Proper audio upgrade/replacement
Discussion in 'Audio & Video' started by saramos, May 24, 2019.
  1. May 24, 2019 at 10:17 PM
    saramos
    saramos [OP] New Member
    Scott
    2014 Tundra
    Bilstien 6112s 2" rear shackles. LED headlights. Interior wood trim. 798Addict Wheels. Nitto Ridge Grapplers. Tonnaeu Cover, Fenders, Side Steps. 4 camera system
    I have been going through the threads in this forum and am a bit unsure about the proper audio upgrade/replacement path. I have a '14 SR double cab with factory Entune system. I have seen references in the threads about JBL and non JBL systems. Looking online about the equipment installed in my particular vehicle, it does not identify if it is JBL or not. So, here are my questions.
    Are all Entune systems JBL?
    My understanding is that if the system is a JBL, simply upgrading the amp is not really an option. If so, the best path would be looking at a full HU/amp/speaker replacement. Is this correct?
    If not, how do I identify the system as being JBL or non JBL?
    Finally, if it is a non JBL, is an upgrade without an HU replacement a reasonable option?
    Thanks,
  2. May 24, 2019 at 10:24 PM
    JBL is an upgrade. Yes, you can change amps but it’s more than just a simple plug and play.
    You’ll have tags that say JBL on the door panels and the H/U IIRC.
    Non JBL- can upgrade too.
    Best option is to contact @james@tech12volts who can steer you in the right direction.
    Pudge likes this.
  3. May 24, 2019 at 10:34 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    i bought JBL Badges on ebay and adhered them to my speaker grilles. it looks like it sounds much better now
  4. May 24, 2019 at 10:35 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Not all entune are JBL. You could do a VIN search but as far as I know all JBL systems say JBL on the headunit or even speaker grills, definitely on the back if the speakers themselves. I highly doubt the SR has JBL. But the JBL sucks anyway and is more difficult to upgrade individual items.
    A proper upgrade should include a new head unit. You wont regret it I promise, but you will regret not doing it to save a few bucks. You'll get CarPlay and/or android auto at the very least and much much more, including superior sound overall. I suggest kenwood but jvc, alpine, pioneer are all very much an upgrade, personally I would stay away from the android / Tesla head units but some guys love them and they do look pretty sweet. An Idatalink maestro RR would make integration a snap between factory wiring and new head unit.
    A 5 channel amp would be ideal, with component speakers in the doors, and a subwoofer or 2 behind the seats. Possibly upgrade dash speakers as well but you could save money by just disconnecting them if you get some good door components.
    James @tech12volts is the only person I would talk to about this or buy from. But there are plenty of online options, steer clear of ********* if you can. Also talk to local installers in your area, your be surprised by the deal you may get.
    Toyotoholic and T-Rex266 like this.
  5. May 24, 2019 at 10:41 PM
    Pudge
    CT
    Technically it should sound worse
    T-Rex266 likes this.
  6. May 24, 2019 at 10:43 PM
    :smokertransformer:
    TRD-tv[QUOTED] likes this.
  7. May 24, 2019 at 11:19 PM
    saramos
    Scott
    2014 Tundra
    Thanks for the replies. But I think I'll skip the badges. We don't need no stinkin' badges...
    Pudge and Trooper2 like this.
  8. May 25, 2019 at 4:27 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    Replacing my head unit made my non JBL speakers sound better. So much better that I dont feel like I need to replace them immediately.
  9. May 25, 2019 at 5:30 AM
    b183
    b183 New Member
    South MS
    2019 Tundra Barcelona Red TSS
    Bed Step, Driver pull Handle, Camlocker LP Toolbox, Bed Rails, Rubber Bed Mat TRD rear sway bar, front camera AVS window deflectors window tint
    Will a new HU affect MPG and tire Pressure Readings in the Instrument cluster readout?
    Tundyfundy and Trooper2 like this.
  10. May 25, 2019 at 6:26 AM
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    MPG no and I didnt have tire pressure monitoring readouts so I can't speak to that.
  11. May 25, 2019 at 7:26 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    It definitely worked for me. No plans on any other changes for now. The stock non JBL HU is like 12 watts of power, Many of the aftermarkets mentioned are 50 watts of power. Audiophile quality? Probably not, but definitely more volume and built in EQ's to play with. You can always upgrade speakers and / or add an amp later.
  12. May 25, 2019 at 7:45 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You are better off without the jbl. Easier to upgrade.
    The main question you should be asking yourself is if you want to keep the factory headunit. After you figure that out. Reach out to tech12volts and give them your budget and what kind of sound you are looking for and James will set you up. I got almost all of my gear from him. Top notch.
  13. May 25, 2019 at 8:30 AM
    Pudge
    CT
    The maestro should integrate everything. Except the turn by turn in the litle center cluster screen
  14. May 27, 2019 at 2:55 PM
    james@tech12volts
    james@tech12volts tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    hey guys if you need to get a hold of me and i do not answer a PM email me as I always get emails. Sometimes I do not get a PM notice for days . tech12volt@gmail.com
  15. Aug 18, 2019 at 10:43 PM
    saramos
    Scott
    2014 Tundra
    Here's a followup. I decided to go with a head unit replacement and chose the Pioneer 7200NEX. It looked like the best balance of price vs performance and options. I also added the Maestro RR and Idatalink harness. I did the install myself and am pretty happy with the results. First, the sound is soo much better than the original HU. Having an eq I can set custom settings is great. Android Auto will come in handy for music (Spotify) on trips or even on the daily. All splices on the harness were soldered and shrink tubing. The GPS was mounted under the center speaker cover as the SR has no center speaker. Mic was mounted at the back of the roof console. I like that the display can be tilted to closely match the angle of the trim and original display. I now have individual tire pressure readouts and code readout if there's something wrong with the truck.
    Biggest issue I have now is the USB/AUX port. I pulled out the factory port and replaced it with one I found online that was supposed to fit Toyota, but must be for other models. I had to modify it to fit where the factory usb/aux port is and it does not clip in well and is easily pulled out. Then it becomes disconnected on the back side requiring me to pull the panel out again.
    Next project I want to do is to be able to integrate the additional cameras I added to the truck. I have 1 in front of each wheel, one in the grill and one mounted to the back axle looking forward. It would be nice to be able to display them on the HU instead of a different display. I see the new 2020 Tacoma TRD PRO will have this as an option. Toyota's implementation looks pretty cool as the cameras will have dynamic guidelines projected. Great for picking a line when off-roading.
    Trooper2 and ManoTundra like this.
  16. Aug 19, 2019 at 5:18 AM
    Trooper2
    JR
    Glad to hear some positive results.
    Now be careful not to destroy the stock speakers! LOL There are some modest upgrades for those as well that would bring more improvements.
  17. Aug 19, 2019 at 9:39 PM
    saramos
    Scott
    2014 Tundra
    Always interested to hear about upgrades.
  18. Aug 20, 2019 at 6:52 AM
    Trooper2
    JR
    I have not replaced my speakers yet; surprisingly the stock ones are still useable, or haven't crapped out yet.
    I inquired with @james@tech12volts recently about speaker upgrades with HU like ours. He recommended the jl c1 650 at or about $150 a pair with brackets.
    I have found some Pioneers and other known brands online with good reviews from $100ish and up.
    I have also been intrigued in a smaller powered subwoofer. Many brands and options, not truck shaking but adds a little Bass. Also looks somewhat easy to install.
    Something like this:
  19. Aug 20, 2019 at 6:59 AM
    Trooper2
    JR
    Think built for Gen 3's. Not sure if would work for Gen 2.
