Leveling TRD Exhaust
Discussion in 'Performance and Tuning' started by Tundyfundy, Jun 8, 2019.
  1. Jun 8, 2019 at 8:46 PM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    After installing my TRD exhaust it was very obvious that the drivers side exhaust pipe was closer to the body than the passenger side. Not only did the exhaust tip hit the bumper when I was off-road, it was visually off putting. I had to do something!! Also seeing a bunch of other people having this problem I decided to make a thread with the fix I came up with.
    I ordered these exhaust hangers...
    https://www.amazon.com/CarXX-Exhaus...a-571004886438&psc=1&ref=&adgrpid=70635887228
    After much frustration I decided to cut off my old exhaust hanger. I couldn't get it lose for the life of me. Once I cut it off I installed one of the new exhaust hangers.
    After installing only one hanger it was obvious that the hanger was not as rigid as the OEM hanger and it let the exhaust pipe vibrate while idling.
    In order to combat this I installed both hangers on the drivers side and it tightened up the exhaust pipe quite well! It was a little tricky to get them both on there but I drew a diagram to try and help explain how I did it.
    I love it!! It's even now and exactly level to the bumper!! Much more clearance then before and looks BA! The red hangers are visible from the side of the truck and add some flair compared with the rear sway bar.
    Anyway I'm not a pro at this but let me know if I missed something and be kind!
    PS
    As a side note I should add that I saw some guys recommending to drill out the bolt holes on the exhaust pipe or unbolting the exhaust and using jack stands to level it. I didn't want to crack those bolts for fear the metal gasket would mess up, or that I would be there all day trying to get it aligned with jack stands. I am so glad I tried this first!! 14 bucks and about 20 minutes and its forever fixed. Good luck and enjoy!
    Phantom Lord, ChrisTRDPro and JH5370 like this.
  2. Jun 8, 2019 at 8:49 PM
    Tundyfundy
    Bay Area, CA
    Pix
  3. Jun 8, 2019 at 8:57 PM
    AZTundra
    Paul
    Phoenix, AZ
    I need to give this a try. Mine is still high on the drivers side as well.
    Tundyfundy[OP] likes this.
  4. Jun 8, 2019 at 9:01 PM
    Tundyfundy
    Bay Area, CA
    Diagram: I sprayed both hangars with WD40 to help slid'r in easily.
    AZTundra likes this.
  5. Jun 8, 2019 at 9:04 PM
    Tundyfundy
    Bay Area, CA
    Do it! so easy and makes a big difference in the look.
  6. Jun 8, 2019 at 9:08 PM
    AZTundra
    Paul
    Phoenix, AZ
    I've got a balance left on an Amazon gift card, so I'll place the order tomorrow. I just ordered some eagle claws to hold my weathertech passenger side mat in place and a stubby antenna last night, this will be my next order. Thanks for posting this solution.
  7. Jun 8, 2019 at 9:11 PM
    Tundyfundy
    Bay Area, CA
    Nice! Let me know how the eagle claws turn out!
  8. Jun 8, 2019 at 9:19 PM
    AZTundra
    Paul
    Phoenix, AZ
    Will do. They should be delivered on Thursday or Friday, so I'll get them installed next Saturday.
  9. Jun 10, 2019 at 9:51 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    I’ve always just snugged up the 6 bolts, pushed down on high side while tightening, then up on low side while tightening.
    If it’s off too far still, take out the bolts one at a time and drill the holes bigger.
    15whtrd and Tundyfundy[OP] like this.
  10. Jun 10, 2019 at 10:02 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I’m glad you got your exhaust right too.
  11. Jun 10, 2019 at 12:03 PM
    Tundyfundy
    Bay Area, CA
    Hey Kieth,
    I saw that you posted that somewhere. I feel like this was way easier, permanent, and I don’t have to risk ruining the exhaust flange or steel gaskets. Also seems hard to keep the pipe where you want it while on your back trying to cinch down the bolts.
    To each their own but I found this fix very easy and the only tool I used was a utility knife. I’m just kicking myself for waiting so long!
    dirtydeeds[QUOTED] likes this.
  12. Jun 10, 2019 at 12:05 PM
    Tundyfundy
    Bay Area, CA
    Yes!! Thank you. Along with the coach builder shackles they improved the ride immensely. Although, the billet bracket was extra, and I think it should be included!
    dirtydeeds likes this.
  13. Jun 10, 2019 at 1:42 PM
    Omohundro
    Jody
    McMinnville TN
    Agree, the brackets are highway robbery, no pun intended.
  14. Jun 15, 2019 at 6:29 PM
    Tundyfundy
    Bay Area, CA
    Side note.... I off-roaded today and the exhaust didn’t hit the bumper once!! So stoked on this mod.
  15. Jun 15, 2019 at 8:56 PM
    AZTundra
    Paul
    Phoenix, AZ
    How did the excursion go today? I wanted to tag along, but couldn't get the day off at work to make the drive out to CA. On a side note, I got those eagle claws installed today for the passenger side weathertech mat...works pretty good at keeping the mat from sliding.
  16. Jun 15, 2019 at 9:14 PM
    Tundyfundy
    Bay Area, CA
    It was awesome! We had to cut it a bit short due to an appt we had but really fun! Good to know Ill order them tonight! Hope to see you on the next one!
  17. Jun 15, 2019 at 9:44 PM
    AZTundra
    Paul
    Phoenix, AZ
    Order more than you need just in case. I got the four pack and only used 2 on the passenger mat. One of the eagle claws bent as I tried to seat it into the carpet so I had to use another one and try again. If I needed all four I would have been screwed. Here is a pic of the finished product. Hopefully I can make a future trail run up there.IMAG3879.jpg IMAG3878.jpg IMAG3877.jpg
  18. Jun 15, 2019 at 9:58 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    God damnit. I tried ignoring this and pretending it isn't something I need to worry about, but sure enough the driver's side is a half inch lower. Sonofabitch.
    But seriously, thanks for posting this. Glad there is a cheap option to remedy the issue.
    Edit: I just realized @Tundyfundy and @AZTundra you both said you were high on the driver's side. Any idea why mine would be the opposite? My exhaust was installed at factory/port.
    Tundyfundy[OP] and AZTundra like this.
  19. Jun 15, 2019 at 10:11 PM
    AZTundra
    Paul
    Phoenix, AZ
    No idea why yours would be the opposite. I thought maybe the drivers side was higher due to new stiffer exhaust hangers while the passenger side reused the stock hanger. I ordered the same red hangars as @Tundyfundy but haven't received them yet. the other option according to Keith at dirtydeeds is to loosen the three bolts to the tailpipe section and rotate the pipe a little and retighten.
  20. Jun 15, 2019 at 10:20 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'll crawl under tomorrow and take a look. Maybe Keith's suggestion will work for my situation.
  21. Jun 15, 2019 at 10:35 PM
    Tundyfundy
    Bay Area, CA
    Worth a shot, it didn’t really bug me too much but the pipe would bang the bumper when the truck would rock. Not cool. Think about is the driver side low or is the passenger side high? Choose which side has the height you like and adjust the other one. Post some pix after!
  22. Jun 15, 2019 at 10:46 PM
    Tundyfundy
    Bay Area, CA
    Awesome! Ordered 4 pack w 3/8 hole cutter. Nice cheapish Mod and functional!
    AZTundra[QUOTED] likes this.
  23. Jun 16, 2019 at 8:49 AM
    AZTundra
    Paul
    Phoenix, AZ
    I've got one one claw left over if by chance you need it let me know.
