  1. Jun 3, 2019 at 5:37 AM
    Durobumps
    Durobumps Made in the U.S.A.
    Plastics Guy
    Tucson, Arizona
    Are we Active now?
    Use TRON10 for 10% Off and Free Shipping
    Awesome! We love the upgrade! :cool:
  2. Jun 3, 2019 at 6:10 AM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Nice rig....stance is perfecto.
    YTThao530[QUOTED] and Pinay like this.
  3. Jun 3, 2019 at 8:25 AM
    Lexus4jess
    Lexus4jess New Member
    jesse
    Magnetic Gray 2019 SR5 Tundra
    TRD shifter, painted grille Both, Black out tundra emblems
    I need to do this to my truck.
  4. Jun 3, 2019 at 8:29 AM
    Lexus4jess
    jesse
    Nice DIY.
    Cthulhu[QUOTED] likes this.
  5. Jun 3, 2019 at 8:40 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Sound deadening all weekend.
  6. Jun 3, 2019 at 9:33 AM
    jmdaniel
    Leander, TX
    Thank you!
    NewImprovedRon likes this.
  7. Jun 3, 2019 at 9:36 AM
    effektz
    effektz New Member
    Fort Worth, TX
    2017 Tundra CM TSS Offroad
    Added Dynamat to all 4 doors and back wall. Going to get some killmat and dynaliner for the roof before ordering some MLV and CCF for the floor
  8. Jun 3, 2019 at 11:13 AM
    phiredrop
    phiredrop New Member
    2015 MGM Tundra Platinum
    LOVE the idea of sound dampening. I'm really interested to hear your feedback on how much difference it makes, and if there are any guides you followed and/or tips tricks to getting it done and making it worth the effort.
  9. Jun 3, 2019 at 11:19 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    What do you have up front, leveled 2-3?
  10. Jun 3, 2019 at 11:28 AM
    effektz
    effektz New Member
    Fort Worth, TX
    @phiredrop It made a big difference for me. I drive 60 miles round trip to work on the freeway everyday and I had to have the stock radio at about a 40 just to hear it comfortably with cruising. After I did the dynamat, I can now have the radio at about a 12-15 to hear it the same as I did before it.
    I watched all of the Taco Tunes videos on how to install the sound deadener on YouTube and used them for reference during installation. A couple things I noticed during my install were
    • Decided to add dynamat to the inner door skin as well as the outer one. The area is really tight for anyone who is tall or has big hands (I am 6'5'') and I felt like at times I was auditioning for the next Cirque du Soleil act. The inner doors take time but I think are well worth doing even though some may disagree.
    • Wear disposable gloves, its much easier to handle/position the material with gloves on that getting it stuck on your skin
    • Make sure to follow the advice Taco Tunes said on the video and overlap the material
    • Make sure to have a good roller and expect your hand to cramp non stop until your done
    • Be sure to add material behind and around the speaker as well, it made my stock system sound much clearer
    • Be sure to do the rear wall and not just the doors. The rear wall had a LOT of noise that I never realized.
    • Make sure you have more than enough material. I thought I was going to be short a day before the install so I ordered another box on Amazon and man that saved my life. That would of sucked to have to remove everything a second time if I didnt have enough.
    • Drink lots of beer. Took me about 8 hours to do all the doors and rear wall
    If you have any other questions, just let me know! Happy to help!
  11. Jun 3, 2019 at 11:44 AM
    Cthulhu
    Thanks! Adding the clear silicon sealant to the raised ridges definitely helps. I can maneuver the truck back and forth aggressively (to clean the loose rubber off my tires like NASCAR :rofl:), and the phone won’t slide a millimeter.
  12. Jun 3, 2019 at 11:44 AM
    jmdaniel
    Leander, TX
    https://www.tundras.com/threads/sound-matting-worth-it.22604/
  13. Jun 3, 2019 at 11:50 AM
    Gary86
    Gary86 New Member
    Gary
    2024 SR5 TRD Off-Road
    6" Readylift|Hostile Rage 20x10|Toyo OC R/T 35s|TRD Sway Bars| 2019 PRO Headlights w/ @iHacker harness|Morimoto Foglights|5% Tint
    Front install. The rear is on the way.
  14. Jun 3, 2019 at 11:56 AM
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    Last weekend, TRD rear sway bar. Love it, corners so much smoother.
    Saturday I plastidipped the cupholder and shifter trim and added tvd radio decals. The decals were a pain in the ass and I couldn't get them perfect but look pretty good.
  15. Jun 3, 2019 at 11:59 AM
    jmdaniel
    Leander, TX
    All good points.
    On the material, it looks like we applied to the same areas, and I used almost all of my material, which consisted of 1 - 36sq ft and 1 - 18 sq ft box of Noico. I also used two rolls of the Noico tape.
    Agreed on the tightness of the inner door panels, and also, that Toyota metal can be sharp! My left hand/arm looks like I am the world's worst at cutting my wrists. I had RC surgery on my right shoulder in February, so am still mainly using the left.
    When you pull the factory plastic sheets off the doors, use a very quick and hard pull, and you will get off all/almost all of the glue used to hold them to the doors. If any is left, press the plastic sheet, (a clean portion of it), back over the remaining adhesive, and give it a quick yank. Having the doors clean of this makes applying the material so much easier.
    Get a set of plastic trim tools before you start. They will make popping some of the pieces off much easier, and are invaluable to pull the white plastic inserts out of the door w/o damaging them. Some of these connectors will stay with the door panel when you remove it, but you'll have to pull the ones that are still in the door, and reattach them to the door panel.
    Halfway through, I shot this video. Thumps 1 and 3 are the undeadened front door; 2 and 4 are the deadened back door.
  16. Jun 3, 2019 at 2:55 PM
    Blueknights75
    Ron
    Clayton, NC
    Big shout out and thank you to @SR5 AZUL and @Beesta for hooking me up! Finally after months and months I have found the 19’ PRO BBS wheels!! Now time for a slight lift and meatier tires. Xtreme Offroad in Chesapeake, VA is an amazing shop and I highly recommend them as well!
    99D0E4EF-586C-4ACC-B888-0603DF3F8008.jpg 0E2F76A6-BE5E-4E5E-B7B2-088ECB97391D.jpg
  17. Jun 3, 2019 at 3:25 PM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    Today I appreciated the shine it has 2 weeks after applying beadmaker, getting rained on/muddy and a quick scrub and towel dry last night
    mgm16trdpro, Watt maker and Pinay like this.
  18. Jun 3, 2019 at 3:50 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Awesome Ron!! :thumbsup::thumbsup:
    They look Bad A$$!! :muscleflexing::muscleflexing:
    Blueknights75[QUOTED] likes this.
  19. Jun 3, 2019 at 4:32 PM
    GreyGhost15
    GreyGhost15 New Member
    2015 MGM TUNDRA SR5 CREWMAX 4X4
    https://www.tundras.com/threads/big-easy-build.66540/#post-1731305
    Thanks for replying back. That's what i thought it was, going to order me some from Amazon after seeing the shine from yours.
  20. Jun 3, 2019 at 5:06 PM
    PNW-Tundra
    PNW-Tundra New Member
    Brent
    Washington
    2017 Crew Max SR5 TRD
    Fire extinguisher wrapped up. For the areas I hunt in the fall, we are required to carry at least a 5lb extinguisher as part of our access requirements.
  21. Jun 3, 2019 at 5:46 PM
    phiredrop
    Thank you both for the info! Will definitely be adding this to the 'to-do' list!
  22. Jun 3, 2019 at 6:19 PM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    Looks great, mine is loose in my diamondback tray. What mount is this?
  23. Jun 3, 2019 at 6:21 PM
    crabbymcnab
    2016 Inferno SR5
    I’ve got a set of the +3 still in the wrapper from the last group buy. I’m thinking I like the +2, what do you have on the front?
    YTThao530[QUOTED] likes this.
  24. Jun 3, 2019 at 6:23 PM
    crabbymcnab
    2016 Inferno SR5
    What mounts are these?
  25. Jun 3, 2019 at 6:27 PM
    PNW-Tundra
    Brent
    Washington
    The rubber grippers are quick fists. I have them mounted to some aluminum flat bar that I have mounted to my bed rails.
  26. Jun 3, 2019 at 6:27 PM
    crabbymcnab
    2016 Inferno SR5
    Quoting to find this easier later on
    jmdaniel[QUOTED] likes this.
  27. Jun 3, 2019 at 6:30 PM
    crabbymcnab
    2016 Inferno SR5
    This past weekend the truck got a wash, rotated the tires and changed the oil.
    Toyota is a Japanese company, my truck assembled in Texas using wheels made in China. Thought it was humorous when I saw that.
    Watt maker likes this.
  28. Jun 3, 2019 at 7:28 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Got these reverse lights installed. Thanks to @mgm16trdpro for the help!E57732F5-836D-438C-A3C7-30C2D783E2DD.jpg DADAC580-59FF-4471-B763-B681B49831DE.jpg
  29. Jun 3, 2019 at 8:36 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Nice job! Glad to see someone else going with foam and mlv. You wont regret it!
    I wanna do my roof with something. I'm afraid to pull the liner down but I just know itll make a HUGE difference in sound. I gotta do it.
    snarkscarbine likes this.
  30. Jun 3, 2019 at 8:43 PM
    Pudge
    CT
    Its definitely worth the time, effort, and money. Especially if you do it right. CLD tiles, closed cell foam, mass loaded vinyl, tape seems, maybe add some insulation or a reflective layer. My cabin is so quote now, and I can blast my radio and barely hear it outside the car. No vibrations, no rattles. Doors close like a 1980s caddy. Music sounds better. It's a big project but worth it
