Aftermarket lug nuts?
Discussion in 'Wheels & Tires' started by 2015_Nova_Taco, May 25, 2019.
  1. May 25, 2019 at 10:36 AM
    2015_Nova_Taco
    2015_Nova_Taco [OP] New Member
    I have the usual Toyota problem. Lug nuts swelled up a little and the socket wrench rounded them off.
    Had this issue on the wife's Sienna too.
    Anyhow, anyone recommend an aftermarket lug nut? I bought a couple at the dealer and they were $16/each.
    There has to be a better option.
    Thanks.
  2. May 25, 2019 at 11:22 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
  3. May 26, 2019 at 10:21 AM
    2015_Nova_Taco
    Thanks @birdman076 but isn't there anything off the shelf that I could just buy at the Autozone or something. These are stock wheels, I just don't wanna be trapped if I have to pull a wheel on the road after some hammer head over torques them.
  4. May 26, 2019 at 10:28 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  5. May 26, 2019 at 10:52 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    I had the same problem recently and got a set of solid OEM replacements from wheel adapters USA, $35ish. I doubt that you'll find a set of ET style lugs on the shelf at any of the chain auto parts stores.
  6. May 26, 2019 at 11:52 AM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    I got a set of anodized ones off ebay for about $25. You need what will specifically work on the wheels you are using. Stock lugnuts will not work on aftermarket wheels.
    Pinay likes this.
