17.4 MPG on 5.7 4x4 -TSS
Discussion in 'General Tundra Discussion' started by Razorwyre, May 10, 2019.
  1. May 10, 2019 at 9:19 AM
    Razorwyre
    Razorwyre [OP] New Member
    2018 Tundra Platinum
    Since MPG seems to be a common topic around here, I thought I would share my commute this morning. Cruise set to 72mph.
    I haven’t weighed the truck but I suspect it is over 6000 pounds. I have a bedliner, tonneau, double sound deadening in doors, dual exhaust and Amp running boards.
    The key is two things, I recently switched to P rated 275/60R20 from E rated Toyos and I use TSS adaptive cruise. Lots of haters on this forum for TSS, but you are missing out, much more relaxing to drive in traffic as well as it coasts easily and accelerated gently and gets better gas mileage.
  2. May 10, 2019 at 9:24 AM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    I recently switched to 275/60R20 P rated as well but I’m not seeing this kind of improvement... perhaps my computer hasn’t RE-learned yet?
  3. May 10, 2019 at 9:25 AM
    Razorwyre
    Are you using cruise, and at what speed do you have it set?
  4. May 10, 2019 at 9:30 AM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Always use cruise, set 70-72MPh. I also have 3/1 level and BAKFLIP G2
  5. May 10, 2019 at 11:00 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    You must live someplace FLAT.
    JoshuaA and Watt maker like this.
  6. May 10, 2019 at 12:15 PM
    Razorwyre
    Good call, I am in Houston, very flat.
  7. May 13, 2019 at 6:28 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I've gotten 20 MPG on a few highway drives already. Yes, it's mostly flat here. And the adaptive cruise isn't horrible, I suppose. I'll keep those tires in mind when the time comes.
  8. May 13, 2019 at 6:59 AM
    Blueknights75
    Ron
    Clayton, NC
  9. May 13, 2019 at 7:06 AM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    I can get 17's-18's on stock platinum tires if I'm cruising 65 for a while. Other than that I'm lucky to get 13 in the city.
