Coachbuilder Issue
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by pitts101, May 19, 2019.
  1. May 19, 2019 at 8:46 AM
    pitts101
    pitts101 [OP] New Member
    2016 TRD Pro
    i installed my +3 shackles on my 16 pro last night and my exhaust is hitting the leaf springs now just sitting there, did I miss something or do you have to take the truck to a muffler place to rework the exhaust????
    Rica25 likes this.
  2. May 19, 2019 at 9:44 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Pics?
    Rica25 likes this.
  3. May 19, 2019 at 9:50 AM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Contact David @Coachbuilder1 he should be able to coach you through how to fix it.
    Rica25 likes this.
  4. May 19, 2019 at 9:54 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    It says on his site that it works with TRD dual exhaust. I would contact him with pics. You should be able to get that worked out quickly.
    https://shop-coachbuilder.myshopify...ilder-3-shackles-provides-1-75-of-actual-lift
    Rica25 likes this.
  5. May 19, 2019 at 10:00 AM
    pitts101
    2016 TRD Pro
    The exhast isn’t even in the rubber exhaust hanger and it’s an 1/8” from touching. I need to go up about an inch to be in the exhast hanger.
    Coachbuilder1 and Rica25 like this.
  6. May 19, 2019 at 10:10 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    That last u-bolt on your leaf isn't stock. What is it used for?
  7. May 19, 2019 at 10:17 AM
    pitts101
    2016 TRD Pro
    Not sure, I didn’t put it there and I assumed stock
    Rica25 likes this.
  8. May 19, 2019 at 10:22 AM
    Levidale08
    Levidale08 New Member
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Homemade bed rack with extra spare with Rhino rack,two jerry cans mounted in the bed
    Just cut the suckers. That’s what I did because I was hitting the tips off-roading.
    TheBeast and Rica25 like this.
  9. May 19, 2019 at 10:24 AM
    GiantsFanDan
    That's not stock. Get some more photos so we can see what it is.
  10. May 19, 2019 at 10:27 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Yea that u- bolt that ur hitting is definitely not stock- do u have add-a leaf or aftermarket leaf pack ??
    did u buy tuck used?
    Rica25 and pitts101[OP] like this.
  11. May 19, 2019 at 10:28 AM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
  12. May 19, 2019 at 10:30 AM
    pitts101
    2016 TRD Pro
    Interesting, I bought the truck used and I didn’t install that.
    Rica25 likes this.
  13. May 19, 2019 at 10:36 AM
    pitts101
    2016 TRD Pro
    Do you have an add a leaf or did you have the u bolt stock?
    Rica25 likes this.
  14. May 19, 2019 at 10:36 AM
    pitts101
    2016 TRD Pro
    Ya I bought it used
    Rica25 likes this.
  15. May 19, 2019 at 10:45 AM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    It was stock. Mine didn’t have what yours has. I cut the exhaust right after the axle. No more dragging the tips and hitting the pipe with the springs.
  16. May 19, 2019 at 10:50 AM
    pitts101
    2016 TRD Pro
    Ok so how many leafs are stock? Is there anything wrong with turning the u bolt upside down so the bolts face up?
  17. May 19, 2019 at 11:03 AM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    I think it was 4. I’ll have to find mine original springs. I put Alcan springs on mine a while back.
  18. May 19, 2019 at 11:11 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I just used a different hanger that allowed us to "push" the tailpipe down a bit to avoid contact. I'm running CB +3 as well.
    pitts101[OP] and Rica25 like this.
  19. May 19, 2019 at 11:41 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You can see your helper leaf on there. If you don’t haul you could remove it
  20. May 19, 2019 at 11:42 AM
    Tundramoney
    Tundramoney Old school
    Earth
    Extended shackles are bad for your leaf springs
    Rica25 likes this.
  21. May 19, 2019 at 1:02 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    From the looks of those particular helper springs, the u bolt needs to be oriented that way to sit in the groove on the spring end. If it were turned around would the flat part of the u-bolt rest in the groove?
    pitts101[OP] and Watt maker like this.
  22. May 19, 2019 at 1:11 PM
    pitts101
    2016 TRD Pro
    After review, yes they definitely have add a leaf. I didn’t know that till now. I do tow a lot so i May extend the exhaust a couple inches down. The tires are on the ground full weight btw.
    Watt maker likes this.
  23. May 19, 2019 at 1:14 PM
    pitts101
    2016 TRD Pro
    Ok 1 more thing, I bought cb shims for the front and this says 1” lift but it’s only 1/2” thick. That make sense?
  24. May 19, 2019 at 1:24 PM
    pitts101
    2016 TRD Pro
    Ok thanks!
  25. May 19, 2019 at 2:03 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    Anyone else see this and laugh, I know I’m childish you don’t have to tell me. A69E65FB-ADE5-47E9-AD08-96FF2AA28AC5.jpg
  26. May 19, 2019 at 5:10 PM
    4Runner
    4Runner New Member
    Columbia, SC
    I have already solved this. Please just look at my post.
  27. May 19, 2019 at 5:20 PM
    pitts101
    2016 TRD Pro
    Where do I get this?
  28. May 19, 2019 at 5:24 PM
    4Runner
    4Runner New Member
    Columbia, SC
    I go mine from eBay. Euro something. PM me. I’ll send you link
  29. May 19, 2019 at 5:58 PM
    TheBeast
    TheBeast The Beach
    chop chop..:sawzall:
    when the truck is on a lift the droop will be even more. Those springs gonna rest on the exhaust pipe.
    I had to chop mine (running Deavers and extended bypasses though)
  30. May 20, 2019 at 9:15 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Good talkin' Chris, Let us know how it goes, should be a simple fix :)
