Items needed for sound system install?
Discussion in 'Audio & Video' started by EAK, Jun 6, 2019.
  1. Jun 6, 2019 at 9:57 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    Hey guys, I’m in need of some quick help. I’m having a system professionally installed in 2 weeks and need help listing items needed for install.
    Truck:
    - 2015 crew max 1794 with JBL system
    Items I have or know I need/want:
    - JBL sub replacement and JBL Stadium 5 channel amp (@james@tech12volts group buy)
    - New HU. Thinking Kenwood DMX906s for wireless CarPlay. Thoughts?
    - iDatalink Maestro
    - TO2 harness
    - Scoche dash kit
    What else do I need or you recommend?
    - Wiring kit? Which one?
    - Anything else?
    I thought the install place was fair on labor, but overcharging for parts, so I’m bringing my own. Thanks in advance for your help.
  2. Jun 6, 2019 at 10:04 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    any 4ga ofc amp kit
  3. Jun 6, 2019 at 10:10 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    Thanks Danimal86. I’ll add this to the list.
  4. Jun 7, 2019 at 5:47 AM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    Bump to the top.
    If the list looks complete, please let me know. I’ll be having it installed out of town so it’s important to me to have everything needed on the install day.
  5. Jun 7, 2019 at 7:04 AM
    tundraal
    tundraal New Member
  6. Jun 7, 2019 at 8:34 AM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    Thanks tundraal for your input. Very helpful.
  7. Jun 7, 2019 at 9:03 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Antenna adapter https://www.crutchfield.com/p_12040LX11/Metra-40-LX11-Antenna-Adapter.html
    USB adapter https://www.crutchfield.com/p_120TOYUSB/Metra-AX-TOYUSB-USB-Port-Cable.html
    Satellite radio adapter if you wanna use xm or factory nav antenna
    Flash you maestro when it comes
    Some sound deadening would be nice
    4 awg amp wiring kit, extra RCA cables for running multiple channels. Most lots come with 1 set of RCAs
    Depending on where the amp is going, you may want a 9 conductor wire to run from the amp to the area under the seat where the connections for all the speakers will be picked up. I actually have one for sale if you want. I ended up not mounting my amp where I planned so I didn't need it. It has pos+ and neg- wires for 4 speakers and also the amp remote turn on wire all wrapped in one casing, making install faster and much easier.
    https://www.crutchfield.com/S-j3axW...8MqkS6wi1pxrjqMisVWSSzcWialfOD3Ga3BoCeKrw_wcB
  8. Jun 26, 2019 at 4:30 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    OP... did you install this Kenwood Excelon DMX906S? I've just picked up the same unit, accessories, powered sub from Crutchfield. Install pending.
  9. Jun 26, 2019 at 7:34 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    I did not. The deal for the used amp and sub didn’t go through so I pulled the plug on the whole thing.
    Still looking to buy a HU. Let me know how you like the DMX906s. I was considering it solely because of the wireless CarPlay, but I’ve read some poor reviews on the sound quality of wireless CP.
  10. Jun 26, 2019 at 8:18 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    Don't underestimate the power of sound proofing. It really makes a difference. Good advice from @Pudge.
    Pudge likes this.
  11. Jun 26, 2019 at 8:27 PM
    EAK
    EAK [OP] New Member
    KY
    ‘15 White 1794
    I see Pudge posting all over the place on the forum. Definitely appreciate the knowledge he shares.
    Pudge, you definitely come across as someone who knows about audio installation. Preprare yourself for my DMs when I take on this task! :smash:
    Pudge likes this.
  12. Jun 26, 2019 at 8:41 PM
    Pudge
    CT
    Everything I know, I have learned here. I just share what I have learned to try to help others. There are some real experts here, in all aspects of truck life. I have nothing on most guys but Thank you.
  13. Jun 27, 2019 at 4:01 AM
    GeoJoe
    Quality reply. I try to do the same.
    Install of this unit, with Maestro, Kenwood Dashcam, Audiovox camera (mounted in front) and powered sub all going in next week. I'll report back on results... but I am deaf in one ear so WTF anyway. :eek:
    Pudge[QUOTED] likes this.
