Icon rxt and shackles
Discussion in '2.5 Gen Tundras (2014-2021)' started by DexterL, Jun 16, 2019.
  1. Jun 16, 2019 at 6:29 AM
    DexterL
    DexterL [OP] New Member
    21 lunar rock TRD pro Seqouia
    Adding cdcv front and rear icons to my new truck and debating adding the rxt system. I have a a leer toppe, Rolf rack, fly rod holder and a decked truck bed system loaded. I am usually
    Hauling a drift boat or medium weight jet boat. Wanting to maintain some rake for sake of the TSS sensor and wondering what length coachbuilder shackles I’ll need? Thanks!
  2. Jun 16, 2019 at 6:47 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    How high are you lifting the front? If 3” with your topper your gonna want 2” to 2.5” in the rear :....coach builders +3 only gives about 1.75” so your gonna need another leaf to add to that or get a longer shackle. I’m using pro form fab 2” shackles super heavy duty $60 on eBay.
  3. Jun 16, 2019 at 6:49 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Over stock or combined with RxT? Because as I understand it the RXT adds lift by itself...and I think that is what compounds the question.
  4. Jun 16, 2019 at 6:53 AM
    xtyfighterx
    Ty
    North Idaho
    Didn’t see he has the rxt my bad!
    I was saying stock. So what’s the rxt add 1.75”?
    TacoWuzzaTurd likes this.
  5. Jun 16, 2019 at 7:58 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    joonbug likes this.
  6. Jun 16, 2019 at 11:46 AM
    DexterL
    Thank you
    831Tun[QUOTED] likes this.
  7. Jun 16, 2019 at 12:07 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The RXT’s height is determined by which option you choose. Which is determined by how much weight you run. Sounds like you need option 2 or 3. Those will give you a 3-4” lift with stock shackles. Adding CB shackles will likely give it way too much lift.
    zcarpenter92 and 831Tun like this.
  8. Jun 16, 2019 at 12:48 PM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    I am very happy with my RXT leafs. Well worth the money. If you use the truck off road a lot I’d add the Icon hydraulic bump stops, those cleaned up rear feel over the rough stuff a lot too.
    Erichudgins likes this.
