2016 bed alignment is not correct.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tahoe Tundra, Oct 9, 2016.
  1. Oct 9, 2016 at 11:02 AM
    Tahoe Tundra
    Tahoe Tundra [OP] New Member
    2016 tundra 4x4 sr5 dbl cab long bed TRD
    Anybody else with this issue ?. Purchased a tundra with a long bed about 6 months ago. Got to looking at the body while wash and waxing the truck the other day and noticed that the bed is about 1 inch off center to the right from the back of the cab. Service person said he has never seen anything like that in his 4 years with the dealership. They are going to look at it next week. Can this be corrected at the dealership ?. Is there room for adjustment ?.
    dcsleeper408 likes this.
  2. Oct 9, 2016 at 11:05 AM
    TheBeast
    TheBeast The Beach
    lots of new tacomas with the same issue
    BlueFalconActual likes this.
  3. Oct 9, 2016 at 11:07 AM
    Tahoe Tundra
    Wow. quality control issue at factory ?.
  4. Oct 9, 2016 at 11:09 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Mine is off center too. Not a whole inch but definitely noticeable. I'm going to address it on my next oil change next week. Let me know what they say.
  5. Oct 9, 2016 at 3:22 PM
    Blankcheese
    Blankcheese New Member
    Johnny
    '16 SR5 DC 4WD
    That sounds like something they can fix.
  6. Oct 9, 2016 at 3:35 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Mine is too!!! Maybe about 3/8". Double cab long bed. And my front bumper is different in height left to right.
  7. Oct 9, 2016 at 4:20 PM
    vidman
    vidman New Member
    Rick
    Massachusetts
    I was just looking at mine while installing my firestone airbags and cradles and mine is pretty much perfect. the dealer should be able to fix
  8. Oct 9, 2016 at 4:39 PM
    Sorry guys. It was my fault. Damn whiskey takes the best of me when I adjusted the tooling a few months back. Be going down in TX to fix issues in a week or so. I talked to Mike and he is allowing me to keep my overpaid engineer position and authorize you all to go back and get a new truck on Toyota.
    Just mention ColoradoTJ. They know who the drunk bastard is.
    Crewmax Chris, 831Tun, gosolo and 6 others like this.
  9. Oct 9, 2016 at 4:50 PM
    That sucks guys. It can be fixed though. There is quite a bit of adjustment that can be made.
    It does blow ass that you have to get it taken care of on your valuable time for something that should have been done right the first time.
    NewImprovedRon likes this.
  10. Oct 9, 2016 at 5:25 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I had an old truck that had the same issue and a body shop was able to adjust it and get it right on. The tech that did the adjustment said the body itself usually has an oversized hole in it, so you have that adjustment option. Maybe your truck got built on a Friday PM or Monday AM ? Good luck and let us know the outcome.
  11. Oct 9, 2016 at 7:09 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    If I get a chance tomorrow, I'll talk with the QA guys in the plant and see what the tolerance is. Been meaning to do this, because mine is noticeably off as well.
  12. Oct 11, 2016 at 3:59 AM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    So I wasn't able to talk with any of the managers, but one of the floor QA inspectors said that the tolerance for bumper alignment is up to 1" variance from one side to the other. I will try to follow up and verify this to be correct.
    NewImprovedRon and jburson250 like this.
  13. Oct 17, 2016 at 8:50 AM
    Tahoe Tundra
    Turns out to be that the cab alignment is off from the factory. Dealership tried to adjust the bed. No adjustment. Service manager told me to take it to the best body shop in town. Shop owner said it was the cab that is out of alignment. Estimate repair cost is 300 dollars. Toyota will pay for it.
    Law323 and dcsleeper408 like this.
  14. Oct 23, 2016 at 1:29 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    I just noticed my 2014 crewmax is off as well. About 1/2 to 3/4 inch, and can tell by how much my tires stick out
  15. Oct 23, 2016 at 1:36 PM
    15whtrd
    15whtrd Mr. Blonde
    I loosened my bed up and the rear bumper the first month I had at home to realign everything.
  16. Oct 23, 2016 at 1:42 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Can you tell me which bolts I need to loosen, or reference a thread that can help, it super annoying!! Lol My OCD is in the red! Ha ha
  17. Oct 23, 2016 at 1:46 PM
    15whtrd
    15whtrd Mr. Blonde
    Just for the bed alone loosen the bolts that are on the floor of the bed. I looked up the torque specs to make sure I torqued them properly when I was done. And for the bumper I think it was three bolts on each side along the frame. Once you get under there and look at it it's pretty self-explanatory just make sure you torque everything back up. I don't remember any specific post that I got it from I just looked up the torque specs.
  18. Oct 23, 2016 at 2:03 PM
    15whtrd
    15whtrd Mr. Blonde
    62 ft/lbs for the bed bolts and I think it was 84 ft/lbs for the bumper to frame bolts. It's actually where the trailer hitch is attached to the frame.
  19. Oct 23, 2016 at 2:17 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Thank you for the info, much appreciated!!!
  20. Oct 23, 2016 at 3:18 PM
    Fuck this thread. I'm gonna act like I didn't see this so I'm not out checking my own truck lol
  21. Oct 23, 2016 at 3:50 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Here is my problem
    Pretty significant IMO,.I also looked at it from behind at every dam angle and it's definitely not even.
  22. Oct 23, 2016 at 4:00 PM
    LalalalLala
  23. Oct 23, 2016 at 4:01 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Lmao!!! You should look now!!! Lol
  24. Oct 23, 2016 at 4:17 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I once had a 1950 3/4T ford with an 8' bed and a 12" space between the cab and the bed. I searched around for a 9' bed but couldn't find one. Never really figured that one out...
  25. Oct 23, 2016 at 6:35 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Yep, same on my '14! Rear passenger tire appears to stick out about 1" farther, so my bed is basically shifted 1/2" toward the driver side. One of these days I'll loosen the bolts and giver a nudge to the passenger side.
  26. Oct 23, 2016 at 6:48 PM
    15whtrd
    15whtrd Mr. Blonde
    I'm pretty sure it's the axle is off. Just get the bed square with the cab and call it a day. Everyone complains of the axle being off-center, something to do with the driveline.
  27. Oct 23, 2016 at 6:53 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Mine is definitely the bed, without even looking at the tire as a reference , I can easily see the rear of the bed pushed over toward the drivers side.
  28. Oct 23, 2016 at 7:23 PM
    15whtrd
    15whtrd Mr. Blonde
    Damn! It's very easy
  29. Oct 24, 2016 at 11:50 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    Mine is the same. Rear passenger tire sticks out about an inch further from bed than driver side. angle on photos is not the exact same, but I think you can get the idea from the pictures.
    dcsleeper408 and Relentless like this.
  30. Oct 24, 2016 at 12:00 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    It is my understanding just from doing a lot of reading on different Tundra forums, that the rear axle is off center on the tundra...presumably on purpose. Same as the infamous "Tundra Lean" that cannot be explained
