New member
Discussion in 'New Member Introductions' started by Echo304, May 26, 2019.
  1. May 26, 2019 at 9:10 PM
    Echo304
    Echo304 [OP] New Member
    Josh
    2010 Crew Cab/6.5' Bed
    Hey yall! I'm Josh, new here but not so new with this truck. I have a 2010 Tundra and I'm here because I'm looking to keep him running as long as possible! My dad bought the truck new in 2010, and I bought it from him when my last car became... worrisome... in June of last year (2018). He treated the truck decently, but doesnt do nearly as much preventative maintenance as I do (and as I said earlier, I'd like to keep this truck as long as possible). I'm not a Tundra fan boy (because no truck is perfect), but I do love this truck... because I grew up (sorta) in it. In case any of yall name your vehicles, I named it "Tucker" (props if you know where that's from) in 2010.
    Edit: Should mention, I am an unconventional person when it comes to getting the job done. MacGyver'ing is my style, and my obsession with 3d printing only serves to fuel that.
    • Model: 2010 Tundra
    • Grade: TUNDRA GRD
    • Exterior: Spruce Mica(6V4)
    • Interior: Graphite
    • Engine: 8-CYL
    • Body Type: Extended
    • Driver Type: 4WD
    • Transmission: 6AT
    • Order date: 01/2010
    • Body Style: DBL CAB 5.7L V8
    • CK Cold Weather Package
    • EV AM/FM/MP3 CD
      • 6 Speakers
      • Bluetooth
      • Steering Wheel Audio Controls
      • Aux/USB Input
    • FE 50 State Emissions
    • HM Power Heated Outside Mirrors
    • LU Bedliner w/out Deck Rail System
    • OF TRD OffRoad Package
      • Off-road-tuned Suspension
      • Bilstein Shocks
    • Unique 18" Alloy Wheels
    • Fog Lamps
    • Fuel Tank Skid Plate
    • SR5 Badging
    • TRD Offroad Package Graphics
    • Tow Package
    • PE Cloth Bucket Seats
      • Power 8-way Adjustable Driver-Side
      • 4 Way Manually Adjustable Passenger Side
      • Adjustable Headrests
      • Tilt/Telescoping Steering Wheel
      • Center Console with Laptop and File Storage
    • RB Brushed Stainless Steel Stepboard Port
    STANDARD INSTALLATION EQUIPMENT
    Mechanical & Performance
    5.7L iFORCE V8 DOHC 32V Dual Independent
    VVT-i 381HP/401 lb-ft and ACIS 6-Spd
    Automatic Trans w/Sequential Shift 4WDemand
    4x4 System w/Electronically Controlled 2 Speed
    Transfer Case GVWR = 7100 lbs. Payload =
    1640 lbs. Max Tow Cap = 8300 lbs. Engine
    Immobilizer, Cruise Control TripleTech Frame:
    Fully-boxed Fr Section Reinforced C Under Cab,
    Open C Under Bed 4.10 Rear Differential w/10.5"
    Ring Gear Automatic Limited Slip Diff (Auto LSD)
    Coil Over Shock Double A-Arm Front Susp Multi-
    Leaf Trapezoidal Rear Suspension Pwr 4 Wheel
    Disc Brakes, 13.9" Fr Rotors 18" Steel w/
    P255/70R18
    Safety
    STAR Safety System: 4 Wheel ABS w/ Electronic
    Brake-force Distribution (EBD), Brake Assist, and
    Vehicle Stability Control with Active Traction
    Control (VSC+ATRAC) Dr & Fr Pass Advanced
    Airbag System Dr & Fr Pass Seat Side Airbags Dr
    & Fr Pass Knee Airbags Roll-Sensing Curtain
    Airbags (RSCA) Dr & Fr Pass 3pt Seatbelts w/
    Pretensioners & Force Limiters Tire Pressure
    Monitoring System
    Exterior
    6.5' Double-Walled Bed w/Tailgate Assist Front
    Tow Hook, Engine Skid Plate
    Interior
    40/20/40 Fr Bench w/Center 3pt Seatbelts Dual
    Zone Climate Control w/Sync Mode AM/FM/MP3/
    CD w/6 Speakers & Aux Input Tilt Steering Wheel
    Power Windows/Door Locks/Mirrors Cloth
    Trimmed Seats Remote Keyless Entry System
    Variable Intermittent Windshield Wipers Manual
    Headlamp Adjust
    Prostar 190, Migraine, Pinay and 3 others like this.
  2. May 26, 2019 at 9:11 PM
    Welcome from Texas, appreciate your service, SEMPER FI BROTHER!
    Echo304[OP] likes this.
  3. May 26, 2019 at 9:11 PM
    Welcome from NY.
    Pinay and Echo304[OP] like this.
  4. May 26, 2019 at 9:12 PM
    Another Semper Fi! Welcome from Colorado.
  5. May 26, 2019 at 9:24 PM
    Echo304
    Josh
    @Grey Wolf @ARamirez73 - Rah Devils!
    @Jim LE 1301 - Fellow New Yorker here! Well, at least at heart anyway. Work's got me elsewhere... and will for a while, sadly.
    Question I forgot in the original post: If I'm looking for advice, specifically about my truck, and wouldn't also mind keeping a log of what I do (with pic's obviously). Should I just post in the general 2nd Gen forum, or should I do a build thread?
    Pinay likes this.
  6. May 26, 2019 at 9:32 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Welcome from Cypress, Tx!
  7. May 26, 2019 at 9:40 PM
    What part of NY?
    Do a build thread for all your work/mods.
    Post your questions in the 2nd gen forum.
    Pinay and Echo304[QUOTED][OP] like this.
  8. May 26, 2019 at 9:42 PM
    Echo304
    Josh
    Albany area! So real close, well when I was in the area! Thanks for the advice on the forum posting!
    Pinay and Jim LE 1301[QUOTED] like this.
  9. May 26, 2019 at 9:49 PM
    :thumbsup:
    I'm 1 hour south of Albany down the TSP.
    Thanks for your service. I almost joined the USMC but the PD called me. I sometimes regret not going, I wanted to fly helicopters.:(
  10. May 26, 2019 at 9:51 PM
    Josh,
    Quick question...
    Do you know if the Marines on the USS New York wear red baseball hats with the ships logo. The Navy guys wear the black version.
  11. May 26, 2019 at 10:03 PM
    Echo304
    Josh
    I couldnt personally tell you about them, as I haven't been stationed on ship yet... but from my experience it tends to be a Navy Surface Warfare community thing to wear ship logo'd hats (though apparently all Navy personnel assigned to a ship rate the ability to wear one). Also, I just searched MCO 1020.34H (current uniform regulations), and there isn't any mention of wearing a ship's ballcap in uniform. So i'd lean towards no. But again, take what I say there with a grain of salt! (mind you this is all in uniform, if not in uniform I wouldnt see why they couldnt/wouldnt)
    Pinay likes this.
  12. May 26, 2019 at 10:08 PM
    Thanks.
    I remember years ago I saw the same ship's hats and one was red and one was black and I was told the Marines wore the red ones. I wanted to get one of that ship.
  13. May 27, 2019 at 1:12 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hi and welcome from SoCal!!!
  14. May 27, 2019 at 3:52 AM
    Welcome from Ohio
  15. May 27, 2019 at 4:07 AM
    88nitro305
    88nitro305 New Member
    Tom
    2015 Tundra CrewMax TRD Off-Road
    Welcome from VT! Thank you for being a protector of our freedoms and democracy :oldglory::cheers:
  16. May 27, 2019 at 4:51 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
  17. May 27, 2019 at 5:59 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
  18. May 27, 2019 at 7:07 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  19. May 27, 2019 at 7:34 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Welcome from NC
  20. May 27, 2019 at 4:36 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  21. May 27, 2019 at 5:38 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  22. May 27, 2019 at 5:49 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome!
  23. May 28, 2019 at 3:56 AM
    EZO
    EZO New Member
    2005 Tundra
    Welcome from Asheville NC
  24. May 28, 2019 at 4:01 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Welcome from the Wilkes-Barre Scranton area
  25. May 28, 2019 at 7:10 AM
    Cthulhu
    Welcome from SC!! Thank you for your service!!
