Started buying audio upgrades
Discussion in 'Audio & Video' started by Tigwelder, Jun 12, 2019.
  1. Jun 12, 2019 at 4:26 PM
    Tigwelder
    Tigwelder [OP] New Member
    Stopping by local audio shop today . Bought infinity kappa 6x9 front door speakers , mounting brackets , wiring adapters . And picked up sound deadening pack for front doors.
    Next week I'll buy kappa's for rear doors . And more sound deadening for rear.
    I'm thinking about ********* plug and play amp and wiring .and doing subs myself .
    But could get local shop to install skar audio amp and kicker 10" subs . Any input on amp and sub install would be greatly appreciated .
    ManoTundra likes this.
  2. Jun 12, 2019 at 4:52 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Nice!
  3. Jun 14, 2019 at 3:24 AM
    Tigwelder
    Stopped again yesterday and bought 6.5" kappa's for rear doors. And 8 sheets of 12"x36" dynamat sound deadener .
    I think I'm going with 10" kicker comp vt subs in a Qbomb box .
    TRD-tv and ManoTundra like this.
  4. Jun 16, 2019 at 4:08 PM
    Tigwelder
    Well that sucked. IvI' got cuts all over my hands . My knuckles or skinned . But I got two layers of sound deadener on all doors .
    I put a layer on inside of door skin and layer on door just under panels . And instead new infinity kappa speakers front and back.
    Next week I'm having Q box with 10" kicker subs installed. And a skar 5 channel amp .
    Pudge and jdh564 like this.
  5. Jun 16, 2019 at 4:12 PM
    jdh564
    jdh564 New Member
    Jeff
    Atlanta, GA
    2017 Crewmax Super White 4x4
    Looking good! Let me know how that sub and amp sound as I'm trying to figure out my sub and amp choice.
  6. Jun 16, 2019 at 4:13 PM
    tAcomaPueblo
    tAcomaPueblo New Member
    Tampa Bay
    2014 SR5 TRD OR CM 4x4
    Do the speakers need special brackets at all to replace the OEM? I know my Tacoma did and was thinking about upgrading my Tundras as well. Cant wait to see what you think about your set up!
  7. Jun 16, 2019 at 4:16 PM
    Tigwelder
    They did take adapters. I bought them at local audio shop. I think fronts were $20 for 6x9 and rears were $18 for 6.5"
    tAcomaPueblo likes this.
  8. Jun 16, 2019 at 5:07 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, speakers I bought from Crutchfied came with speaker and wire adapters.
  9. Jun 16, 2019 at 5:24 PM
    Tigwelder
    I've looked at JL audio 10" shallow mount subs . And kicker compvt . I decided the kickers would do what I needed.
    I mean im 49 years old . I don't think an extra $400 worth of subs is going to make much difference on my old ears that have stood beside a loud welding machine for last 30 years . I can't rear very good anymore . But would like extra I think the new kappa's provide.
    I think the skar amp I'm looking at is 75 watts per door and 400 on subs .
    Can't tell much difference on kappa's now with out amp to them yet.
    The double insulation on doors has made a huge difference on road noise though.
    I would like to do roof and floors next .
    It took 3 1/2 sheets of 18"x36" sound mat per door . About an hour per door .
    I cut mats into strips and made buckets behind speakers to direct all the sound towards truck cab and not inside doors . That was time consuming.
    Mgmtundra and Pudge like this.
  10. Jun 16, 2019 at 7:13 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Good idea staying away from the ********* amps. I just don't trust those guys.
    Are you swapping head unit? What are you planning to use for OEM feature integration? I have an idatalink maestro RR and kenwood head unit which is great. If you keep your head unit you won't need one but may want something to make amp easier to wire up, like a dsr1 if you have the JBL stuff.
    I'm not sure what the non JBL people use, maybe just high level inputs or a line out converter?
    Any chance you'll want a 9 conductor wire to run speaker wire from amp back up to head unit? Makes it much easier than running a ton of speaker wires, it also has a 9th wire to use for a remote amp turn on. I have one I'm trying to sell.
    TRD-tv likes this.
  11. Jun 17, 2019 at 2:14 AM
    Tigwelder
    I bought a truck with entune upgrade hu.
    Got navigation .
    IvI' had trucks with Bose and didn't like having to but extra to bypass everything
    I'll need a loc . To run speakers
    But will be getting audio shop install amp and subs.
