Air bags for load leveling.
Discussion in '1st Gen Tundras (2000-2006)' started by STONEFLY, May 2, 2019.
  1. May 2, 2019 at 11:28 AM
    STONEFLY
    STONEFLY [OP] New Member
    Bob
    2003 Gold Tundra TRD
    Any recommendations for air bags for my 2003 Tundra Access cab. I want to be able to level it while hauling a camper or trailer. Thanks!
  2. May 2, 2019 at 11:32 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO. A lot of good info on airbags in the search function.
  3. May 2, 2019 at 11:45 AM
    Welcome from NY.
  4. May 2, 2019 at 11:46 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    What @BTBAKER said but i'll make it easy on ya. Firestone ride rite.
    ldale and landphil like this.
  5. May 2, 2019 at 12:23 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Yea, that’s what I’m running. Happy so far. Airlift seems popular as well.
  6. May 2, 2019 at 12:28 PM
    monaco730
    16 Inferno Tundra
    Same. With daystars. Love em.
    BTBAKER[QUOTED] likes this.
  7. May 2, 2019 at 4:40 PM
    Aerindel
    Aerindel New Member
    Montana
    I run airlift, purchased from Amazon. I like them.
    BTBAKER likes this.
  8. May 2, 2019 at 5:09 PM
    Cacoleman2014
    Cacoleman2014 New Member
    Louisiana
    2006 Tundra SR5 double cab
    How much did it raise from factory, if any when at minimum air?
  9. May 2, 2019 at 5:35 PM
    Aerindel
    Aerindel New Member
    Montana
    No noticeable lift at minimum air. A couple inches at 50PSI with no load. I have not tried them at their max PSI. They can only provide lift by canceling out the empty weight of your truck bed, which is just a few hundred pounds. Your stock suspension is already designed to do this. After that they are working AGAINST your springs to provide further lift so they very quickly reach the point of diminishing returns in that regard and also result in a rock hard rear suspension.
    But they are not intended to provide lift. The point is to maintain normal handling and ride height with a load.
  10. May 2, 2019 at 6:15 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I actually obtained a little over half an inch lift at 8psi on both sides
  11. May 2, 2019 at 6:16 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Are those the cradles?
    monaco730[QUOTED] likes this.
  12. May 2, 2019 at 6:34 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    So last weekend I put on the air lift 5000 kit. Great kit, easy install. However, I didn’t want to mount the bottom of the bag. It would limit the droop/articulation. So I put the daystar cradles in. They’re great. Bad thing is, the airlift bags have built in bump stops. At the time I thought “ cool”. Nope. Small bumps bottom out and hit the bump stops making a semi harsh hit. Granted, if I didn’t use the daystar cradles, probably wouldn’t have this issue, but again, don’t want to limit droop. Daystars are about 1 1/8” thick.
    So, just got some generic bags in today that collapse small, no internal bump stop. We’ll see how that works now that I already have brackets.
    Let you guys know Saturday evening.
  13. May 3, 2019 at 7:03 AM
    Cacoleman2014
    Louisiana
    Just wondering if I was going to need to raise the front a little bit. Getting them for my camper and I pull a 7 yard dump trailer at work sometime and it's kinda tounge heavy
  14. May 3, 2019 at 7:25 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I had them on my T100 that was used to haul bulk bottled water, they worked great. I have a kit that I purchased for my '02, but never installed it because the company that private labeled my bottled water went out of business. I have them on my '07 to keep the bed & drive shaft from making contact, they work great.
  15. May 3, 2019 at 9:23 AM
    Cacoleman2014
    Louisiana
    I blew out my center support pulling my camper bc of the angle it put the driveshaft in Definitely have to find a solution and get that spicer center support..
  16. May 5, 2019 at 4:24 PM
    monaco730
    16 Inferno Tundra
    Yes
  17. May 29, 2019 at 7:56 AM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
