Custom grille that has "Tundra" on it?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wendy, May 20, 2019.
  1. May 20, 2019 at 7:11 PM
    Wendy
    Wendy [OP] New Member
    Wendy
    2017 tundra sr5 crewmax
    I have a 2017 crewmax sr5. Looking for suggestions on a custom grille that says tundra.
  2. May 20, 2019 at 7:15 PM
    Welcome from Texas, let's see your ride
    GNTundra likes this.
  3. May 20, 2019 at 7:20 PM
    @SullyMoto19 believe you had one that said MAYHEM??? OR TUNDRA lit up???
  4. May 20, 2019 at 7:21 PM
    Welcome from NY.
  5. May 20, 2019 at 7:28 PM
    @Wendy look up dbcustomz.com
    Wendy[OP] likes this.
  6. May 20, 2019 at 7:43 PM
    @Wendy
    Or get a PRO grille and have @Sting Ray light it up, check out at harmoncustoms.com
    Sting Ray, aperezsh and Wendy[OP] like this.
  7. May 20, 2019 at 7:47 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME!
  8. May 20, 2019 at 8:05 PM
    Notachickmagnet
    Notachickmagnet New Member
  9. May 20, 2019 at 8:43 PM
    Wendy
    Wendy
    Thanks for the welcome.
  10. May 21, 2019 at 2:49 AM
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
    I have MAYHEM
    TokerJoker, Pudge and Deuxlatch like this.
  11. May 21, 2019 at 6:18 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    i had a DBCustomz that said "TUNDRA"... is yours made by ENVE?
    thanks @ARamirez73
    Jonlee124 and TXRailRoadBandit73 like this.
  12. May 21, 2019 at 6:48 AM
    Ragecage92si
    Josh
    17 blue TRD
    Yes mine is ENVE, but did not come lit. I made it light up.
    TokerJoker and Pudge like this.
  13. May 21, 2019 at 6:49 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Would love to see how you did that, looks way brighter than mine was... I loved my DBCustomz, but I was not impressed with the backlit option. Was not very bright at all
  14. May 21, 2019 at 7:06 AM
    Ragecage92si
    Josh
    17 blue TRD
    Not sure if I have pics, but I used 1/4” Lexan, one clear and one color matched blue. So it is blue when not lit. The clear one got white led strip, top and bottom, edge lighting the lexan.
    First time I did it with only 1 led strip and was not bright enough, and I used 1 piece of lexan, painted the back side. (Didn’t work so well) Went double lexan and had issues with water getting between then, now I have it water tight, and thinking about changing lights to rgb and be able to change with the rock lights.
  15. May 21, 2019 at 7:36 AM
    SullyMoto19
    Tyler
    Houston, Texas
    damn man, great work. RBG would look sweet for sure. Id do the same as I have RGB pods and rocklights
  16. May 24, 2019 at 8:44 AM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Thanks for the mention! Let me
    Know if I can help!
