Rims for 2019 Platinum
Discussion in 'Wheels & Tires' started by SteveF, Mar 20, 2019.
  1. Mar 20, 2019 at 3:14 PM
    SteveF
    SteveF [OP] New Member
    2019 Tundra Plat
    Need help/ideas for black rims on my tundra platinum. 20” rims. Don’t plan on lifting the truck. Any recommendations, tips, ideas would be helpful. Don’t have a lot of knowledge in this field so any information would be helpful.
    YsoSeRiouS! and Y0TA PR0 like this.
  2. Mar 20, 2019 at 4:34 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Maybe get some oem toyota trd wheels and have them powder coated? The trd wheels are 18's and ride better than 20's. Cheaper to replace tires with 18's. You can get an 18" tire size that is a comparable diameter as the 20". Or paint those wheels black, and call it a day.
    I think stock platinum is 275/55/20.
    Trd wheel 275/65/18 same diameter as the 20"
    SteveF[OP] likes this.
  3. Mar 20, 2019 at 4:48 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Toyota TSS 20" wheels look nice.
    Faht Nocker likes this.
  4. Mar 20, 2019 at 4:49 PM
    Trooper2
    JR
    You could have those powder coated.....
  5. Mar 20, 2019 at 5:00 PM
    SteveF
    2019 Tundra Plat
    I’ve heard you can’t powder coat the middle cap. Is that true?
  6. Mar 20, 2019 at 6:01 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Go with black and machined edges, when the sun hits then they look white. Go great with your color.
    Fuel assault
    Or black and chrome
    Fuel rampage
    Prostar 190 likes this.
  7. Mar 20, 2019 at 7:11 PM
    Faht Nocker
    Woody
    Milky Way
    You can buy black trd caps. From @Roman
    Roman likes this.
  8. Mar 20, 2019 at 7:43 PM
    Trooper2
    JR
    probably not if plastic. i might leave as is for contrast or rattle can paint if needed.
    Joe Dirt likes this.
  9. Mar 20, 2019 at 7:52 PM
  10. Mar 20, 2019 at 8:17 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Really depends on how much you're looking to spend. Cast? Forged? Etc...
    Popular Choice:
    Fuel > HERE
    Other Choices:
    Arkon > HERE
    Or you can stay with an OEM or even PC your wheels, the possibilities are endless honestly...
  11. Mar 20, 2019 at 9:02 PM
    kejf2005
    kejf2005 New Member
    Antonio
    2018 tundra TRD sport crew max 4x4
    Find a good powder coater near you. Haven’t done mines but seen some really good ones.
  12. Mar 27, 2019 at 9:02 AM
    WhiteTundra1794
    WhiteTundra1794 New Member
    White Tundra 1794
    none yet
    Bought a set of Platinum wheels just like my 1794. Taking down to have powder coat glossy black today. Going to take the center cap to a local body shop to have them match the wheels once they are done. $300 for all 4. Working for Snapon has it's advantages.
    LiftMeUp likes this.
  13. Mar 30, 2019 at 9:05 AM
    SteveF
    2019 Tundra Plat
    Can you take a picture after you get them powder coated?
  14. Mar 30, 2019 at 9:32 AM
    WhiteTundra1794
    White Tundra 1794
    none yet
    Will do Steve. My truck looks just like yours but it is a 1794
  15. Mar 30, 2019 at 11:24 AM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Since you don't intend to lift your truck, you should look for a wheel within a specific offset range, i.e. +18 to +35. I would recommend you stick with +25 or higher (+25 to +35) so there will be no rubbing. So for example, a good 20" stock replacement wheel will be something like a Method NV: 20x9, +25, with 275/60r20 tires. These wheels will sit flush, and the tires will be 33" vs stock 32". With these specs, there will be no issues.
    Or a cheaper alternative is to simply put 1.25" hubcentric spacers on your stock wheels and use the same tire size listed above.
    Good luck!
    plumber802 likes this.
  16. Mar 30, 2019 at 12:14 PM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    Gulf States Toyota TSS Wheels
  17. Apr 3, 2019 at 4:38 PM
    SteveF
    2019 Tundra Plat
    Very nice!
    cheetahblue131 likes this.
  18. Apr 6, 2019 at 8:18 AM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    Do you have a your wheels back yet. I was wanting to do this and wanted to see how the plat wheels looked painted/powder coated.
  19. Apr 12, 2019 at 8:54 AM
    LiftMeUp
    LiftMeUp New Member
    Would love to see some pics when finished. Don't mind me asking, what does it run a wheel?
  20. May 5, 2019 at 9:01 AM
    SteveF
    2019 Tundra Plat
    I got them powder coated finally
  21. May 5, 2019 at 9:11 AM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    Thanks for the picture I think I need to do mine now!
  22. May 5, 2019 at 9:52 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I would like to see Platinum wheels have the gray part gloss black and the machined part stay the same.
  23. May 6, 2019 at 9:17 AM
    fireman02
    fireman02 New Member
    20 SR5
    Looks sharp. If my wheels don’t sell I may do the same, and keep them for winter wheels.
  24. Jun 10, 2019 at 9:06 AM
    WhiteTundra1794
    White Tundra 1794
    none yet
    20190510_172503.jpg 20190510_172440.jpg Finally powder coated. I like my truck so much better. Lifting is next
