Front end leveling kit
Discussion in 'Suspension' started by Farmallbn, May 25, 2019.
  1. May 25, 2019 at 6:43 PM
    Farmallbn
    Farmallbn [OP] Speechless!
    Bradford county, PA
    2016 tundra TRD off road Blue
    Hey guys, I know the question has been asked numerous times, but please help me again on this issue. So I love my tundra to no end. But as I see in here there are numerous ways to level out the front end. I just really want something that will do the job without breaking the bank. 2 kids and a mortgage will do that. Lol can someone give me the name and parts I would get to level it out and not break the bank. I wasnt sure if I could just do a spacer and call it good, or do I need to get different shocks and go from there. The only thing that worries me, is i will be pulling a 9000 lb camper with it as well. I was wondering if i could get it done with a couple hundred bucks and still be ok. Please let me know. The truck is awesome, but would love for it to sit up in front. I can do the work, but as i have saw and read there is so many options, i am just unsure of what to get.
    Thanks.
  2. May 25, 2019 at 6:45 PM
    Blueknights75
    Ron
    Clayton, NC
  3. May 25, 2019 at 6:49 PM
    Farmallbn
    Bradford county, PA
    Thanks. Anything particular I should look at. Or stay away from..
  4. May 25, 2019 at 7:44 PM
    Blueknights75
    Ron
    Clayton, NC
    It all depends how you use the truck. If you don’t plan on off roading then a spacer kit is fine. However if you do plan off roading a little then you may want to try the Billstein 5100 shocks...but @Toytec Lifts will definitely provide you the lift you need at a very reasonable price. They will not try to sell you something you don’t need.
  5. May 25, 2019 at 7:47 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    For about $800 I would just go with the Bilstien 6100 coilovers set at 1.9" and call it good. No spacers on my truck. Here is what I tow. 5000 lbs
    Rex Kramer likes this.
  6. May 25, 2019 at 7:51 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    That’s my setup. Towing 7500 pounds.
  7. May 25, 2019 at 8:10 PM
    Farmallbn
    Bradford county, PA
    Did you guys have to go get it aligned after you did everything? I am just curious.
  8. May 25, 2019 at 8:43 PM
    Blueknights75
    Ron
    Clayton, NC
    Yes
  9. May 25, 2019 at 8:55 PM
    georgiey22
    Yes.
  10. May 26, 2019 at 3:44 AM
    Tundramoney
    Tundramoney Old school
    Earth
  11. May 26, 2019 at 4:17 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    I put on Bilstein 5100s on my 2018 CM, had them set at the middle setting. Perfect if you are not doing anything to the rear right now. I still have 1/2" rake. Had them check my alignment, it was nearly perfect. Have had them for about a year and everything has been great. I think I paid right around $200 for the shocks and $200 for the install.
    Before:
    After:
  12. May 26, 2019 at 4:24 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    So do the 5100s use the existing spring? I know the 6100s come w it...
  13. May 26, 2019 at 4:28 AM
    hitech
    hitech New Member
    Blair
    SOMD
    yes, existing spring.
  14. May 26, 2019 at 4:37 AM
    Farmallbn
    Bradford county, PA
    So where did you get the 5100's . I think that's where I need to go, there really has not been many guys saying to get the spacers. I was shocked.
  15. May 26, 2019 at 4:52 AM
    hitech
    hitech New Member
    Blair
    SOMD
    Amazon.
    I just checked and they are around $250 now, but still not bad for a decent adjustable shock. Any of the vendors on here are also a good place to buy from. I've used ToyTec in the past with good results.
  16. May 26, 2019 at 10:35 AM
    Farmallbn
    Bradford county, PA
    Thanks to everyone that chimed in. I think my best bet is to call toytec.
  17. May 26, 2019 at 6:39 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I did. Toe was a little off. Heck may have been that way before coilover install.
  18. May 26, 2019 at 7:15 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Toytec, Bilstien, Pro Comp, Rancho... On a budget Rancho and Pro Comp for about $300.
  19. Jun 18, 2019 at 7:06 AM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Does changing your suspension affect your warranty?
    georgiey22[QUOTED] likes this.
  20. Jun 18, 2019 at 7:22 AM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    It may. My dealer said if they can trace the defective part being caused by the change in suspension (ball joints etc) Toyota won’t honour the replacement.
