3rd gen turn signal blinking fast. All bulbs are brand new
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bnelson1777, Jun 1, 2019.
  1. Jun 1, 2019 at 1:42 PM
    Bnelson1777
    Bnelson1777 [OP] New Member
    Brandon
    Magnetic grey sr5
    Step bars. Bumper guard. Led light, campershell
    Hi new to the forum. So my turn signals are blinking fast as if the bulbs are out. And since they are blinking fast . This last month I went through 3 sets of bulbs. The 15 amp fuse for my turn signals and haz is good
  2. Jun 1, 2019 at 1:44 PM
    TXTundra2722
    2015 Black Tundra
    Did you buy the truck used? Sounds like there might be an LED bulb in there if all the signals are working
  3. Jun 1, 2019 at 1:48 PM
    Bnelson1777
    Brandon
    Magnetic grey sr5
    I've had the truck for a year. And this just started happening a month ago
  4. Jun 1, 2019 at 1:49 PM
    TXTundra2722
    2015 Black Tundra
    What year is your truck?
  5. Jun 1, 2019 at 1:52 PM
    Bnelson1777
    Brandon
    Magnetic grey sr5
  6. Jun 1, 2019 at 3:02 PM
    TXTundra2722
    2015 Black Tundra
    Check front and rear on the side that's blinking fast for two things, first to see if one is burnt out. The second(if it's not burnt out) check to see if one of the bulbs is an led light
  7. Jun 1, 2019 at 4:36 PM
    Bnelson1777
    Brandon
    Magnetic grey sr5
    They seem fine. But the front ones are out again. So I'll replace the front and the back this time. Just make sure I didnt overlook something
  8. Jun 1, 2019 at 4:57 PM
    SCtundra215
    SCtundra215 New Member
    Jmart
    Sc 2nd gen Trd
    Supercharged 5.7L Trd big brakes Trd sway bars Trd exhaust Amp power steps Decked bed box 3.5” lift 35” kumho m/t 20” -44 rockstar blk/machine 811 wheels
    I went threw this today, I replaced a amber bulb with a clear bulb that had the exact bulb # I needed , I figured the casing is Amber and should be fine, if I put it on either side the light would work but the blinker would flash. Went to auto zone and got amber and problem solved
  9. Jun 1, 2019 at 8:00 PM
    et bowman
    et bowman New Member
    its the running light and blinker bulbs are the same bulb they run all the time when truck is running it will burn out the socket the bulb sits in it is a common problem you can replace the socket or dock for about $10 from dealer ship they usually have them in stock thats how common a problem it is mine done the same thing i haven't done it but they told me they could turn the running lights off then the bulbs would only be turn signals if i have any more problems thats my next move
  10. Jun 1, 2019 at 8:17 PM
    et bowman
    o yea look when you take your bulb out the socket is usually a litte discolored somwhere in it where its been hot it will keep shooting bulbs till you change the socket its about a 3 min job to change the socket so dont pay the dealer ship to do it hope this helps you
  11. Jun 1, 2019 at 8:44 PM
    This^^^^^
    Replace the bulbs with LED's after you change the socket, the will run cooler.
    Good luck
    Welcome from NY.
  12. Jun 7, 2019 at 6:21 AM
    Bnelson1777
    Brandon
    Magnetic grey sr5
    So I changed all the bulbs even the back ones. And the two front signals went out . I'm just taking it to the dealership this is so frustrating
  13. Jun 7, 2019 at 3:15 PM
    Buz
    Buz Hold My Beer
    Houston
    2017 MGM Crewmax TSS Off-Road
    Just had this going on recently on the right front and realized I was not getting a positive seating in the socket. A little electric grease and it “clicked” in, going on 3 weeks and no issues.
  14. Mar 12, 2020 at 2:33 PM
    Jota21
    Jota21 New Member
    I'm having this exact problem. Is your bulb still 'seated'? Which grease did you use?
    For those suggesting to replace the socket, does anyone have a 'how to'??
    Thanks
  15. Mar 12, 2020 at 3:48 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    They need to be pressed in fully. They need to snap into place, I've had this similar issue before where you replace the bulb and they cut out or have hyper blink even though they're new. I've pressed them in so hard I thought I was about to break the bulb, but snapped into place and worked perfectly. I haven't replaced those sockets in 13 years and even snapped a piece out of one of them and they still work fine. Mine are black and gray, half melted, like they've been sitting on the edge of the sun, but still work. Hope this helps someone.
    AZBoatHauler likes this.
  16. Oct 25, 2020 at 5:54 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    How do you replace the socket? Do you have to remove the front grill to change the bulb? Looking for an excuse to upgrade to alpharex or something.
