Tire wear.
Discussion in 'Wheels & Tires' started by Aaron1977, May 30, 2019.
  1. May 30, 2019 at 3:34 PM
    Aaron1977
    Aaron1977 [OP] New Member
    Aaron
    Littleton Colorado
    2012 Tundra Crew Max
    6" Rough country lift 35" tires
    I bought my truck last November. It's a 2012 crew max. The rear tires are wearing on the inside edge. If you look from the back the tires tilt in. What could be causing this?
  2. May 30, 2019 at 3:48 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Tire pressure, out of balance, bad alignment, etc.. Welcome from Ventura California
    Aaron1977[OP] likes this.
  3. May 30, 2019 at 4:02 PM
    Aaron1977
    Aaron
    Littleton Colorado
    The tires only have 3000 miles on the and I heard that you can not align a solid axle.
  4. May 30, 2019 at 4:07 PM
    Anything on the Carfax for your Tunny indicating a possible rear ender at some point?
  5. May 30, 2019 at 4:12 PM
    Aaron1977
    Aaron
    Littleton Colorado
    I was also told that if there is a bent axle I would have vibration and I do not have that. So I do not know what is causing the problem
    Black Wolf likes this.
  6. May 30, 2019 at 4:13 PM
    Aaron1977
    Aaron
    Littleton Colorado
    I will have to reread it but I do not recall anything. Only one minor accident on front end.
  7. May 30, 2019 at 4:13 PM
    saybng
    Gary
    Ventura CA
    :worthless:
    Black Wolf and Aaron1977[OP] like this.
  8. May 30, 2019 at 4:15 PM
    You may not have a bent axle but the differential/springs geometry might be skewed.
    15Yota and Aaron1977[QUOTED][OP] like this.
  9. May 30, 2019 at 4:16 PM
    Aaron1977
    Aaron
    Littleton Colorado
    I will try to get a picture of it
    15Yota and Black Wolf like this.
  10. May 30, 2019 at 4:27 PM
    Aaron1977
    Aaron
    Littleton Colorado
  11. May 30, 2019 at 4:36 PM
    Same here. Scratching my head now.....hmmm...
  12. May 30, 2019 at 4:39 PM
    Aaron1977
    Aaron
    Littleton Colorado
    I will give that a try and let you know.
  13. May 30, 2019 at 4:44 PM
    This^^^^:thumbsup:
