Headers for 2018 Tundra crewmax
Discussion in '2.5 Gen Tundras (2014-2021)' started by BE Tundra, May 28, 2019.
  1. May 28, 2019 at 7:28 PM
    BE Tundra
    BE Tundra [OP] New Member
    2020 TRD PRO CM super white
    Just curious if anyone knows of good headers for a 2018 Tundra 5.7? Is there headers you can buy that will bolt up to existing exhaust, or will you need to purchase other parts? Any info would be greatly appreciated, thank you.
  2. May 29, 2019 at 9:23 AM
    showtime240
    showtime240 New Member
    ARH or JBA Ceramic SS would be the 2 best options.
    ARH comes with Midpipes but are almost $1800
    The JBA would need midpipes depending on which cats you wanted to keep or eliminate.
    You can eliminate the rear two cats if wanted without throwing a code. If you eliminate all 4 cats, then get DAP tuned to get rid of the check engine light.
    I would suggest 3 inch exhaust for either. you dont want to get headers and then have the bottleneck exhaust.
