Toyota will add automatic engine shut off and auto-park to all new vehicles
Discussion in 'General Tundra Discussion' started by G10dra, Jun 13, 2019.
  1. Jun 13, 2019 at 10:22 PM
    G10dra
    G10dra [OP] Not a New Member
  2. Jun 13, 2019 at 11:46 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Mans attempts to "legislate away" STUPID will go on longer than the sun will burn.
    Dear Gawd (if true).
  3. Jun 14, 2019 at 12:48 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    But it’s still a 3rd Gen. it’s the same truck with added features they have done this the past few years. Maybe 2021 will bring a new generation time will tell
  4. Jun 14, 2019 at 4:02 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I heard they are going to do away with trucks completely because they are evil gas guzzlers. Toyota Tundra will now be called the Wundra modeled after Fred Flintstones Bedrock Daily Driver. Wundra because you’ll wonder why your feet are pushing Tundra.
    Wilma!!!
  5. Jun 14, 2019 at 5:56 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    If the engine is running and you have a 12V accessory plugged into the cigarette lighter outlet, like an inverter running a tire inflater, does this mean the engine will shut off when you are trying to inflate something?
    I like to have my engine running when I use my accessory outlets, because I don't want to run down the battery.
    BravoDeltaRomeo likes this.
  6. Jun 14, 2019 at 6:18 AM
    GravityGear
    Aurora, CO
    No the engine switch is still ON, so those accessories won't stop working. They are triggered through the ignition switch.
    myt1[QUOTED] likes this.
  7. Jun 14, 2019 at 6:21 AM
    jtav2002
    jtav2002 Retired Adult Film Sound Man
    Josh
    Reading, PA
    2019 GMC Sierra 1500 AT4 6.2
    The engine won’t shut off in park. It’s just in drive when you stop and push the brakes pedal all the way down. That’s how it works in my wife’s 19 Highlander. I don’t like it so I just turn it off when I’m driving her car.
  8. Jun 14, 2019 at 6:23 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    This goes along with the new gas cans.
    I have spilled more gas with the new spouts than I ever spilled with the unsafe ones.
    I wish they would stop protecting us and let us have a damn truck.
    I have enough safety features now. I am good
    Glad I bought the 2019.
  9. Jun 14, 2019 at 6:28 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    My takeaway from the article is that this isn't automatic shut-off at red lights like on Fords. I'm curious what the "predetermined amount of time" will be and if the driver can adjust it.
    ZappBrannigan likes this.
  10. Jun 14, 2019 at 6:31 AM
    Not really. It's still a 2nd gen in all honesty.
  11. Jun 14, 2019 at 6:39 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I love my 2013. I leave The Truck running when I'm stopped on he trail due to all my accessories, lights, air compressor, dual battery etc. If it shut off on me I would be pissed
  12. Jun 14, 2019 at 6:40 AM
    Technically there is no 3rd gen. Yet.
    Doxiedad and G10dra[QUOTED][OP] like this.
  13. Jun 14, 2019 at 6:48 AM
    MrMax
    MrMax Introvertigo Eximious Geargasm
    Rob
    Eastern Iowa, USA
    2011 Crewmax S/C TRD Rock Warrior
    I hate that auto shut off feature on my GM work car. Sometimes when it shuts off and I'm sitting there my foot eases off the brake just a little and it will start back up and lurch slightly forward. Better engineer those starter motors as an easy replacement item now that they are doing 4x(+) the duty...
  14. Jun 14, 2019 at 7:01 AM
    GravityGear
    Aurora, CO
    The new auto start-stop starters are engineered for the extra duty. New bearings, new motors, new everything. Toyota actually has a "permanently engaged" starter that leaves the gear on the flex plate. Mazda is using a system that fires an injector and ignites the mix to restart engines. Dry lubricants are being used on main bearings and other high startup wear locations. You'll get used to it. Just like we did when EFI became the standard.
  15. Jun 14, 2019 at 7:04 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
  16. Jun 14, 2019 at 7:06 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    My Merc has a hall sensor on the crank shaft and pre loads the next firing cylinder with fuel. Its pretty seamless. At first I hated it but now I don't even notice it. In fact, I like the silence when I'm sitting at a top light. I mean, its already a quiet car, but when its off its totally silent
  17. Jun 14, 2019 at 7:11 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Auto shut off sucks. It is annoying to drive with.
    As population, we crave bigger and bigger vehicles then complain that they dont get better mileage.
    We have doubled, tripled the power we get out of similar sized engines with technology. Yet the vehicles are getting almost the same mpg as 20 years ago of same size.
    specter208 likes this.
  18. Jun 14, 2019 at 7:13 AM
    GravityGear
    Aurora, CO
    Interesting that MBZ is preloading the fuel. Wonder how they avoid pooling.
  19. Jun 14, 2019 at 7:17 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Maybe they dont' actually shoot it into the cylinder. Its DI, so maybe it just knows exactly which cylinder to squirt
  20. Jun 14, 2019 at 8:29 AM
    G10dra
    I agree there isn't but I am just going based on what's already posted and used on this forum.
  21. Jun 14, 2019 at 8:58 AM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Figures that it will eventually make its way to all the vehicles. At least, they're kind enough to put in a deactivate switch in most vehicles that i've driven. Funny thing is that this feature has been in European cars for quite awhile and is nothing new to them but here in the US, its being sold as new gas saving tech.
    Watt maker likes this.
  22. Jun 14, 2019 at 9:17 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I really like it on the merc. I dont ever put it in park or touch the e brake haha I just turn it off and open the door and it automatically puts it in park and engages the brake. Its super convenient.
    Only problem is I get in my tundra and try that sht and it starts rolling on me :rofl::rofl::rofl:
  23. Jun 14, 2019 at 9:27 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    I wonder what the "predetermined" time is, this stuff would drive me nuts. Using mine as a work truck I let it idle a lot if I Jump out to do something to keep the truck cool or hot and keep the dog in the a/c in the summer. Sadly it seems everything is going this way, better hang onto the older stuff now!
  24. Jun 14, 2019 at 9:36 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    That is the key to most of these new 'safety' innovations. As long as the driver has the ability to turn things on/off, and adjust the timing of things we will be fine. The down side is that you pay for this stuff whether or not you want it.
  25. Jun 14, 2019 at 10:32 AM
    Scruffydog
    Scruffydog New Member
    dont worry. 2021 Tundra will have Turbo V6 with hybrid option. Big inrease in HP Torque and MPG cant wait
  26. Jun 14, 2019 at 10:49 AM
    MrMax
    Rob
    Eastern Iowa, USA
    I imagine I will eventually. I would get used to walking again if my big toe was cut off as well...Still wouldn't mean I would like it :)
  27. Jan 8, 2020 at 7:09 PM
    specter208
    specter208 New Member
    2017 Tacoma and 2005 Tundra RGCAB
    2020 does not have auto start-stop
    rebmo and deptrai[QUOTED] like this.
  28. Jan 8, 2020 at 7:13 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    Nope just bought a 2020. No stop start
    specter208 and deptrai[QUOTED] like this.
  29. Jan 8, 2020 at 7:15 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I’d love to see hard facts about how much fuel is saved by the start stop features on cars. It has to be nearly nothing
  30. Jan 8, 2020 at 7:19 PM
    Doxiedad
    James
    Charleston, SC
    I don’t think it’s nothing. If you spend a bit of time stopped in traffic it makes a difference. When stopped you are getting 0 MPG. Whether the increase is worth it to you as a consumer is a personal decision.
