  1. Jun 5, 2019 at 11:16 AM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Tried looking through the graphics on their website but didn't see the TRD Off-Road or even anything Toyota. Did you have to call them to have that put on?
  2. Jun 5, 2019 at 11:18 AM
    ToyodaTundra
    ToyodaTundra New Member
    Oregon
    2019 Tundra TRD OR CM SR5 MGM
    Yeah give them a call and ask them for the code. They have a variety of TRD logos. I think they will actually email you the sheet and you can pick what you want.
    Watt maker and danno266[QUOTED] like this.
  3. Jun 5, 2019 at 11:48 AM
    Isn't it under warranty?
    escuzi_me likes this.
  4. Jun 5, 2019 at 11:53 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I had to remove my front fender liner to fit my tires so I’m thinking this was a result of that. I’m thinking a Baja Design’s pod will hold up better in that area.
    Watt maker likes this.
  5. Jun 5, 2019 at 11:56 AM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Not a bad idea. :cheers:
    Amnesiac[QUOTED] likes this.
  6. Jun 5, 2019 at 12:03 PM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    Added Rebounds and 285/75r17 KO2’s
    FE81CAF2-C0E2-41DC-828D-7F0A1884B972.jpg 798C8672-1B03-4BDD-9312-BCA1A1E0F9A1.jpg
  7. Jun 5, 2019 at 12:09 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Nice. Now if I could only find someone that make a LED light with an amber turn.
  8. Jun 5, 2019 at 12:29 PM
    Amnesiac
    Amnesiac When I am king, you will be first against the wall
    PDX
    2019 Superwhite TRD Sport
    Did you get these installed? Any pics?
  9. Jun 5, 2019 at 12:35 PM
  10. Jun 5, 2019 at 1:05 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Looks good. Do you have any pics to show how much they stick out past the fenders?
  11. Jun 5, 2019 at 1:21 PM
    phiredrop
    phiredrop New Member
    2015 MGM Tundra Platinum
    What did you use to black out your grill? Has the coating on the grill and steps been pretty durable? Or do you have to reapply for chips and discoloring, etc.. Looks awesome!
  12. Jun 5, 2019 at 3:08 PM
    dochanson
    dochanson New Member
    Gabe
    That’s the same mount I used for my Smittybilt. You will 100% have to rotate pump head. I also had to shorten mount legs by about 2 inches.
    Good luck
  13. Jun 5, 2019 at 3:20 PM
    Duckslayr
    Duckslayr New Member
    671 Ltd Cement
    Painted grill with 2 coats SEM plastic adhesion, 3 coats SEM trim, and RCI skid installed
  14. Jun 5, 2019 at 3:32 PM
    Duckslayr
    671 Ltd Cement
    Coachbuilder +3s
    King Extended Travel, coachbuilder shims, and TC uca installed
    Black vs Silver bolts. Still undecided.
  15. Jun 5, 2019 at 3:42 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Nice. Thanks for the pics, dude.
    ToyodaTundra[QUOTED] likes this.
  16. Jun 5, 2019 at 4:25 PM
    Sephon
    Northwest PA
    The perfect amount!
    764C671E-217F-447F-A88A-9B15C938C3C0.jpg DAEEF034-D987-4949-A619-677F147A907C.jpg
    cjmay13, Deafmate, FlyTundra and 4 others like this.
  17. Jun 5, 2019 at 4:36 PM
    easleycrawler
    Travis
    Yep, that's perfect. I'm glad someone finally has a black Tundra with chrome, that has gone with the black rebounds, been looking for that combo for awhile. I'm fixing to order the same wheel and tire, except I'm going with 285/70's. I'm keeping my suspension stock.
    Sephon[QUOTED] likes this.
  18. Jun 5, 2019 at 4:49 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    lol same thing happened to me
  19. Jun 5, 2019 at 5:08 PM
    Sephon
    Northwest PA
    Awesome! You are going to love it. This is exactly the look I wanted. The only downfall is it makes me want to paint my calipers. Which isn’t the end of the world.
    easleycrawler[QUOTED] likes this.
  20. Jun 5, 2019 at 5:15 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Painted exhaust with hi temp semi gloss.
    And steering wheel emblem with plastidip witb glossifier.
  21. Jun 5, 2019 at 5:21 PM
    Redstag
    Redstag New Member
    Summerland B.C.
    2019 Tundra trd offroad
    275/70r18 ko2 Chrome delete grill Chrome delete rear bump caps Tonneau Linex berliner ...old man emu coming
    Ronin antenna and centre organizer.
    Like a new truck everytime!
  22. Jun 5, 2019 at 8:13 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    1 vote black
  23. Jun 5, 2019 at 8:16 PM
    TomC843
    Tom
    Charleston, SC
    This is all an experiment. Less that $75 total and I can just through it into the Swing Case if I fail at mounting it.
  24. Jun 5, 2019 at 8:37 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    The grill was black from factory.. this was awhile ago, so I don’t really recall what I used. But the steps chipped a little so I need to resray with something better. Luckily they were already black, so ya can’t really tell lol
    phiredrop[QUOTED] likes this.
  25. Jun 5, 2019 at 10:11 PM
    Pudge
    CT
    Thanks! If you climb under you'd sesee lots of surface rust that need attention but for the most part it's pretty good. Fluid film is my friend, it's all dry now though cuz its been over a year. I'm a little anal about it if you can believe it. I do need to get under there with a wire brush and rattle can this summer. Then I'll spray a coat of fluid film everywhere.
    NewImprovedRon and Watt maker like this.
  26. Jun 6, 2019 at 4:52 AM
    Glaze22
    Glaze22 New Member
    Reed
    2017 CrewMax
    +100000000 for Fluid Film!!!!!!!!!!
    Pudge and NewImprovedRon like this.
  27. Jun 6, 2019 at 7:55 AM
    phiredrop
    Love it. I got my dad the Ronin 50 cal antenna for Father's Day last year. It turns heads like crazy and he always gets asked about it!
  28. Jun 6, 2019 at 7:58 AM
    phiredrop
    Looks so good! Have a link to the paint used on the grill? Looking to do similar with my Platinum!
  29. Jun 6, 2019 at 10:34 AM
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    I like those but I use my stock antenna to gauge if I have enough clearance for parking decks
    HellBent, Omohundro and NAFlash like this.
  30. Jun 6, 2019 at 10:38 AM
    ktmhauler
    GA
    Added the Havoc HS3 nerf bars and OEM blackouts. ended up leaving the 5.7 badge as is as I like the chrome with black lettering better than the full black
    Found some TRD wheels on ebay off a 2019 that supposedly only have 25 miles on them, that are coming next week, going to mount the stock 255's back on them and get some life out before probably putting on some of the Deegan 38 AT's
    Omohundro, mgm16trdpro and NAFlash like this.
