Motor starts then dies in 3 seconds....bad gas?
Discussion in 'General Tundra Discussion' started by Roundup, May 18, 2019.
  1. May 18, 2019 at 8:20 PM
    Roundup
    Roundup [OP] New Member
    2013Tundra, 112,000 on the clock. Full tank of gas.
    Motor starts and immediately dies as if fuel shut off. Fuel filter? Bad gas? Other?
    All comments welcome.
    Y0TA PR0 likes this.
  2. May 18, 2019 at 8:49 PM
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    Could be alot of things but I would listen to see if the fuel pump goes on when you turn the ignition I'm not a mechanic tho so .....it realy could be anything
  3. May 18, 2019 at 9:02 PM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    Try using your spare key. Could be a interlock/ignition issue.
    koditten, ColoradoTJ and Watt maker like this.
  4. May 18, 2019 at 9:32 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is your 2013 Flex Fuel?
  5. May 18, 2019 at 10:53 PM
    Roundup
    Great suggestions! I will run these traps and report back.
  6. May 18, 2019 at 11:20 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Check your MAF sensor on your air intake :confused::confused:
  7. May 19, 2019 at 12:42 AM
    kgb4187
    kgb4187 New Member
    If it starts fine and turns off after 3 seconds every time I don't think it's a physical issue, something with the security software or something.
    ColoradoTJ likes this.
  8. May 19, 2019 at 1:13 AM
    zackbremer
    zackbremer New Member
    Da Z
    mine did the same thing, it was the maf sensor, its the lil plug on the air intake tube between the airfliter and the manifold. sensor is anywhere for 60-120$ takes less than 5mins to swap and problem went away.
  9. May 19, 2019 at 6:11 AM
    Roundup
  10. May 19, 2019 at 8:34 AM
    Roundup
    No sir
    No sir.
    Looking for spare key and will focus on MAF.
    Thanks all.
  11. May 19, 2019 at 10:01 AM
    Roundup
    Got the last MAF sensor Orielly's had. Headed to swap out.
    OR18TRD likes this.
  12. May 19, 2019 at 12:24 PM
    Roundup
    Well, swapped out the sensor and zero change.
    This truck is parked in a downtown open but covered multi floor concrete garage. Spotted by a younger set of eyes than mine, was a chewed up right side fender well wiring harness to include headlight wires. Squirrels!
    Thanks for all the help guys. Monday call is to the insurance agent.
    Watt maker and OR18TRD like this.
