New Member: Looking for Feedback/Info on 4.7 2nd Gen
Discussion in '2nd Gen Tundras (2007-2013)' started by crisanalex, May 12, 2019.
  1. May 12, 2019 at 9:44 AM
    crisanalex
    crisanalex [OP] New Member
    Alex
    Hey i'm new to the the Tundra forums, I'm looking to get a 2nd gen tundra with a 4.7 ( There has been 2 different recorded million mile trucks is the main reason why i'm looking into them.) and they fit the budget a little bit better. The thread says it all i'm looking for feed back from experienced owners from a reliability and drivabilty stand point. Thanks guys.
    Y0TA PR0 and Black Wolf like this.
  2. May 12, 2019 at 9:53 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  3. May 12, 2019 at 3:28 PM
    FXFormat
    FXFormat New Member
    Solid engine, but is under powered in this big body, plus you'd have to deal with timing belt maintenance as opposed to timing chains on the 4.6 and 5.7...
  4. May 12, 2019 at 4:17 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I have no complaints other than I should've got the 5.7 hahaha. Seriously though it's been great so far (Knock) The only 2 major issues I've had are the Air Injection Pumps and driveshaft, which were replaced @ Toyota's expense :D.
    Black Wolf likes this.
  5. May 12, 2019 at 4:32 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
  6. May 12, 2019 at 4:41 PM
    Welcome from Colorado. I've got the 5.7 so can't help there.
  7. May 12, 2019 at 4:52 PM
    Welcome from NY.
  8. May 12, 2019 at 5:30 PM
    FXFormat
    FXFormat New Member
    I have an LX470 which is the same 4.7, great motor, very smooth, lasts forever, however it's way down on power, esp if you use your truck to tow or haul heavy stuff. Mine is used for offroading and overlanding so power is not required, i have my Tundra 5.7 for power if i need it.
    Comfort, dutchman11, TheBeast and 4 others like this.
  9. May 12, 2019 at 5:35 PM
    Welcome from Texas
  10. May 12, 2019 at 6:30 PM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Welcome from South Texas. Good luck. Good looking Lexus. What size tires?
  11. May 12, 2019 at 6:43 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  12. May 12, 2019 at 7:30 PM
    TheBeast
    TheBeast The Beach
    that is clean !!
  13. May 12, 2019 at 8:08 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Would avoid timing belt engine if possible, costly maintenance item. 4.6 & 5.7 have timing chains, get changed less frequently.
    Only matter of time before we see a 4.6 or 5.7 get a million miles.
  14. May 13, 2019 at 11:30 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  15. May 13, 2019 at 11:33 AM
    LittleTRD
    LittleTRD New Member
    James
    Central California
    2015 Tundra Crewmax
    Camburg UCA's, Fox Factory 2.5's Front & Rear, Coachbuilder +3 Shackles, Decked Bed System, Snugtop Rebel Shell, switch pros 9100, and baja designs for all additional lighting.
    Welcome from Cali!
  16. May 13, 2019 at 4:02 PM
    Viking
    Viking New Member
    Jerry
    2007 metalic brown double cab Tundra
    Welcome from S.W. Oregon. You really need to keep tabs on miles when you have a timing belt, I have a friend that owns a Highlander with the 3.3 VVT engine, same as our Sienna engine, his belt broke and he spent a lot of money and since we have the same engine, we took our Sienna into Toyota service and had a new belt and water pump installed. The Carfax we had printed out didn't mention any belt change and I wasn't about to take any chances, service department said it was due so it could have saved us a bunch of cash. Those million mile Tundra's had the 4.7 engine, but like Trooper2, I suspect that it won't be long and a 4.6 or 5.7 will make the million mile mark, I'm really impressed that our 5.7 at 245,000 runs like new, definitely if you take care of them, they will probably serve you a lifetime. I would have liked to have owned ours from the beginning, same with the 2006 Sienna, would have saved a lot of headaches from the Fords we've owned that had far less miles on them.
    Trooper2 likes this.
  17. May 14, 2019 at 5:16 PM
    SilverTundraOR
    SilverTundraOR New Member
    2007 Tundra Limited
    I have a 07 with the 4.7l. The motor has been rock solid, but yes it is down on power compared to the 5.7. It gets almost the exact same mileage as a 5.7 so keep that in mind also.
