Will this setup work?
Discussion in 'Suspension' started by Runnerstrom28, Apr 23, 2019.
  1. Apr 23, 2019 at 3:57 AM
    Runnerstrom28
    Runnerstrom28 [OP] Hail Hydra
    Derek
    14 limited blue ribbon tundra crewmax
    From the research I've done on here I'm pretty sure this will work, just want to make sure though.
    Plan is to put Bilstein 5100s on the front to level it out, at the 2in setting and put on 275/65/20 nitto terra grapplers
    I'm sure I'll have to do some minor trimming, but will I have to do bmc?
  2. Apr 23, 2019 at 4:45 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    what offset you running?
  3. Apr 23, 2019 at 4:48 AM
    Runnerstrom28
    Derek
    Stock 20 rims, I have the limited edition
  4. Apr 23, 2019 at 4:53 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
  5. Apr 23, 2019 at 4:55 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    so the offset is what i'm needing....not size. but i believe the limited is a +60 offset, so with a 33"x (almost)11" tire, you should fit without any issues on a 2" level. i had fit same tire size on a 20x9 wheel with +20 offset and didn't have to trim anything on that either.
  6. Apr 23, 2019 at 5:19 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    BTW, the 5100's can be set at 1.57" or 2.24". The truck will be level at the 1.57" (middle) setting. The limited wheels are 20x8 +60mm offset. With those wheels, the 275's will easily clear the UCA. However, 275/65/20 is a 34" inch tire which may require some trimming. I don't think that you will need to do the BMC, but you may have to trim/manipulate some plastic. I think that you will need to remove the little front spats on the wheel well (2 screws and its off) and maybe trim or push in (heat gun) the mud flaps. If you have a skid plate, it may need to be bent up a little. Worse case, you may have to deal with the plastic that is attached to the bumper. You can use bumper shims or redrill the plastic. All of these modifications are minor and super easy. and it is worth it for the larger tires :)
    good luck :)
  7. Apr 23, 2019 at 5:26 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    crap....thanks. i missed the size that is was 65 and not 60! good catch and my bad! with that being said....agree with everything above^^^^
    Netmonkey[QUOTED] likes this.
  8. Apr 23, 2019 at 7:13 AM
    Runnerstrom28
    Derek
    Awesome! Thanks alot guys! I appreciate the wisdom :cheers:
    Netmonkey likes this.
  9. May 10, 2019 at 6:30 AM
    LiftMeUp
    LiftMeUp New Member
    Quick question. I see you say that with the 275s you will easily clear the UCAs. I believe that tire is 10.83 wide. I'm looking at the 285/65/20 on stock wheels. It's 11.22 wide. Plan on lifting front 3". You think any problem with UCA rubbing?
  10. May 10, 2019 at 6:38 AM
    Netmonkey
    Georgetown, TX
    it depends on the wheels that you have. in my reply, I was referring to the 20x8 +60mm offset wheels (that come on the limited trim). with that wheel, you should be able to fit a 285 and clear the UCA.
    LiftMeUp[QUOTED] likes this.
  11. May 12, 2019 at 8:36 AM
    Runnerstrom28
    Derek
    Finally got it done! 5100s middle setting with 275/65/20 terra grapplers
    LiftMeUp, TNTundra53 and Trooper2 like this.
  12. May 14, 2019 at 6:36 AM
    LiftMeUp
    LiftMeUp New Member
    What trimming had to be done? Any way of taking a pic of how close you are to UCAs? I want to run 285/65/20 on stocks but if can't fit then going to drop down to 275.
  13. May 14, 2019 at 9:43 AM
    Runnerstrom28
    Derek
    I'll take pics when I get home later today
