  1. May 28, 2019 at 8:49 AM
    #7261
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    FirstGenVol likes this.
  2. May 28, 2019 at 10:39 AM
    #7262
    speedtre
    speedtre New Member
    Inland Northwest
  3. May 28, 2019 at 11:09 AM
    #7263
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    replaced all of the fluids this weekend.
    abcinv, NUDRAT, Hooptytrix and 5 others like this.
  4. May 28, 2019 at 12:36 PM
    #7264
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
  5. May 28, 2019 at 12:47 PM
    #7265
    simonmiles
    simonmiles New Member
    I actually bought a set but haven't had a chance to install them yet. They appear to be high quality and well made. I hope to get them on this weekend along with some other front suspension work. I do have a promo code that will save you close to $10 if you decide to purchase.
  6. May 28, 2019 at 4:01 PM
    #7266
    Casper421
    In the woods
    06 DC
    Please share said code.
    Hooptytrix likes this.
  7. May 28, 2019 at 4:18 PM
    #7267
    simonmiles
    You enter the code during the checkout. It is "maxx10" without the quotes.
  8. May 28, 2019 at 4:42 PM
    #7268
    Casper421
    In the woods
    06 DC
    Thank you sir.
  9. May 28, 2019 at 5:03 PM
    #7269
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    Today, I ordered Camburg UCAs and a custom pack from Deaver. I get paid Thursday and will probably be ordering the Icon CO's and rears. Stage 1 I guess you could say.
    For those with Icon 2.5 CO's, did you shim the one side or did you just crank down the preload to compensate? I'd rather shim because I don't want each side preloaded differently. Also, I plan to run 295/75/16’s on SCS Ray10's with 4" BS -12 Offset. I am assuming I'll have to cut/trim/smash to some degree.
  10. May 28, 2019 at 5:04 PM
    #7270
    simonmiles
    My pleasure good sir.
    Casper421[QUOTED] likes this.
  11. May 28, 2019 at 5:13 PM
    #7271
    Casper421
    In the woods
    06 DC
    Good choices. I added a shim on the drivers side from @Coachbuilder1. David recommended 2 on drivers and 1 on passenger. I might throw in the other two instead of cranking up another 1/2”.
  12. May 28, 2019 at 5:18 PM
    #7272
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    What size tire and wheel combo as well as actually amount of lift are you running? I am excited. I have been spraying the shit out of everything with PB Blaster for the last 2 weeks every couple of days.
  13. May 28, 2019 at 5:23 PM
    #7273
    Casper421
    In the woods
    06 DC
    285/75 on 17x8.5 4.30” bs -10mm. I forgot to take measurements but I’m probably about 2.25-2.5” in the front.
    MDobb79[QUOTED] likes this.
  14. May 28, 2019 at 5:26 PM
    #7274
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    I am looking to go 3.5" front 1.5" rear.
  15. May 28, 2019 at 5:31 PM
    #7275
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    So tempting to just pull the trigger now hoping they'll be here for install this weekend....
  16. May 28, 2019 at 5:33 PM
    #7276
    It's cheaper if you order the front and rear separately. I just ordered both last month.
    PM me if you want details.
  17. May 28, 2019 at 5:55 PM
    #7277
    Professional Hand Model
    Fred
    Hand Protectors
    You guys have high dolla taste in shocks. I guess its not too bad as the Icons come with springs as well. Probably my next move in 5 years time. $1 a day saved from here out and they’ll be paid off.
  18. May 28, 2019 at 5:57 PM
    #7278
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    Thanks for the offer but I got antsy and pulled the trigger. Icons on the way as well as everything else. Plus beers have been consumed so that is always a good lubricant....
    Filthyphil likes this.
  19. May 28, 2019 at 6:12 PM
    #7279
    It was a really hard decision for me to spend that much money on coilovers. I changed my mind 10 times. I'll soon know if they are worth it.
    Rheywood456 and MDobb79 like this.
  20. May 28, 2019 at 6:13 PM
    #7280
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Eh. My tacos on its second set of coil overs. Totally worth it, the ride is very good
    MDobb79 likes this.
  21. May 28, 2019 at 6:27 PM
    #7281
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    I know they're great. I have a few friends with tacos, 4runners and Tundras that run them and they swear by them. I was going to go with Fox but I saw a few posts, more specifically something @Casper421 said that made me make up my mind.
    Rheywood456 likes this.
  22. May 28, 2019 at 6:36 PM
    #7282
    Hooptytrix
    Dirty South
    I was thinking the same thing but then I remembered I spent $1,500 on coilovers for S2000 a few years ago. I guess I'll keep my mouth shut :spending:
    Rheywood456, bmf4069 and MDobb79 like this.
  23. May 28, 2019 at 7:04 PM
    #7283
    empty_lord
    05 rollover special
    Around here the Fox coil overs seem to fair the worst in the winter. None of the coil overs do great in winter with the road salt, but my buddies that run them have pretty severe rust in the shafts within 2 years
  24. May 28, 2019 at 8:09 PM
    #7284
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I think most people preload when that option is there. Why spend more money?
    I also have 295s and had to trim. Instead of hammering the pinch weld, my buddy at Trail Toys cut a section out of it.
  25. May 28, 2019 at 8:13 PM
    #7285
    because_wumbo-truck
    Jon
    Houston, Texas
    I didn't measure mine and I didn't adjust the preload on my toytec boss CO's, but I'd guess I gained about 2.5-3 inches in front. I did the wheelers progressive AAL with the stock overload removed from the stock leaf pack for 1.5 inches. My truck looks like it's perfectly level. 3.5 in front might make you nose high. But if you keep the stock overload then I would think it should be fine. Also with that much front lift you may want new UCAs and a diff drop.
  26. May 28, 2019 at 8:39 PM
    #7286
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    You may have missed all my posts but I ordered Camburg UCAs. Diff drop to come as well as new LBJs and extended brake lines.
  27. May 28, 2019 at 9:43 PM
    #7287
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah I didn't read lol
  28. May 29, 2019 at 4:20 AM
    #7288
    speedtre
    speedtre New Member
    Inland Northwest
    Welcome to the club....I traded my 2017 Tacoma for my 2006 1-owner grandpa special (ie lightly used and we'll maintained with records) a few months ago. Overpaid a bit for it's "uniqueness" but I couldn't be happier. The only thing I miss is the backup camera and that can be rectified. :thumbsup:
  29. May 29, 2019 at 4:51 AM
    #7289
    because_wumbo-truck
    Jon
    Houston, Texas
    You, my friend, are a god among men. I really don't understand the appeal of the turd gen tacos lol. You made a great choice. I loved my two first.gen tacos, but I really really love my tundra.
    speedtre[QUOTED] likes this.
  30. May 29, 2019 at 6:45 AM
    #7290
    andrew8404
    andrew8404 New Member
    Andrew
    Yup, I was so sick of the transmission flaring up to 3-4000 rpm for no reason and only to be told that’s normal. There’s nothing I really miss about that truck except the overall sleekness of it. Otherwise the Tundra is way more comfortable and has an engine/transmission that actually works!! And yes the backup camera is a must for this truck! 279 for a car play radio and a 30 dollar Amazon backup camera made this truck very modern ha ha.
    Your lucky with the grandpa truck! Mine had four previous owners. But seemed fairly clean so I couldnt pass it up. It was also expensive 15k for 98000 miles but they worked with me and gave me a fair price on the 2017 Tacoma.
