Toyota Corporate Field Technical Service Agent (FTS)
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1fujifilm, Jun 6, 2019.
  1. Jun 6, 2019 at 9:09 AM
    1fujifilm
    1fujifilm [OP] New Member
    Bear
    19 Tundra Crew
    Hi All,
    I have a doosey for you guys and gals, I was blown away today by the process to get some warranty work done; AND IT IS RIDICULOUS!
    -Took my 19 Tundra with 863 miles to an appointment on 5/25/19 to have the tailpipe adjusted (it is almost touching the paint), a sharp piece of plastic molding on the steering wheel that catches my thumb and a headliner that has come apart from the Bluetooth microphone.
    Service advisor looks at it all and says he will have to get approval from Corporate FTS prior to any work and he will call me on 5/27/19.
    -5/31/19, I get no call back so I call the service advisor and she states we are waiting for FTS approval and will call you tomorrow.
    -6/9/19, I get no call back so I call service manager and he states the FTS has five states to cover and is busy person. We review my three concerns and I say "you need to talk to Toyota corporate to do a few hundred dollars in work"? He says yes. I think "that is the saddest thing I ever heard, a Manager that can't approve a sub-$500 expense.
    Anyway, we will wait for the FTS to see the truck. YES, I HAVE TO TAKE IT BACK TO DEALER FOR THE FTS TO APPROVE WARRANTY WHEN IT WORKS FOR HE/SHE'S SCHEDULE. THEN, TAKE IT BACK WHEN THE PARTS ARE IN TO GET FIXED!
    Oui to the Vee! This must be some of that "Lean process" that "Toyoda" perfected and we learned in college 20 years ago.
    All I wanted was the darned tailpipe adjusted so I can put the TRD chrome tip on. The others 2 concerns I can fix at home with a file and super glue.
    Bear
    panicman, Trooper2 and Black Wolf like this.
  2. Jun 6, 2019 at 9:18 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Wow! That is ridiculous!
    bumper to bumper warranty, should be done no question asked!
  3. Jun 6, 2019 at 9:25 AM
    tundraal
    tundraal New Member
    Doesn't make any sense man. Is there another dealer in your area? Maybe give corporate a call(s) and let them know what a hassle this has been for you....
    Y0TA PR0 likes this.
  4. Jun 6, 2019 at 9:40 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    My headliner was coming down near the overhead console and I called the dealer, they had me come in to see it, ordered the new headliner and called me a few days later to replace. Service Manager was most eager to make sure I was satisfied and didn't have to get approval from a Corporate field person. Actually, the new one was coming down in the same place, went right back when I noticed and it turned out to be an adjustment on the placement of the console overhead that houses the map lights and sunroof controls. They corrected the problem and I have not had an issue since. Sounds like the dealer needs a little more pressure on them!!
    Black Wolf likes this.
  5. Jun 6, 2019 at 10:19 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Go to a different dealer.
  6. Jun 6, 2019 at 10:27 AM
    Stig
    Stig New Member
    This.
    Amd file a bbb complaint on the first dealer and on Toyota regional.
    sundance likes this.
  7. Jun 6, 2019 at 10:46 AM
    marcfs71
    marcfs71 New Member
    Marc
    2010 Grey Tundra TRD Offroad Pkg with TRD Supercharger
    Dual Exhaust
    Put a jack under the tail pipe about a foot or 2 back and stick a long tube (jack stand handle) in the pipe and press down on the pipe a few times. You will do a better repair job than the dealer!
    kstateskier likes this.
  8. Jun 6, 2019 at 11:37 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I would never go back again.
    Never had to have an approval for my Tacoma when it went into limp mode.
    I had it towed in, they gave me a loaner and I was back a day later to get it.
  9. Jun 6, 2019 at 11:48 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Don't do this.
    Here is what you do: loosen the clamp near the mid-section (close to muffler), position the tailpipe to position you want and then tighten loosen clamp.
    Paul B and Duneflyer like this.
  10. Jun 6, 2019 at 11:50 AM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    Ya... thats a dealer issue. Change dealers... and fast. I have had several things replaced on my 17, just because the warranty is almost up. all approved in the same day. Hell they warrantied my front hood cowling that I probably broke the clip myself.
  11. Jun 6, 2019 at 11:53 AM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    Perhaps the service advisor/manager is new and wasn’t aware what he does or doesn’t have authority to approve. Regardless, you have every right to be upset and can’t blame you for being so.
  12. Jun 6, 2019 at 12:05 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Exhaust Dirty Deeds 8”SS, some led lights, Osram headlights, Pro Stop brakes, Pop Lock, AFE dry air filter with charcoal delete.
    Post the dealers name and service managers name here so we know who to avoid.
    ScooterInNV and Duneflyer like this.
  13. Jun 6, 2019 at 12:07 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    I would talk to another dealer if that's an option. Sounds like your current dealer doesn't want to help you out. And the field agent thing sounds like a load of BS. I went in at 57k to assess my cam tower leaks and within 2 hours the work was totally approved, parts were ordered and a loaner vehicle was reserved for me. No need for a "field agent" or an "I'll call you in a few days."
  14. Jun 7, 2019 at 6:31 AM
    1fujifilm
    Bear
    19 Tundra Crew
    I received a second call back on 6/6 and was told the exhaust is indeed notched and can't be adjusted without going aftermarket.
    They did get warranty approval to do the headliner and will buff the steering wheel a bit to soften the edge.
    All in all, I am happy.
    I buy new every other year while under warranty and will just leave the headliner.
    Bear
  15. Jun 7, 2019 at 6:56 AM
    sundance
    sundance New Member
    I got the same treatment some time back from a dealer I've been to for YEARS.
    I finally went Toyota Customer Service and another dealer. Had my issue fixed immediately.
    Since I quit going there, I've noticed the service manager is gone and most of the service department.
