1UPPER’s 17 CM SC Platinum Custom Build
Discussion in '2.5 Gen Builds (2014-2021)' started by 1UPPER, Oct 20, 2016.
  1. May 1, 2019 at 10:42 AM
    #1261
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    More than the S/C whine and exhaust roar, I'm hearing the hours of detailing and cleaning lol. Good vid, trucks a beast. When are you going to open those headlights and do black with blue details, clear reflector mod? Think thats needed with your rig at the insane custom level it is.
    1UPPER[QUOTED][OP] likes this.
  2. May 1, 2019 at 11:14 AM
    #1262
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    Thank you for the compliments! I actually ordered the smoked reflector lenses for the headlights but decided to not open my OEM headlights. I was waiting to see how the new Morimoto replacement headlights performed instead of retro fitting. Plus I’m getting the itch to do a long travel tundra build.
    aperezsh, TokerJoker and airosey like this.
  3. May 1, 2019 at 4:50 PM
    #1263
    1UPPER
    TEXAS
    Flux capacitor!
  4. May 1, 2019 at 4:52 PM
    #1264
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    That's NUTS!!!
    1UPPER[OP] likes this.
  5. May 1, 2019 at 5:07 PM
    #1265
    1UPPER
    TEXAS
    Flux capacitor!
    I like this rear long travel setup but I don’t like loosing my towing and load capabilities. Im doing my research though. A4FDEB01-822B-4FAE-9D3C-4C6A87BBF3B9.jpg 261F22E2-7B43-4D78-A16E-09F024DEE39B.jpg
  6. May 1, 2019 at 5:34 PM
    #1266
    NjDevilToy
    NjDevilToy New Member
    MGM tundra
    I could look at that suspension all day
    aperezsh and 1UPPER[OP] like this.
  7. May 5, 2019 at 8:20 AM
    #1267
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    You are spot on Magnuson can and does make a higher volume SC like Whipple and Harrop 2600 however they were involved with Toyota in the original development so they understand the limits of the engine and drive train components including the aluminum engine block and 600HP at the crank is it. The reason why Toyota stopped the TRD SC which was built by Magnusson on the 5.7 was because people were changing the pulleys and pushing the vehicle beyond it's limits. At the end of the day my 2017 Tundra SC w/BD tune was getting 481HP at the rear wheels to the ground with stock wheels and tires I was in the low 440s with 33.5" tires to the ground. I lost about 50HP just going from stock tires to 285 70r 18 and heavier Fuel wheels. I lost a little more HP on SC Sequoia with 34" tires. The type of Dyno they used on @1UPPER's vs the roller type is that it gives you HP to the axle but not to the ground as it does not account for tire size and weight my guess with 37's were probably talking 410-420HP to the ground. it also is probably why there were initial incorrect MPG readings. I'm no expert but I have been studying this stuff for the last 7 years or so since I wanted to SC my first Tundra. Like 1UPPER said the real challenge in his tune was the long tube headers with this engine design the SC preforms better with just a less restrictive muffler or cat back system but without the LT headers.
  8. May 5, 2019 at 10:21 AM
    #1268
    1UPPER
    TEXAS
    Flux capacitor!
    Thanks for all your input and suggestions. Lots of good points to think about. I was surprised when they did my dyno from the axles versus the tires on rollers.
    I wasn’t originally planning on doing the SC when I did my long tube headers. So if I could do it all over again, I wouldn’t have change my headers with a SC. I’ve learned a lot on what to do and what not to do though. My particular situation was a little bit unique because not to many places have tuned a FFV SC, with long tube headers and the full exhaust. At least not in my area. I did tell Pro Speed when they did my tune to not worry about getting the most HP but to make sure it was reliable for daily use. I also said I didn’t want to push my motor to hard. I’m still very happy with my setup!
  9. May 5, 2019 at 10:46 AM
    #1269
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Niiiiice Add, very cool, I look forward to how this mounts up. Please post up mount/install pics, I may add one to my ARE Z.
  10. May 5, 2019 at 10:59 AM
    #1270
    1UPPER
    TEXAS
    Flux capacitor!
    Will do. It arrives this next week. I look forward to seeing how it works out.
  11. May 5, 2019 at 3:40 PM
    #1271
    Patriot
    Patriot Member
    Your Tundra Rocks Brother!!!
  12. May 5, 2019 at 4:06 PM
    #1272
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    That is a great approach to tell Pro Speed that the reliable HP # was the one you're after, not some peak # just to say that's how much HP you have. Your truck is a very unique combo of hardware and software, and you navigated those obstacles with quite a successful outcome. Hindsight will most often yield a recognition of other options, but I think you did extremely well with what you have from where you started. Being the first to work through something always makes it easier on the next guy to "1up" what you did, but that is what progression is all about. I'm sure you have a complete truck build in your head as to how you would do "the next one". ... which I'm looking forward to as well!
    1UPPER[QUOTED][OP] and Bo-Hunter like this.
  13. May 5, 2019 at 5:36 PM
    #1273
    Bo-Hunter
    Greg
    NOVA
    2009 RW 4x4 Truck
    Please don't take my previous post the wrong way. You have an incredible build and the guys at Pro Speed are the best in the business I wish I lived closer to them. You have an awesome tune especially having to deal with the truck being ffv. I appreciate the info you shared at least now we know there are more options for the ffv guys. I agree with toyoholic 100%. I apologize if my post seemed bad it was not meant to be. I have the upmost respect for you and your build i think it’s incredible.
  14. May 5, 2019 at 5:48 PM
    #1274
    1UPPER
    TEXAS
    Flux capacitor!
    Thanks for all the kind words. I definitely have a plan in my head already for my next 2020 build. I really enjoy thinking and making new ideas to set my trucks apart from what I typically see. I’m pretty certain I’ll sell my truck this fall and do a whole new build from the ground up. So my gears are turning and planning the next build already.
    :burnrubber:
  15. May 5, 2019 at 5:50 PM
    #1275
    1UPPER
    TEXAS
    Flux capacitor!
    No worries bro. I didn’t take any offense to your previous post. I always appreciate another persons opinion. Thank you for the compliments!
    T-Rex266 and Toyotoholic like this.
  16. May 9, 2019 at 6:44 AM
    #1276
    1UPPER
    TEXAS
    Flux capacitor!
    Look what arrived yesterday! Now I need some dry weather to install on my ARE Z series camper shell. 8E15D81B-7988-496E-B24F-86E18C7D4FFF.jpg
  17. May 9, 2019 at 7:11 AM
    #1277
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Can't wait to see how it turns out. And how many LED's it will take!
  18. May 9, 2019 at 8:48 AM
    #1278
    PinoyRN
    PinoyRN Manila Gorilla
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    DIBS!! :spending:
  19. May 9, 2019 at 9:56 AM
    #1279
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I am busy this weekend, but can help next week after work if you need a hand installing. Not sure about next weekends schedule yet
  20. May 9, 2019 at 10:19 AM
    #1280
    1UPPER
    TEXAS
    Flux capacitor!
    I appreciate it but the install is pretty straight forward. It will install on my camper shell rails. So it’s a lot easier than my roof rack.
    Watt maker, Pudge and TokerJoker like this.
  21. May 11, 2019 at 7:45 AM
    #1281
    1UPPER
    TEXAS
    Flux capacitor!
    Unboxing my Prinsu ARE camper shell rack. I like that the bars are notched so you can fit hardware into the grooves for lights or other accessories. D4C04ACC-A348-4006-895D-CE371B583704.jpg
    Kind of surprised the Prinsu rack only has 7x bars with the kit. My Coachbuilder kit came with 12x bars for the roof rack.
  22. May 11, 2019 at 9:29 AM
    #1282
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    That's going to look sharp! Can't wait to see it installed.
  23. May 17, 2019 at 4:25 PM
    #1283
    1UPPER
    TEXAS
    Flux capacitor!
    It’s Friday and my truck is trying to tell me something with 80085 on the dash. :D
  24. May 17, 2019 at 4:41 PM
    #1284
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Wow are u serious? Have u calculated on paper to make sure that’s accurate?
  25. May 17, 2019 at 4:54 PM
    #1285
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    I think he was pointing out the "Tundras In The Snow" his Mileage is telling him about, and not the MPG. LOL But he's professionaly tuned so I wouldn't doubt that's pretty accurate.
  26. May 17, 2019 at 5:03 PM
    #1286
    1UPPER
    TEXAS
    Flux capacitor!
    Yeah I was more pointing out the fact of the ( o )( o ) s on the gauge. Lol
    d0zer, TheBeast, T-Rex266 and 2 others like this.
  27. May 17, 2019 at 5:04 PM
    #1287
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Ok ok I'll spell it out for the slower folks...
    BOOBS
  28. May 17, 2019 at 5:09 PM
    #1288
    1UPPER
    TEXAS
    Flux capacitor!
    Can you spot my Tundra?
  29. May 17, 2019 at 6:51 PM
    #1289
    We did a Snow Performance Methanol kit on my brothers SC 3.4L Tacoma, his 5.9L Cummins tow rig, and if I ever do even one upgrade to my Duramax, it will be a Meth kit from Snow Performance. Expensive, but well worth the performance especially when running higher boost (on our diesels we would see 31-50 psi).
  30. May 17, 2019 at 7:10 PM
    #1290
    Vizsla
    Vizsla 2 = 2.5
    I almost bought that kit, but chickened out. Look at their under bed cantilever kit. The truck in the pics belongs to one of our members on a vacation. @roypark
