Please help wheel destroying truck
Discussion in '2nd Gen Tundras (2007-2013)' started by McFlappin, Jun 11, 2019.
  1. Jun 11, 2019 at 8:40 PM
    McFlappin
    McFlappin [OP] New Member
    2013 crewmax lowered
    2/4 drop ,unichip tune , s&b cold air intake
    I am lowered 2 inches in front and have 22 inch rims and i hit a bump and it ripped all the plastic from under my wheel well, i don't care about replacing it because it will happen again but i do care that my air intake and passenger side of my engine and belts are exposed to water is there something i can do to cover them. also something that wont fall out after hitting a bump
  2. Jun 11, 2019 at 8:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Smaller tires and/or maybe extend the bumpstop?
    Tundra_361, Tundyfundy and Pudge like this.
  3. Jun 11, 2019 at 8:52 PM
    McFlappin
    i was just wondering if they sold something or i could make something to cover the air intake and engine so it doesnt get flooded with water and lock up but i will also look for bump stops as mine are flattend out
  4. Jun 11, 2019 at 8:56 PM
  5. Jun 11, 2019 at 9:07 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Superbumps or durobumps are a start.
    If youve got a bigger budget for the project consider air bumps. Will cushion much better on hits. If you get the bump position fixed you can rebuild the liner and it will not get touched again
  6. Jun 11, 2019 at 9:13 PM
    McFlappin
    do you think its okay to drive like this untill i figure something out?
  7. Jun 11, 2019 at 9:15 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Put a snorkel on it, lol :yes:
  8. Jun 11, 2019 at 9:25 PM
    TXTundra2722
    2015 Black Tundra
    I wouldn't drive it in the rain with it exposed like that(air filter). It ripped out your wheel well liner because the tire/ wheel combo and lowering kit were not set up quite right. Just like a lift, when lowering a vehicle you still have to articulate the suspension to make sure everything clears. Best of luck to you. Got any pics of the entire truck?
  9. Jun 11, 2019 at 9:31 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Try prefilter material. Won’t completely stop everything but it’s better than nothing
    ColoradoTJ likes this.
  10. Jun 11, 2019 at 10:27 PM
    McFlappin
  11. Jun 11, 2019 at 10:29 PM
    McFlappin
    the pre-filter material sounds pretty good for the time being
  12. Jun 11, 2019 at 10:32 PM
    15whtrd
    15whtrd Mr. Blonde
    Curious, what size is your overall tire diameter?
    Think about doing an AIP relocate. He relocates the breather inlet tube up inside the engine bay.
  13. Jun 11, 2019 at 10:36 PM
    McFlappin
    im not sure the actual height of tire but the tire is a 285/45/22 if that helps
  14. Jun 11, 2019 at 10:48 PM
    15whtrd
    15whtrd Mr. Blonde
    Here is a comparison. You are basically at stock hight with the tires. Just a little wider. I’m surprised you are rubbing so bad with only a 2 inch drop. It must be your wheel offset helping that situation. By the way I really like the way your truck looks!
    Did you do drop spindles or lowered coilovers?
    If you are on stock shocks with drop spindles, that may be your issue. Start with replacing your smashed bump stops and adding a shim or two underneath it. When people do spacer lifts they typically forget to shim their bump stops which causes shock failure. You are at the other end of the spectrum and blowing through your shocks and bouncing off of the bump stops and your inner fender. Think about doing a proper lowered shock set up to keep you off your bump stops and ditching those spindles if that’s what you have. Then you could replace the inner fender plastic.
    This may not be what you want to hear but I’m just trying to get you to fix the problem instead of cutting patching in fender wells.
    Marty McFly and Hbjeff like this.
  15. Jun 12, 2019 at 9:08 AM
    McFlappin
    i have 2 inch drop coils and beltech shocks
    15whtrd likes this.
  16. Jun 12, 2019 at 9:16 AM
    15whtrd
    15whtrd Mr. Blonde
    Good idea with the super bumps but I’m almost positive they won’t fit without jacking the truck up. But then he will be always riding on the bump stops. I think the ride might be harsh even though those stops are somewhat plush. But he definitely needs to adjust the bump stop position.
  17. Jun 12, 2019 at 9:17 AM
    McFlappin
    bolt on part or cut and weld?
    for relocating the bump stop
  18. Jun 12, 2019 at 9:22 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    @15whtrd you are probably correct. He might not have that much up travel left.
    To extend bumps is a bolt on. You jack up truck onto stands, remove shock assembly. Then you can put the tire back on and cycle your suspension freely. You can raise that tire up with a jack until it gets close to the liner/body. You will see at that point how much your bump stop needs to be lowered by with a spacer.
    I would seriously consider smaller tires though. You will be able to see this when you check your travel as well. You are running a stock sized tire basically. If you got one that is 1.5 inches shorter it might clear fine at full bump....
    15whtrd likes this.
  19. Jun 12, 2019 at 9:25 AM
    15whtrd
    15whtrd Mr. Blonde
    Soak the threads under the bump stop in PB blaster or something like it. Take some big channel locks and unscrew it. You will probably have to jack the truck up to make room to get it out. Add some spacers underneath each of them and bolt it back in. I am unsure of the equation to how much shim you would need.
    For instance when we are lifting a truck, a quarter inch shim on top of the coil overs equates to about a half inch of lift at the wheel. So in relation the bump stop is a little closer to the wheel so just a guess, a quarter inch of shim under the bump stop might limit the wheel travel about 3/4 to 1 inch in the wheel up travel.
    You can test this theory with some washers under a bump stop. Try a couple of washers and jack your truck up by the lower a arm. Hopefully it will compress enough to land on the bump stops and show you how far your wheel is traveling. Add or take away until you find the right combination. I would suggest shimming both bump stops on each side. Although the best Way to test this would be without the coil over in place.
  20. Jun 12, 2019 at 9:26 AM
    15whtrd
    15whtrd Mr. Blonde
    This would probably be best. That way he could keep as much suspension travel as possible. Plus it would gear his truck up a little bit and make it that much faster LOL.
  21. Jun 12, 2019 at 9:43 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I’d be worried about the intake for sure. I’d probably just install a new intake system, something that doesn’t pull from the fender well. Would kind of suck to lose the stock “cold air intake” but much better then sucking in water on accident. Get something that pulls from under the hood. Maybe install a functional hood scoop :)
    15whtrd likes this.
  22. Jun 12, 2019 at 10:05 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    This guy may have some suggestions...
  23. Jun 12, 2019 at 10:15 AM
    Keep in mind your Air Injection Pumps are completely exposed and need to be shielded from the elements.
    15whtrd likes this.
  24. Jun 12, 2019 at 11:15 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Get some flex hose and re route the filter elsewhere
