What to look for when buying a used Tundra.
Discussion in '2nd Gen Tundras (2007-2013)' started by woopud, May 25, 2019.
  1. May 25, 2019 at 12:01 PM
    woopud
    woopud [OP] New Member
    Bert
    Hi All,
    I do not own a Tundra currently but my next truck will be one! I see a lot of stories about Tundra's and how long they'll last, when I'm ready to buy one it will be a 2007 -2013 model. What are things I'll have to look for when buying one? i do all my owwn maintenance on my truck, my old Silverado I drove up to 275,000 miles, it was all original no rebuild engine or transmission. My current F150 is closing in at 200,000 miles, also all original.
    TokerJoker likes this.
  2. May 25, 2019 at 12:03 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    :worthless:
    I kid!
    Cam tower leaks.
    The right options for what you are seeking.
    Consider the 5.7 or 4.6 for your needs.
    2x4 or 4x4.
  3. May 25, 2019 at 12:34 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Pull a CarFax report.
    Inspect for frame rust.
    Take it on an extended test drive on different road surfaces.
    Maybe visit your local tire shop, and have them lift & inspect it.
    Turn the radio OFF while you are driving so you can hear everything.
    I rolled the dice on my '07 when I purchased it 09/2017 with 270k on it, because there was no service history... my extended test drive and a look underneath told me all I needed to know. It has 285k on it now, and I love driving it.
    Good luck with your search!
  4. May 25, 2019 at 1:08 PM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    As already mentioned, visually inspect cam towers. You can see the problem area, or the signs of an issue by looking from the front wheel well. There are better explanations that you can find here with a quick search.
    And i guess check for rust damage on the frame. Though, that shouldnt really be a problem since Toyota offered to take care of it but you never know.
    Cant really think of anything else that was abnormal with the tundras. The price on a used tundra can be discouraging at first but totally worth it. They hold their value like champs.
    Hope you find one you like!
  5. May 26, 2019 at 5:38 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Check for bed rust.
    TheBeast likes this.
  6. May 26, 2019 at 6:16 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Check for evidence of flood damage. The United States has had an incredible amount of flooding in the last two years.
  7. May 26, 2019 at 11:06 AM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    don't forget the secondary air pump if it has been blocked off of replaced already or original. lots of info on here about limp mode in the second gens.
  8. May 26, 2019 at 11:52 AM
    TheBeast
    TheBeast The Beach
    all good advices.
    rust, cam tower leak ,AIP are the big ones.
    rust especially under a plastic bed liner. you wont see it until you lift it.
  9. May 26, 2019 at 11:53 AM
    TheBeast
    TheBeast The Beach
    4x4, 5.7L and crewmax have the best resale value imo so a used one will probably be a bit more than a 2WD DC
  10. May 26, 2019 at 1:40 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from Tx!
    Some 2007's have the 4.7L which has the timing belt, costly maintenance item.
    many recommend the 5.7 in leu of the 4.6 or 4.7
