safe way to test travel/articulation?
Discussion in 'Suspension' started by Brocksw, May 21, 2019.
  1. May 21, 2019 at 8:55 AM
    Brocksw
    Brocksw [OP] New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    Is there a safe and handy way to check your suspension travel at home without access to one of those ramps? I'd like to see how much up travel my shock has and what I need for bump stops on the front.
  2. May 21, 2019 at 9:27 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I haven’t tried this, but I’m wondering if it’s possible to cycle the front up and down by hand, maybe using a big, long pry bar, with the wheels off and the front on jack stands? Not sure if it can be done without loosening the lower control cam nuts a bit, though.
    Trooper2 likes this.
  3. May 21, 2019 at 9:52 AM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    I just did this the other day using a hill in my yard.
    Changing the positioning of the truck would allow you to lift a front wheel as well.
    Would something like this work? Or do you need to know full compression?
  4. May 21, 2019 at 9:56 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Gotta remove the spring. That spring can rebound your 7000lb truck. Won’t be able to beat that by hand
    15whtrd likes this.
  5. May 21, 2019 at 10:19 AM
    Grumpy Uncle
    Pat
    CO
    I played a little with my ramps at the house. They are only about 6" though. (I know that's what she said)
    TheBeast likes this.
  6. May 21, 2019 at 12:00 PM
    Brocksw
    I'd prefer not to disassemble the shock...partly because its a paint but mostly because that doesn't tell me what type type of bump stop or bump stop extension I need and with my front sway bar I'm pretty sure getting to full compression while they're on the truck is not likely. Need to know real life up travel while on the truck.
  7. May 21, 2019 at 12:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What shock setup are you running
  8. May 21, 2019 at 12:44 PM
    15whtrd
    15whtrd Mr. Blonde
    The only way to really know this is without springs. The shocks need to be mounted and you would jack up that side of the vehicle until it’s compressed all the way, then measure your bump stop distance. It’s a pain in the ass but it’s the only way I see to properly do this. Otherwise go off of someone else’s formula and what they came up with. Doing this with the springs on will not give you full travel as it would if you were out hitting the bumps while driving.
    Sunnier and Brocksw[OP] like this.
  9. May 21, 2019 at 1:29 PM
    Brocksw
    Elka 2.5
  10. May 21, 2019 at 1:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Call them and see if the compressed length matches the stock tundra shock.
    I’ll bet it’s close
    Sunnier, Brocksw[OP] and 15whtrd like this.
  11. May 21, 2019 at 1:56 PM
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    Get a case of bud light and take her out for a rip!
  12. May 21, 2019 at 2:04 PM
    Brocksw
    just called Franc at Elka to see if extensions were needed. Their engineers have been pretty good about getting me answers to questions so hopefully they reply back with an answer. Not sure why I did't just do that right away....:facepalm:
    15whtrd likes this.
  13. May 21, 2019 at 2:34 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would imagine elka wants the most travel possible, so having a similar collapsed length with stock would accomplish that. A arms have a fixed travel arc. So in reality bumpstop extensions just limit travel...
    equin and 15whtrd like this.
  14. May 21, 2019 at 2:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Unless they have a spacer lift LOL
  15. May 23, 2019 at 7:24 AM
    Brocksw
    Just heard back from Franc at Elka... They tested with factory bump stops... Says there is no need to get extensions.
    TruckyTruck likes this.
