P0440 Quick advice - Poll
Discussion in '1st Gen Tundras (2000-2006)' started by 00TundraZ, May 22, 2019.
P0440 fixed by gas cap replacement?
  1. Yes
    0 vote(s)
    0.0%
  2. No
    100.0%
  1. May 22, 2019 at 6:32 AM
    00TundraZ
    00TundraZ [OP] New Member
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    If you have experienced P0440, was it just the gas cap? I just ordered a new one in hopes this makes it go away. Wanted to gather a little info.
    If you fixed it with some other remedy, please let me know what it was!
    Truck runs fine, but it just doesn't run as nice as before. I'm guessing it is compensating a little for this code, possibly running slightly rich like my old mustang used to when I removed the cats.
    Thanks!
  2. May 22, 2019 at 11:04 AM
    I keep getting this code too. I just clear it and move on, then it comes back after a few drives(about a month). I've also heard it could be some part up under the spare. I think.
  3. May 22, 2019 at 11:06 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Mine was the filler tube itself. It was just dry rotted, only took about 20 minutes to replace in the driveway.
    Black Wolf and 00TundraZ[OP] like this.
  4. May 22, 2019 at 11:45 AM
    atl63
    atl63 New Member
    Andrew
    2000 Tundra
    Do you have a link to a walk through or can you give me a high level overview? I have the same code but new gas cap didn't solve it. I was thinking my issue might be the filler tube too.
    I was also going to test the purge valve but think I would be getting a second code if that was the cause.
  5. May 22, 2019 at 12:18 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not a whole lot to it, look up under the truck by the fuel filler. There's an approximately 15" long 1-1/4" diameter hose for the filler. There's a worm drive clamp at each end. You'll need a short screwdriver or a ratchet like the one below to remove the clamps. Pull the hose off each side and then move the clamps to the new hose and reinstall.
    Not a hard job by any means it's just cramped up in there.
    https://www.stanleytools.com/produc...s/ratchets/38-in-drive-rotator-ratchet/89-962
  6. May 22, 2019 at 2:00 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Thank you for the input! If my cap doesn’t fix it then this will be my next route. Where did you buy the hose? OEM? Local store?
  7. May 22, 2019 at 3:24 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Can’t remember the exact code, but a few years ago had the CEL light up and took it to Auto Zoned for the diagnostic. They said the code was reading some kind of ‘Charcoal Canister’ thinga jig in the gas tank. $400 part!
    Called up high dolla service shop and guy said put a new gas cap on it. It worked $8.
    I will be buying a new OEM cap as the quickie fix cap doesn’t have that leash attachment I used to enjoy. The little things.
    marbleville and 00TundraZ[OP] like this.
  8. May 22, 2019 at 3:58 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Well I hope this OEM cap is the ticket!
  9. May 22, 2019 at 4:05 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    00TundraZ[QUOTED][OP] likes this.
  10. May 22, 2019 at 4:06 PM
    Fred
    Hand Protectors
  11. May 22, 2019 at 4:12 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Possibly, you'd definitely want the old one to compare first. It's a weird corrugated hose and has to be flexible enough not to kink and just the correct length since there's no wiggle room.
    Black Wolf likes this.
  12. May 22, 2019 at 4:18 PM
    Fred
    Hand Protectors
    ATV25, Acatlin96, speedtre and 3 others like this.
  13. May 22, 2019 at 4:22 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    If my cap doesn’t fix it I’ll buy the OEM hose. It’s only money right?!
  14. May 22, 2019 at 5:00 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    I'd double check the part number before you order. They made a few changes and 02-03 have a couple options.
  15. May 22, 2019 at 5:15 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    I’ve got a 2000 so I’m sure it’s just 1 type. Heck I have a manufacture date of 1999
  16. May 23, 2019 at 12:00 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm just here for the blonde. :D
    ATV25, Festerw and (deleted member) like this.
  17. May 23, 2019 at 2:11 PM
    Fred
    Hand Protectors
    I wonder what she is thinking about?
    ATV25 and Darkness[QUOTED] like this.
  18. May 23, 2019 at 2:22 PM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Clearly thinking about my funnel. :bananadance:I mean c’mon that is thread relevant!
    ATV25 and Darkness like this.
  19. May 31, 2019 at 7:18 AM
    00TundraZ
    Zac
    Fort Wayne, Indiana
    2000 SR5 AC 4x4
    Just to follow up on this in case someone digs this up on the interwebs, I have had the new cap on for a week and the code has not resurfaced. I spent the coin and bought a toyota OEM cap. :mudding:
  20. May 31, 2019 at 9:37 AM
    Fred
    Hand Protectors
  21. Jul 5, 2021 at 7:53 AM
    pratt26
    pratt26 New Member
    Jihn
    2010 Tundra double cab SR5
    My P0440 was cleared by reconnecting the cables after my truck was serviced to replace the Knock sensor :(
