Fitting 03 tundra wheels on my new 2012
Discussion in 'Wheels & Tires' started by Yotalover716, Nov 3, 2016.
  1. Nov 3, 2016 at 3:05 PM
    Yotalover716
    Yotalover716 [OP] New Member
    Justin
    2012 rock warrior dubbed cab
    Joined up for info :) looking to install my after market 22 inch wheels on my 2012 tundra I used to have an 2003 tundra and they changed from 6 lug to 5 is there an adapter I can buy to make them fit?
  2. Nov 3, 2016 at 3:44 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Welcome to the forum! I personally wouldn't recommend it due to offset properties and the chance that the adapter just adds more stress on your ball joints and control arms. I'm sure there is someone out there who provides them. I just wouldn't take the chance leaving so much space myself.
    Those 6 lugs are the exact diameter as the tacomas. Have you entertained the idea of selling them and putting that towards a new set?
    Law323 likes this.
  3. Nov 4, 2016 at 7:48 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i have ran plenty of adapters and spacers on a few different vehicles. my zo6 650 hp vette runs a set. if they are torqued properly and you can deal with the additional offset they are fine. plenty of folks discourage them due to additional stress on front end parts but if torqued properly and inspected they would put no more stress then a similar offset aftermarket wheel.
    that said there are a ton of adapter companies, just pick a reputable one.
  4. Nov 4, 2016 at 7:40 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Anyone know why toyota went from 6 lug to 5?? makes no since. 6 is better than 5 on a heavier truck. I think they don't want us to be able to use tacoma and older tundra wheels.
  5. Nov 4, 2016 at 9:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's a post on this somewhere. In a nutshell, each of the five wheel studs is thicker than the six studs of the first gens. Together, it was said, the thicker five studs were 35% stronger than the thinner six studs.
