DIY mirror caps and door handle swap out
Discussion in '2.5 Gen Tundras (2014-2021)' started by T-Rex266, Oct 5, 2014.
  1. Oct 5, 2014 at 6:31 PM
    T-Rex266 [OP] Fuck Cancer Staff Member
    Like many, I was tired of chrome door handles and mirror caps and wanted to swap them out for black ones.
    Items needed:
    -Flat head screw driver
    -T30 hex wrench screw driver
    -Flashlight (I used one to see where the tabs were behind the mirror)
    - (2) replacement mirror caps
    - (2-4)door handles {dependent upon your model}
    Mirrors:
    Point the mirrors all the way down. You'll see two tabs at the top. Simply push the tabs down, and out with the flathead screw driver.
    Pull the mirror cap off
    Align the tabs with the new mirror cap and snap on.
    Door handles:
    Open the door and remove the black plastic covering on the side of the door. (I used a flat head to pry it off...don't forget to place it somewhere you won't lose it)
    Use the t30 screwdriver to loosen the hex. Don't worry, it will not fall into the door-frame. It catches before hand.
    Pull off the handle (they slide and pop off)
    Place replacement on and slide to the left to lock it into place. Tighten the hex bolt and you're done.
  2. Oct 5, 2014 at 7:58 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice write up, thanks!
    T-Rex266[OP] likes this.
  3. Nov 11, 2014 at 5:06 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    So I called my dealership to see if they had door handles to replace my chrome ones. They quoted me at $650....for door handles! I told him i was going to just paint them with a sharpie.
  4. Nov 11, 2014 at 5:11 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good write-up
    Rica25 and T-Rex266[OP] like this.
  5. Nov 11, 2014 at 5:12 PM
    csuviper
    Broomfield, CO
    LOL! The look on that guys face :)
    darkknight2014 likes this.
  6. Nov 11, 2014 at 5:27 PM
    Lmao. Check with TRDSparks. I paid half of that for handles AND mirror caps...all were OEM parts.
    RitcheyRch and Blueknights75 like this.
  7. Dec 24, 2014 at 10:10 AM
    BadRobot63
    BadRobot63 New Member
    2015 Tundra Crew
    Auto tail gate opener, driver side grab handle.
    Sean266 why are your pictures not showing in your original post.
  8. Dec 24, 2014 at 6:48 PM
    Gah. Because I copied the url from Gmail. I'll fix it soon.
  9. May 25, 2015 at 4:43 PM
    Updated OP with photos according to order.
  10. May 25, 2015 at 7:30 PM
    Dilsky
    Shawn
    Edmonton, Alberta
    I ended up going with some plastidip and clear coated them. So far they are holding up allright!
    ScottTN likes this.
  11. Aug 10, 2015 at 3:46 AM
    Mmabucs65
    Mmabucs65 New Member
    New York
    2014 tundra limited double cab
    6 inch pro-comp lift, TRD sport muffler, cherry bomb exhaust, FabFour bumpers, go rhino 2.0 sport bar, 20in fuel wheels, 37" Nitto ridge grapplers, Alpine ILX-F511 headunit, upgraded speakers with 2 8inch sundown audio subwoofers.
    Great write up, where did you pick up the mirror caps and door handles?
  12. Aug 10, 2015 at 5:14 AM
    TRDSparks.
  13. Jul 26, 2016 at 10:46 AM
    Maddog94
    Maddog94 New Member
    GREAT write up, thank you! Just changed all my chrome out now thanks to your guide. I don't think I would have attempted it otherwise. Was super easy.
    csuviper likes this.
  14. Oct 23, 2016 at 3:12 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Is there some type of adhesive tape or something holding the mirror caps on? Mine are not budging. Period. No way.
    I push the tab(s) down and try to push away(toward the front of the truck) and there is no movement. Nada.
    Am I missing something?
    grrr.
    FireAC likes this.
  15. Oct 23, 2016 at 3:38 PM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    Mike, mine were a major PITA, but the caps came off undamaged.
    I'll attach a pdf with some additional pics.
    There's lots of clips. Should be no tape or adhesive.
    Good luck!
  16. Oct 23, 2016 at 3:49 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Love my color matched ones.
  17. Oct 23, 2016 at 5:17 PM
    McLovin
    McLovin New Member
    Harry
    Maryland
    17' QS CM Limited, 14' MGM T4R SR5 Premium,
    The process of removing the mirror caps is described as releasing the 2 clips at the top. This may have worked in some cases but not for me. There are 4 clips total. In my case, I released the inner clip first (closest to the body regardless of passenger or driver side). Then the top clip closest, then the second top clip and finally the outside clip. If you look at your replacement mirror caps, you'll see what I mean. Hope this helps.
  18. Oct 23, 2016 at 6:45 PM
    AxelsHumanDad
    2015 CM Platinum
    Thanks. I don't have replacements(yet). I was going to dip these until I get replacements ordered and color matched. I'll have another look tomorrow.
  19. Oct 23, 2016 at 6:46 PM
    AxelsHumanDad
    2015 CM Platinum
    Thanks for that. Tomorrow is another day. :cool:
  20. Oct 23, 2016 at 6:47 PM
    AxelsHumanDad
    2015 CM Platinum
    That looks great! Exactly what I want to do with my Bronze eventually.
    Tophergt99[QUOTED] likes this.
  21. Oct 23, 2016 at 6:54 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for the write up Sean. I've had the black handles waiting on my dresser for about 2 weeks now. I'll try this tomorrow morning before work.
  22. Oct 24, 2016 at 8:06 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    when you put the mirror caps back on what part did you snap in first from the top or the bottom?
  23. Oct 24, 2016 at 9:04 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    OK, that was really fast and easy. It's gonna take me longer to post before and after pics tonight than it took to change the handles. Having done them, I think I wanna pull 'em again and color match 'em. I'll live with 'em for a few days,,,, at least as long as it takes for the paint to show up...ha.
    MatthewPTguy likes this.
  24. Oct 24, 2016 at 9:05 AM
    McLovin
    McLovin New Member
    Harry
    Maryland
    I lined up the bottom first because they have that downward hook to them. Then the top I carefully snapped back into place.
    040Tundra likes this.
  25. Oct 24, 2016 at 9:44 AM
    SuperSilverTundra
    thanks just curious since I had installed them on my truck a few months ago they didn't seem to fit perfect the driver side cap had more of a gap then passenger side trdsparks took care of me and sent out another pair I have yet to install them I will install later when I get home just checking to see if there was and tips to install but I will give it a shot today starting from the bottom see if it makes a difference
  26. Oct 28, 2016 at 10:57 AM
    Tundra280AI
    Tundra280AI New Member
    COS
    '17 Tacoma TRD OR
    Just swapped mine out today, less than 30 min for a rookie. Probably take 10 if I had to do it again
    Have a chrome set available from a 16 CM
  27. Nov 4, 2016 at 10:27 AM
    Tundra1616
    Tundra1616 New Member
    Anyone has a set of chrome door handles and/or mirror caps for a 2016 Tundra interested in selling? If so please pm me.
    Thanks.
  28. Nov 6, 2016 at 4:30 PM
    YotaguyVA
    YotaguyVA New Member
    Renato
    Virginia
    16 silver sr5 Trd crewmax
    LED conversions, spray in liner, tonneau cover, color matched handles, 3/2 level, 2" spacers, 295/70r18 cooper st maxx on stock wheels.
    i ordered color matched (sky silver) door handles to put on from http://www.sparksparts.com/ i wanted to just install those and see if i wanted to do more, such as the mirror caps or the grille. i will post pictures after the install. Anybody have pictures of silver tundra with the grill/mirror caps/etc body matched?
  29. Nov 7, 2016 at 8:00 AM
    SuperSilverTundra
    @YotaguyVA check out my truck painted grille/door handles/mirror caps
  30. Nov 7, 2016 at 10:41 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    I didn't know it's that easy to swap out the door handles. Now I'll be in the market for a nice set of chrome door handles. As soon as I get the new eyeballs and Christmas paid for, that is.
