Rear seat fold down mod
Discussion in 'General Tundra Discussion' started by joonbug, Oct 29, 2016.
  1. Oct 29, 2016 at 4:44 PM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This only works on Doublecabs.
    Here's @JMB's original write up to cutting the hooks.
    https://www.tundras.com/threads/dc-fold-down-rear-seats.699/
    There’s an easier way to do this mod by hammering down the rear hooks just enough for the seats to hook on.
    But I found that it causes the seat to recline back just enough to interfere with the sliding rear window. Not a big deal if you don’t have the slider or if you have a manual slider as you can just pull on the headrest a bit to get the window open. But if you have an electric slider, it’ll get caught on the headrest.
    original post on my 2015
    Took about 2 hours. Only thing I did different from this write up was I didn't remove the brackets and just grinded them in place. Glad I did, because I had to grind more than the 7/8" on one of the brackets. If I had removed them, grinded, and re-installed, I would've had to do this several times. And they look like a pain to remove. So instead I just kept them attached to the seat and kept grinding more until the seat locked in. Worked perfectly. But I don't recommend this if you don't have much experience handling a 4.5" grinder in tight spaces. And be careful to protect the interior from flying sparks. [​IMG]
    gacosta153, ColeR, tundra_20 and 13 others like this.
  2. Oct 29, 2016 at 6:18 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'm definitely going to have to try this!!
  3. Oct 29, 2016 at 6:26 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Yep indeed, this is one of those must do mods. The best return for the investment! I have a lot of stuff back there and all it cost was a little bit of time. There was a guy from another forum that was fabricating the hooks at the right size and powder coating them. Sold for around $50.00, i think. I would not run the grinder in the cab, myself, be to afraid of pits in the glass or holes in the upholstery. Wasn't too bad pulling 'em off.
    Law323 likes this.
  4. Oct 29, 2016 at 7:48 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah gotta love free mods. I would have pulled off the hooks but couldn't find my torx bits. They're probably with my 10mm socket. Dammit. Anyways, all I had was my folding torx key set and I just couldn't get it in there. So I just used a big plastic tub to shoot the sparks into with a couple of rags around it and it was fine.
  5. Oct 29, 2016 at 7:58 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Don't try, DO!
    Law323[QUOTED] likes this.
  6. Oct 29, 2016 at 8:03 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    What's crazy is, all Toyota has to do is shorten the hooks by 1 inch and we would all have folding seats. Why Toyota why?
    Julikins53, Tundra101 and gosolo like this.
  7. Oct 29, 2016 at 8:13 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Hi jack alert
    So yeah, several things about Toyota corporate decisions defy comprehension:
    1) No rear diff locker EVEN ON THE PRO
    2) No grab hanle, drivers side
    3) This, rear seat fold down
    Why oh why
  8. Oct 29, 2016 at 8:31 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Aye aye cap'n!!
  9. Oct 30, 2016 at 4:17 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    A tip of the hat to you. You are a bold man to throw those sparks inside the cab. Maybe you have a career training all the dumass welders that I have that can start even a piece of steel on fire.
  10. Oct 30, 2016 at 4:31 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    When I bought my first welder many years ago, I was living in an apartment. I was so excited to try welding but nowhere to do it. So, I set up shop in my living room and taught myself how to weld. Grinding metal and welding over carpet and furniture all around teaches you real fast how to manage sparks. :notsure: Or atleast try to... Lets just say I didn't get my security deposit back. But thanks for the write up John. I wouldn't have done the mod if I didn't see yours.
  11. Oct 30, 2016 at 6:01 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Being a welder and having sprayed spark and slag on surfaces all around as well as starting numerous unintentional fires I am also impressed!
    GODZILLA likes this.
  12. Oct 31, 2016 at 1:55 AM
    TRDFaux
    TRDFaux Irresponsible Adult
    2014 Tundra SR5 Crewmax 4X4
    Toytec level and diff drop, Cooper STT Pro Tires, TRD Pro Grill, blacked out, debadged.
    Being a firefighter, I would like to thank your kind for the job security....
  13. Oct 31, 2016 at 7:35 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    You're very welcome. I do what I can for our fire departments!! :)
    NewImprovedRon likes this.
  14. Nov 2, 2016 at 10:45 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I am wondering the same myself. Someone at Toyota corporate decided that it was better to have seats that fold up. That someone probably drives a Camry. First thing I noticed when I looked at the Tundra brochure was the picture of the back seats folded up. I thought that sucks. I leave the back seat down in Tacoma all the time. The fabric is protected, I have storage behind it, and a flat place to put stuff.
    gosolo[QUOTED] likes this.
  15. Nov 2, 2016 at 10:53 AM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    What do the brackets look like before/after? They look the same in all of your photos...
    UPDATE: I just looked at the other forum post. I understand now.
  16. Nov 2, 2016 at 11:30 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    god dam 10mm socket I probably have about 4 or 5 10mm sockets but I can never find it when I need it aint that a bitch
    aperezsh and joonbug[QUOTED][OP] like this.
  17. Nov 2, 2016 at 11:31 AM
    SuperSilverTundra
    does anybody know if there is a backseat fold down mod for the crewmax? tag me with the link I need to do this asap
  18. Nov 2, 2016 at 11:35 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I've never looked behind the seats on a CM but probably has something to do with the dropping rear window. Look and see if you have the same seat hooks as us. Maybe it's possible?
  19. Nov 2, 2016 at 11:40 AM
    SuperSilverTundra
    do you have any up close pick of the hooks you grinded down? so I can look and compare
  20. Nov 2, 2016 at 12:01 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    These are the hooks on the back of the seats
    And they hook onto these loops on the back wall
    Sunnier likes this.
  21. Nov 2, 2016 at 12:04 PM
    SuperSilverTundra
    ok cool thanks man these are similar to the back seats on the Tacoma im gonna check out my seats and see if I can access these hooks
  22. Nov 2, 2016 at 12:07 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    And I have no idea how the CM seats work, but while you're folding your seat up, the back has to lift up about an inch for it to work.
  23. Nov 2, 2016 at 12:09 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh, I just thought of something. Maybe there's no room back there on a CM because of the drop down window. You might want to see if there's even any space behind the seats before you go through all the trouble.
  24. Nov 2, 2016 at 12:16 PM
    SuperSilverTundra
    you know when I was at a dealership looking to buy my tundra I seen they had one in the showroom a 1794 crewmax with all the bells&whistles and I noticed that behind the back seats they actually had a subwoofer installed back there so I know for a fact there is space behind the seats I just haven't seen anyone with a write up on how to access that space i think this will be on my list of future mods
  25. Nov 2, 2016 at 12:20 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Same here! Can NEVER find any of my many 10mm sockets. Usually end up buying a new one.
  26. Nov 2, 2016 at 12:30 PM
    SuperSilverTundra
  27. Nov 2, 2016 at 1:28 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    These end up with the missing socks from the dryer
  28. Nov 2, 2016 at 1:33 PM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Is this mod possible on the crewmax. I have a 2015 CM and there is alot of room behind the seats and I'm tired of trying to stuff things back there from the side or from under the seats ( I always have my back seats folded up for the pup) but jackets, hats, gloves, treestand seat pad, first aid kit etc.. all fit just access sucks
    Julikins53 likes this.
  29. Nov 2, 2016 at 4:00 PM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    I can't attest to this but the Sub woofer may lie just below where the window rolls down to. It probably a little 8" sub.
  30. Nov 2, 2016 at 5:10 PM
    tidalwave01
    tidalwave01 New Member
    Sohil
    El Dorado Hills CA
    2016 1794 Black TRD OFF ROAD
    it took me by surprise when i went from a 2011 rock warrior to a 2016 1794 the seats in back do not recline or fold.
