********* vs. Tech12Volts
Discussion in 'Audio & Video' started by CenTexTundra, Apr 19, 2019.
  1. May 10, 2019 at 5:25 AM
    #61
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    I sent a couple emails
    Meh, I will go local and see what they have.
    I have an appointment today with a place to discuss what I am looking for.
    I used them over the last 15 years but like everyone else they got to big to have good support.
    Would like this done in the next week or so and waiting over a week when he responded here to a forum is a bit odd but he may be too busy now with joining a forum and selling a lot of kits as well as the group buy that when on.
    May take him a couple weeks to catch up
  2. May 10, 2019 at 11:27 AM
    #62
    hypa
    hypa New Member
    A new headunit is definately the best way to go. The stock unit integrates so well with the steering wheel controls, etc that I didn't want to mess with it. After doing my research, I went with the ********* full setup with 4 speakers, two 12" subs and dual amps. I'm really happy with the results.
    That said, I'm not going to be winning any IASCA comps with this setup, but for windows down summer cruising it's just perfect.
    Netmonkey likes this.
  3. May 10, 2019 at 8:58 PM
    #63
    CenTexTundra
    CenTexTundra [OP] New Member
    2017 Tundra Limited
    BDS 7" Coilover lift; BDS UCAs 37" Nitto Ridge Grapplers; 20" Fuel Tactic Wheels Smittybilt 10k Winch; Smittybilt M1 Bumpers WeatherTech Mats; EPS Rear Vault, TRD Pro Grille Genesis Offroad Dual Battery (Optimas)
    I didn't switch out the dash but did add the DSR1. I'm still kicking around the idea, for now it still looks totally stock...but it sure doesn't sound stock!
  4. May 10, 2019 at 9:02 PM
    #64
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I swapped my dahh speakers before I had decided to change head unit and add an amp. I got them from James, 3.5 infinity reference cfx in the corners and dual JL C1 tweeters on his custom bracket in the center. I ended up powering those from the headunits speaker outputs, just ran new wires to each speaker. Was easy enough but not really necessary once you amplify the door components
  5. May 10, 2019 at 9:03 PM
    #65
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Centex, I have the same system and upgraded the center to C1’s and the corner dash speakers too. The corners were too overpowering so I disconnected them. I do however really like the C1’s at the center. Well worth the $75 in my opinion.
  6. May 11, 2019 at 7:13 AM
    #66
    CenTexTundra
    2017 Tundra Limited
    I will look into upgrading the center channel. You are running right off of the head unit vs an amp? I'm sure that's plenty of power since the center should be more subtle and thanks for the heads up on the corner dash speakers, I can see how that might put too much sound in the front.
  7. May 11, 2019 at 7:24 AM
    #67
    CenTexTundra
    2017 Tundra Limited
    Oh ok. That was probably a lot of juice going to the front dash.
    PS great looking Lab! I have a black female that just turned 1.
  8. May 11, 2019 at 9:40 AM
    #68
    PNW_Husky
    I have the stock JBL so I’m running the center channel off the front outputs of the RD900/5 bridged.
  9. May 20, 2019 at 8:08 PM
    #69
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    I went with an OEM Audio+ system for my non JBL H/U. It was pretty much a done deal after the ********* guy got pissy when I told him his practice of moving orders to the back was nonsense.
    My system has been sitting in a closet since it got here, as I had a pretty severe rotator cuff repair in mid February, and was under strict instructions to lift nothing more than a cup of coffee. Yesterday morning, I got a text from OEM, asking me how I was, and how the system sounded. That’s some pretty cool follow up, and I’m going to attempt the install over the long holiday weekend.
