Throttle problem help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Thattundradude, Jun 15, 2019.
  1. Jun 15, 2019 at 12:05 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hello everyone. I am literally stuck on my tundra I don't know what to do. I wired a front camera a few months ago and since then I've been stuck. I used a drill bit to make a hole so I can take the wire from the engine to the cabin. (The same where the engine harness comes in from) after that I disconnected the accelerator pedal plug to wrap the wire around it, plugged it back in, wired the camera to the headunit started the truck, pressed the pedal when I was backing up and it didn't engage until I was past half way, the check engine light came on. Things I've done
    Brand new Accelerator pedal (nothing)
    Checked all fuses (nothing)
    Showed it to someone and they're telling me I need a new ecm
    I've attached the codes from TechStream
  2. Jun 15, 2019 at 12:12 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Why would you touch the accelerator wires? I don't recall seeing anything about that when I installed my frac unit.
  3. Jun 15, 2019 at 12:28 PM
    Thattundradude
    Platinum Tundra
    Lifted
    Idk what I was thinking at that moment
