Seat belt chime won't turn off!
Discussion in 'General Tundra Discussion' started by megahmann, May 17, 2019.
  1. May 17, 2019 at 8:11 PM
    megahmann
    megahmann [OP] New Member
    Damion
    07 electric blue TRD Limited and lifted
    I have an 07 tundra that I just bought. I love this truck so much but I noticed that the seat belt chime and symbol comes on while driving periodically.
    I always wear my seat belt* let me say that first before anyone complains.*
    It's irritating to know that while driving, the chime comes on about ten times during my commute! I hate it!
    What can I do about this problem without going to the dealership?
  2. May 17, 2019 at 8:15 PM
    bfd300
    bfd300 New Member
    It comes on while wearing your seatbelt?
  3. May 17, 2019 at 8:16 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    Take your lunch box out of the passenger seat!
  4. May 17, 2019 at 8:19 PM
    Trpl7
    Rob
    Washington
    Super White 07
    Seriously, if you have something sitting in the passenger seat that I believe weighs close to maybe 10-12 lbs it will cause this to happen. I run a bullydog that takes the chime away but it doesn’t shut lights off and I notice every once in awhile that the light will start blinking.
    TRDFerguson and landphil like this.
  5. May 17, 2019 at 8:20 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Maybe check the wiring under your seat for the seatbelt sensor, could be loose or broken. Alternatively, you could grab a copy of techstream and OBD2 cable and disable the seatbelt chime altogether... But would probably be best to fix the issue, not treat the symptom.
    15whtrd likes this.
  6. May 17, 2019 at 8:28 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup, this would be the issue if there is anything on the passenger's seat.
  7. May 17, 2019 at 8:46 PM
    megahmann
    Damion
    there is no one and or nothing in the passenger seat.
  8. May 17, 2019 at 9:11 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Well damn. They can't all be easy, can they? I'm thinking two possibilities then. Option 1: something is wrong with the seatbelt switch in the driver's seatbelt buckle, wiring, or it's connector. Option 2: the weight sensor in the passenger's seat is reading incorrectly.
    Here's my suggestion to try to narrow that down. Next time you're driving solo, buckle the passenger's seat belt as well, even though the seat is empty. If the warnings continue, it's likely option 1. If silence and (almost) world peace, then option 2.
    15whtrd, joonbug and TRDFerguson like this.
  9. May 17, 2019 at 9:12 PM
    megahmann
    Damion
    i will give option one a go landphil thanks so much.
    landphil likes this.
  10. May 17, 2019 at 9:13 PM
    15whtrd, ColoradoTJ and TRDFerguson like this.
  11. May 18, 2019 at 4:28 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    It could be, a bad connection in the receiver portion of the seat belt, You can try some contact cleaner and insert and remove the seat belt a few times quickly to see if it frees up the switch. You can also put the seat all the way forward and make sure the wiring isn't damaged under the seat.
    -Jason
    15whtrd likes this.
