Stupid question time...whats the difference between forward and reverse?
Discussion in 'General Tundra Discussion' started by airgunner, May 31, 2019.
  1. May 31, 2019 at 5:50 AM
    airgunner
    airgunner [OP] New Member
    N-KY
    2015 DC MGM TRD
    So can some one explain to me why a lot of people report that after getting larger tires, they have some rubbing in reverse?
    What I mean is, if turning your wheel all the way to one side and backing up causes rubbing, shouldn't it rub just as much if you were going forward (assuming you are on a level surface in both cases)?
  2. May 31, 2019 at 5:53 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Weight distribution is more pronounced in reverse.
    Also, you're assuming wheel is dead center in the wheel well, but that's based on how your alignment is done.
  3. May 31, 2019 at 5:54 AM
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    I would guess the bushings 'squish' enough that the wheel will move back and forth slightly enough to make a difference. I don't know :notsure:
  4. May 31, 2019 at 6:23 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    You wheel is in the same position relative to the wheel well opening regardless of direction
  5. May 31, 2019 at 6:26 AM
    15whtrd
    15whtrd Mr. Blonde
    I always found that strange myself. I can only assume that things must flex at all the pivot points and bushings depending whether it’s forward or reverse.
    Marty McFly and NewImprovedRon like this.
  6. May 31, 2019 at 6:30 AM
    Ditto.
    I think your turning your wheels more in reverse like backing into a parking space or something like that. When your driving foward you really don't cut your wheels that much........just a thought.:notsure:
    15whtrd[QUOTED] likes this.
  7. May 31, 2019 at 7:02 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    That seems more likely then any other reason I've seen so far?
  8. May 31, 2019 at 7:05 AM
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    Its funny cause my wheels run only when I reverse turning the wheel left I cant seem to find the issue
  9. May 31, 2019 at 7:10 AM
    sdde4n
    sdde4n New Member
    Best test I've done is turning hard and then putting in reverse and stepping on it a bit. Mine rubs there a tad, but not really at any other time. The physics is what it is, ears don't lie.
  10. May 31, 2019 at 7:12 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    You must be young if you believe that! lol
    Tundyfundy and Tracy Perry like this.
  11. May 31, 2019 at 7:17 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    4WD can sometimes cause rubbing in the front as well when it doesn't in 2WD.
    JoshuaA likes this.
  12. May 31, 2019 at 7:18 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    It's all to do with the suspension. Since you're reversing, the front of the truck dips down, which would mean you're compressing the front suspension, which would put the widest part of the tire closer to cab mount/bumper/etc, which is where you're rubbing. When you accelerate, the back of the truck dips down, which means the front lifts up causing the suspension to droop, pulling you farther away from the rubbing points.
    That's my guess...
  13. May 31, 2019 at 7:19 AM
    sdde4n
    sdde4n New Member
    I am, except for the grey beard.
    KnuckleHD likes this.
  14. May 31, 2019 at 7:21 AM
    sdde4n
    sdde4n New Member
    Thank you. You took what I meant to say and made it sound all smart-like.
  15. May 31, 2019 at 7:27 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    I get that but and for normal driving, I could see that but here's my hesitation on excepting that as the complete answer...
    If I was checking tire fitment, I would turn the wheel fully to both directions and try going both forward and reverse to check for clearance but I would be doing that very slowly which would not induce the compression you are referring to. Even during normal driving, I very rarely back up fast enough to cause a noticeable amount of weight transfer or suspension compression but maybe that's just me?
  16. May 31, 2019 at 7:53 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Exactly what Ron just pointed out!!
    NewImprovedRon likes this.
  17. May 31, 2019 at 8:11 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  18. May 31, 2019 at 8:13 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I get this, along with rubbing if I reverse on a decline. But no rubbing forward or reverse full turn on level ground in 2WD.
  19. May 31, 2019 at 9:15 AM
    15whtrd
    15whtrd Mr. Blonde
  20. May 31, 2019 at 10:28 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    I'm sure you're sincere, but I really can't tell if the answers here are serious or not :notsure:
    No.
    No.
    Yes.
    KnuckleHD and 15whtrd like this.
  21. May 31, 2019 at 10:34 AM
    NewImprovedRon, 15whtrd and Trooper2 like this.
  22. May 31, 2019 at 10:57 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Dont ask me to quote the source but I recall the conclusion, and the test used to draw it.
    Conclusion: your suspension flexes more (horizontally to the ground) in one direction than the other due to forces applied in either. Its not just weight transfer, but also drag on the ground by the tire and engine power applying in different directions thru the drivetrain.
    Test used: on a flat surface, after having pulled forward a few yards, put your foot firmly on the brake and put the truck in park. Have a friend take a long piece of painters tape and connect your fender, thru the hub of the wheel, down to the ground. With your foot still on the brake, put it in reverse. Now have your friend look at the tape. They'll see it torqued between the fender and hub, but not from the hub to the ground. There's your "flex". Can repeat the same thing in opposite order (meaning start the test from having stopped after reversing a few yards, then put in drive and check). And you can accentuate this affect by repeating the test on an incline in the direction you're testing (aka if you're testing the reverse movement, do this on an incline where the nose is higher than the tailgate. This essentially replicates the resistance to roll the tires have upon initial brake release.)
    Again I can't remember the source but I definitely remember thinking the test was sound and seeing the visual evidence. And I did read it on the internet so it must be true.
    Edit: cleaned up the test description, or at least what I remember of it.
  23. May 31, 2019 at 11:08 AM
    War Machine
    War Machine SSEM # 5 3MW
    Your truck moves faster going forward than it will in reverse. The body of the truck is able to stay ahead and keep pace with the wheels when going forward. That’s because it’s more aerodynamic in that direction.
    When in reverse, the truck falls behind a little, as there is more wind resistance. Since a wheel is a circle, it is equally aerodynamic when moving both forward or backward. It’s speed is the same regardless of direction, so the truck can’t stay ahead due to it not having the same advantage.
    So, you get the tire bumping the truck. Which is the way he wants it. Well, he gets it. I don’t like it anymore than you men.
  24. May 31, 2019 at 11:19 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Cement[QUOTED] likes this.
