
    Omohundro and War Machine like this.
  7. Jun 17, 2019 at 12:00 PM
    #67
    Omohundro
    Jody
    McMinnville TN
    I just watched the video, so is this to thick? It’s very blue, in the video he said that was to much. Could this be a problem(flaking). I’m just asking, I know nothing about the product yet. 13FCDC96-E2EB-45E2-B19F-ED59D6DC8633.jpg
  8. Jun 17, 2019 at 1:58 PM
    #68
    Pudge
    CT
    I think its possible I put it on too heavy but I actually didn't have any flaking issues. I just had a few spots where my sidewalls rubbed sonething and scuffed the sealant off. And one area where I didnt get all the brown tire bloom off so it showed thru. I tried touching up those spots but it didn't look great and was uneven so i figured I should just start fresh and be more careful. I just wanted them perfect, obviously I'm a little OCD lol. But the fact is you really cant strip it off without spending a lot of new products and hours of scrubbing. I ended up doing the best I could to remove as much as I could and i put on 2 fresh coats. It looks great again so I'm happy. I was just pissy yesterday and Saturday from frustration. It's a great product but you have to be sure to follow the steps perfectly
  9. Jun 17, 2019 at 2:10 PM
    #69
    Danimal86
    Daniel
    Sacramento, CA
    Thanks. I thought I was up to date on this thread, but it looks like I missed a bunch. Sounds like there isn't an easy way to get this stuff off.
  10. Jun 17, 2019 at 7:26 PM
    #70
    Omohundro
    Jody
    McMinnville TN
    This may be a silly question, have you tried a pressure washer to get it off?
    Pudge[QUOTED][OP] likes this.
  11. Jun 17, 2019 at 8:20 PM
    #71
    Pudge
    CT
    That is not silly at all. And no I have not. I thought about it when I was planning on how to attack it, then forgot while I was doing it. And just remembered again now hahaha.
    It's a slim chance it would work but very much worth a try. Beats scrubbing for hours
  12. Jun 17, 2019 at 8:24 PM
    #72
    Pudge
    CT
    No easy way. So the key is to be sure to do your prep work the right way, then do it again. And known that even if you do prep the right way, it still may flake. We all know that of all people @driverdog Jim did the proper prep work and he still had issues.
    All that said, its still worth the risk and effort. When done right, its amazing. I mean easy to clean, glossy, tires for 3,4,5+ months with nothing to do to them other than regular cleanings. No more need for tire dressing. It has amazing potential and I'll keep using it
  13. Jun 18, 2019 at 8:24 AM
    #73
    Pudge
    CT
    That isnt the area that scuffed, but it's an area that I clearly didn't get clean enough when I used this tire coating the very first time. I didn't have a good tire cleaner then. And I wasnt able to strip the coating off in that area to re clean it.
    The second pic is a different tire that I believe I got the cleanest and the coating has always looked the best on
    driverdog likes this.
  14. Jun 19, 2019 at 5:10 AM
    #74
    War Machine
    I’ve gotten no response to my inquiry to Optimum. If I get time over the next few days, I’ll attempt to clean up the spots with the brush attachments on my drill. They work pretty great for hard water spots on my shower doors and countertops.
    4in 4 Piece Soft, Medium and Stiff Power Scrubbing Brush Drill Attachment for Cleaning Showers, Tubs, Bathrooms, Tile, Grout, Carpet, Tires, Boats by DrillStuff https://www.amazon.com/dp/B0727NJZNV/ref=cm_sw_r_cp_tai_LyIcDbK2T4M77
  15. Jun 19, 2019 at 6:22 AM
    #75
    Omohundro
    Jody
    McMinnville TN
  16. Jun 19, 2019 at 6:57 AM
    #76
    Pudge
    CT
    It will clog up the spray nozzle for sure when it dries. the top that it has on it now for dispensing gets clogged. Make sure whatever you use to apply it with, that you wash right away or you'll end up having to throw it out. Because it's a coating, it dries very hard.
    Omohundro[QUOTED] likes this.
  17. Jun 19, 2019 at 7:11 AM
    #77
    Omohundro
    Jody
    McMinnville TN
    Got it.
  18. Jun 20, 2019 at 9:11 PM
    #78
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    You think one of those Magic Erasers with a brush to clean off the magic eraser bits? They seem to work wonders w/o much damage.
    driverdog and Pudge[OP] like this.
  19. Jun 20, 2019 at 9:31 PM
    #79
    Pudge
    CT
    I was thinking it may work. I thought of it after a 2 hour battle trying everthing else I could think of. I ended up just recoating the tires, but maybe I'll try the magic eraser on a spot tomorrow
    NUDRAT[QUOTED] likes this.
  20. Jun 21, 2019 at 11:15 AM
    #80
    War Machine
    So, it looks like the bad spots on mine wore off on their own.
    NUDRAT likes this.
  21. Jun 21, 2019 at 11:56 AM
    #81
    Omohundro
    Jody
    McMinnville TN
    What about mineral spirits or paint thinner to cut the tire coating off.
  22. Jun 21, 2019 at 11:58 AM
    #82
    Pudge
    CT
    That's good. I had a few spots like that. I just went over the whole tire really well to clean it and re coated it. Surprisingly it came out pretty even
  23. Jul 9, 2019 at 5:45 AM
    #83
    Omohundro
    Jody
    McMinnville TN
    So does this mean you’re done with the Optimum coating? Lol, I have a big bottle that I haven’t even opened yet.
  24. Jul 9, 2019 at 6:37 PM
    #84
    Pudge
    CT
    I'm on my second attempt and so far so good. It's been about 3 weeks. I used shine supply wise guy tire cleaner this time and took extra care and time. No flaking and it's nice and even.
  25. Jul 10, 2019 at 4:16 AM
    #85
    War Machine
    I’ve done several vehicles with it, and only had an issue on one tire. I didn’t get that one clean enough. The bad spot wore off on its own, and I was able to re-do it.
    Pudge[OP] and Omohundro like this.
  26. Jul 11, 2019 at 4:08 AM
    #86
    War Machine
    Sure thing. I’ll try and get some when my wife gets home. Hers was done a month or so ago. My two daughters cars were done last weekend. I’m not sure how long it’s been since I applied them on mine.
  27. Jul 12, 2019 at 4:21 AM
    #87
    War Machine
    Jim, I forgot to take pics yesterday. I’ll try to remember this weekend.
    I did put some on my original thread. I believe there are updates at 1 week, 2 weeks, and a month.
    https://www.tundras.com/threads/optimum-tire-protection-coating.37880/
  28. Jul 13, 2019 at 4:43 PM
    #88
    War Machine
    Took some pics just now. We’re having some rain in the area, so I didn’t clean any of them. Maybe showing them before being washed is a good idea anyway.
    Daughter’s car, done a week ago:
    Wife’s Sequoia, done just over a month ago:
    Mine currently. I’ve lost track of when I did it last.
  29. Jul 13, 2019 at 6:35 PM
    #89
    War Machine
    No problem. For better reference, same tire on my wife’s Sequoia.
    June 10th. (Top left was bottom of the tire when applied. Fixed after the photo):
    Today:
    This was one coat only.
    NUDRAT and driverdog like this.
  30. Jul 13, 2019 at 6:56 PM
    #90
    War Machine
    Yes, definitely. One thing that does cause a little trouble though. If you look at my wife’s tire, you see the tiny ridges running around it. ( Bridgestone logo is in this area.) Those type of tires seem more difficult. You have to move the applicator in all directions to make sure you fill those ridges up.
