What is this??
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shephard_Of_The_Tundra, May 27, 2019.
  1. May 27, 2019 at 7:18 PM
    Shephard_Of_The_Tundra [OP] DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    So was wiring my tow mirror spotlights earlier, and when I opened the dash panel on the drivers side floor. I noticed this big red wire spliced onto the 12v wire I was going to splice into...anyone know what it's for? Couldn't seem to find other tundras with it...
  2. May 27, 2019 at 7:19 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Hidden camera. :spy:
  3. May 27, 2019 at 7:24 PM
    Doesn't look like it's spliced
  4. May 27, 2019 at 7:26 PM
    Corpus Christi, TX
    The red wire is T-tapped onto the dark brown wire...this is the first time I opened this part of my truck and I bought it new with 20 miles on the clock...
  5. May 27, 2019 at 7:26 PM
    Corpus Christi, TX
    Hell...it does have some black egg shaped device attached to it...microphone maybe
    Sas[QUOTED] likes this.
  6. May 27, 2019 at 7:28 PM
    Take it back to where you bought it and say.........."What the f:censored:K is this????
  7. May 27, 2019 at 7:30 PM
    Corpus Christi, TX
    I'm sure they'll say I did it...then try to sell me on fixing it/removing it..then get home $500 later and realize the never removed it.
    TheBeast and Black Wolf[QUOTED] like this.
  8. May 27, 2019 at 7:39 PM
    I myself would personally go back and ask "What is this?" "I didn't put this here, please explain what this is." I don't take dealer BS for an answer.
  9. May 27, 2019 at 7:42 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Cut the wire and see what quits working :notsure:
  10. May 27, 2019 at 7:50 PM
  11. May 27, 2019 at 7:53 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Didn't someone post on here about GPS trackers that dealerships were putting on in case they had to repo the vehicle?
    Myhobbes25 and Black Wolf like this.
  12. May 27, 2019 at 7:55 PM
    Trooper2
    JR
    There was some talk about that a while back.
  13. May 27, 2019 at 8:00 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I think it was a term and condition of the loans, etc.
    Craziness.
  14. May 27, 2019 at 8:01 PM
    At least Toyota can locate vehicle if stolen though.
  15. May 27, 2019 at 8:35 PM
    Corpus Christi, TX
    I think I'm going nuclear...I'll unplug the tap and well see...keep you guys posted
  16. May 27, 2019 at 8:35 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    It looks like it has an inline fuse attached to it as well. Do you have any aftermarket items added by the dealer? My first guess would be LED bed lights, followed by tailgate actuator (pop and lock, etc). Anything on your truck that’s not considered “standard”?
    mountainpete likes this.
  17. May 27, 2019 at 8:53 PM
    Corpus Christi, TX
    I do have LED bed lights. Was told it was from the factory...I was watching that YouTube video from trail ridge on installing tow mirrors and they're tundra did not have that red wire tapped into this brown wire. Which in the video they claimed the brown wire was for the bed lights.
  18. May 27, 2019 at 8:57 PM
    KnuckleHD
    They can be added by the dealer. Pretty common actually. I’m about 99% sure that’s the power to your bed lights.
  19. May 27, 2019 at 8:58 PM
    Corpus Christi, TX
    I'm thinking so too now that you brought it up. Will definetly check tomorrow, I knew you guys would figure it out.
    Appreciate the feedback so quickly!
  20. May 27, 2019 at 8:58 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Pull the fuse and see if the bed lights still work.
    Black Wolf, Bprose and TheBeast like this.
  21. May 27, 2019 at 9:02 PM
    KnuckleHD
  22. May 27, 2019 at 9:19 PM
    TheBeast
    TheBeast The Beach
    KnuckleHD[QUOTED] likes this.
  23. May 28, 2019 at 4:00 AM
    MotoTundra
    MotoTundra The Ocho
    Don
  24. May 28, 2019 at 4:04 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I have the same T tap on my TSS model with dealer added bed lights.
    KnuckleHD and Black Wolf like this.
  25. May 28, 2019 at 5:20 AM
  26. May 28, 2019 at 5:21 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Where does it end up??
  27. May 28, 2019 at 5:46 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    That brown wire is for the cargo lights. That's where it is tapped for the bed lights. So if you have bed lights, that's where it's getting it's power. Step #27 in the link in my signature.
    It is the same diagram from the PDF that @KnuckleHD posted.
    CaptSpaulding likes this.
  28. May 28, 2019 at 5:52 AM
  29. May 28, 2019 at 5:55 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    It goes over to a grommet in the passenger floor board, down the factory harness to the lights in the back of the bed.
  30. May 28, 2019 at 8:14 PM
    Corpus Christi, TX
