Headlights went off left blinker
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Jun 8, 2019.
  1. Jun 8, 2019 at 1:17 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    this morning driving early in the morning my headlights blinked off when I used my left blinker and then came back on.
    What is causing it and what is the fix. This is the first time it happened. My Tundra is a 2015 with only 74000 miles on it.
    I am fixing to go on vacation in 2 weeks should I be concerned about it before I leave?
  2. Jun 8, 2019 at 4:09 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @kcaustin66, it could be a number of things. Check that your headlight harnesses are all intact as well as all of your fuses. It could possibly be your multi-function headlight switch. There could be a short or a bad connection. If it were my guess, the latter would be my pick. And to answer your question, yes you should be concerned. There's a chance the headlights wont come back on:eek2:, not a great place to be in the dark. Good luck and let us know.:thumbsup:
    Black Wolf likes this.
  3. Jun 8, 2019 at 4:30 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This is a known issue and there are a few threads about it. Happened to me twice in a weeks time, always when turning left. I have a 2015 platinum with an ihacker harness for 2018 LEDs
    I think the issue is the blinker stalk but Toyota hasn't acknowledged the problem as a TSB.....yet
    rons23 likes this.
  4. Jun 8, 2019 at 5:02 PM
    BWinter
    BWinter New Member
    Central California
    2018 White 1794, TRD Off Road, 4x4
    T-Rex266 likes this.
