Was my filter changed at the dealer?
Discussion in 'General Tundra Discussion' started by pro2amendment, May 10, 2019.
  1. May 10, 2019 at 6:34 PM
    pro2amendment
    pro2amendment [OP] Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    So I was at the dealer today for my 10,000 service. I took before and after pics of the filter housing. Is this evidence the filter was not changed? Or am I being paranoid... I ALWAYS change my own own oil but have let the dealer do it with the 24 mos service freebie. I have never had a vehicle with the cartridge filter before so not sure if I'm looking at this correctly. To me... this should have some finger prints or something indicating this was removed. It looks like it wasnt touched. What do you think?
    Before:
    After
    P-Factor likes this.
  2. May 10, 2019 at 6:46 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Based on the marks on the filter cap I’m going to say it wasn’t changed. Do yourself a favor and skip the “freebies”. IMO it isn’t worth the headache.
  3. May 10, 2019 at 6:49 PM
    To me I believe it was changed. Look at what I circled, it looks like a different position. No fingerprints because they wear rubber gloves now.
  4. May 10, 2019 at 6:51 PM
    I agree. Different position.
    BTBAKER and Jim LE 1301[QUOTED] like this.
  5. May 10, 2019 at 6:54 PM
    pro2amendment
    Indiana
    Bullet liner
    Ok cool. Thanks for your perspective. I thought there ought to be prints or something wearing off the oily dust.
    Black Wolf likes this.
  6. May 10, 2019 at 7:09 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I learned a lesson from this type of scenario, I used a colored sharpie and made a mark on the out side of the filter housing to filter area and engine block, ya I had to crawl under the truck to do it, but my dealership said they did it and actually did not do it. When questions were asked they said the oil was not changed either. I'm like what was the point of bringing it in then. I did get some scratches on my drivers door on that appointment, I cryed foul, and took it home and did the oil change my self.
    Later they did a hack job of a repaint on my drivers side door.
    Do the oil changes your self and ride with confidence it's done properly.
  7. May 10, 2019 at 7:17 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Get to know the folks at your dealer. I know by name and they know me. We text and stay in touch. I have the same tech work on my truck. No issues except the hourly rate is a bit much. Still, trust factor is worth it.
    Blueknights75 likes this.
  8. May 10, 2019 at 7:19 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  9. May 10, 2019 at 7:22 PM
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    You should use the liquid to check if the bolts move. And place some on the filter housing. To make sure unless they have the same color. Then i dont know :rofl:
  10. May 10, 2019 at 7:33 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Dude. This sounds EXACTLY like what I just went through. Took to dealer for an issue, they returned with big deep scratch in drivers side door, had cheap ass paint job done which caused $2K more damage. I just now finished up a 4 month long battle to get it resolved.
    OR18TRD likes this.
  11. May 10, 2019 at 8:44 PM
    Inquiringone
    Ter
    NorCal 408
    Here's what I did. I went to a shop that I wanted and knew the did top notch work, got and estimate and TOLD them either you go where I picked (In my case they did the same thing three times)or my lawyer would be calling them. I won got what I wanted. My truck had 8, 10,15k miles. Nobody should put up with that BS.
    I hope your as happy as I am. These days you have to stand up for your selfs or your mowed over. Sorry I didn't mean to hi jacked your thread.
  12. May 10, 2019 at 9:12 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Go out and take some more pics...there is too much flash on the after pic.
    Inquiringone likes this.
  13. May 10, 2019 at 9:13 PM
    Tacogrande
    Jeremy
    But just looking right now i say it was not changed.
  14. May 10, 2019 at 9:42 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Just the fact that an owner has to question whether or not a service was done is enough to either find a reputable place you can absolutely trust and pay for the service or know 100 percent it’s done right and do it yourself.
    Most dealers suck. End of story.
    Darkness and Midnite72 like this.
  15. May 10, 2019 at 9:45 PM
    Better to do on your own, cause YOU KNOW it's done right
    Midnite72, BuckWallace and BTBAKER like this.
  16. May 11, 2019 at 12:00 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    When I did my first oil change I needed a wrench to remove the filter housing. There looks to be nothing disturbed on the filter housing. The filth on the bolt seems to be maybe the camera flash over exposing, and thus washing out, the bolt. I would guess that it wasn’t changed
    Pudge and BTBAKER like this.
  17. May 11, 2019 at 3:04 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Total BULL$HIT what some STEALERS are doing!!
    This is my first new truck in my life
    After spending the most $$$ in my life on a vehicle I expected at least a call or email from salesman or dealer to see if I happy with truck etc- NO not ONE FU@CKING call - just a lot of emails saying we are having a sale want to buy another one- SERIOUSLY!!!
    I’m do all my own SERVICE - FORGET them
    Have to take truck in for RECALLS- u can dam bet I will be checking truck over with fine tooth comb before leaving - after hearing about u guys scratch/ paint ISSUES
  18. May 11, 2019 at 4:58 AM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    Yeah my truck had less than 5K miles when it happened. Went from a scratch through the paint on my driver door... to overspray on wheels, steps, door handles, door seals, and damaged the clear protectors on the edge of the doors by sanding them or painting clear over them. Whoever they sent it to apparently didn’t tape off anything. It was REALLY bad.
    After a few weeks of the GM dodging me after saying he would look into it, I went to a dealership up near me with an awesome collision center and got a repair estimate on my own. Sent it to original dealer and told them i wanted it done there. They gave me sh*t so i Filed a complaint with Toyota corporate. Toyota called them, they call me acting like they dunno the story and said they would be sending a check to this collision center. 3 months go by and the collision center had been helping me this whole time by playing middle man, because to be honest I didn’t want to even speak to this dealership anymore. After 3 months I spoke to collision center again and suggested maybe we goto corporate a 2nd time... which i did.
    12/21/18 —
    Went to pick up truck (because they originally put the wrong lift on) and found deep scratch in drivers door
    1/11/19 —
    picked up truck with butchered paint job
    4/19/19 —
    Finally got my truck fixed a few weeks back (8,500 miles) and I’ll now be going to this other dealership for service as well.
  19. May 11, 2019 at 5:11 AM
    Colt 45
    Colt 45 New Member
    Ler
    09 Toyota tundra TRD
    1 1/2 left 295/75r18 Firestone m/t
    They have a special tool to remove the oil filter and it goes back on usually in the same position as it locks in if you do suspect they're not changing the filter ask for the old filter back
  20. May 11, 2019 at 5:16 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, and it is probably over tightened and not properly torqued like mine was.
  21. May 11, 2019 at 5:23 AM
    Colt 45
    Colt 45 New Member
    Ler
    This is the lock tab
  22. May 11, 2019 at 5:34 AM
    NH2BV
    NH2BV Daily drivers!
    Las Cruces, NM
    2024 Tundra TRD Off Road
    Rock Stock OEM beast
    On my 2018 Tundra, they just did the first 5K servicing and they did not change the oil filter. They have a statement on the service sheet that they change oil at 10K or 1 year. They didn't claim to do the oil change and I am OK with that. The did service the 2 recalls and a few other things. Toyota Care is just basically inspecting the vehicle and doing minor servicing and that's about it.
  23. May 11, 2019 at 5:37 AM
    It looks over tightened compared to the before pic. I was thinking the same thing. heh.. heh.
  24. May 11, 2019 at 5:39 AM
    Colt 45
    Colt 45 New Member
    Ler
    My baby girl getting her 5,000 mi alignment
  25. May 11, 2019 at 5:45 AM
    Colt 45
    Colt 45 New Member
    Ler
    it's also a pain in the ass to remove the skid plate on a tundra and a lot of times that dealers skip the oil filter because of that not necessarily the dealer's fault just a tech being lazy that's why if I get my oil changed somewhere else I ask for my filter back are a watch them do the service
  26. May 11, 2019 at 6:38 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    On a positive note, A missed filter won't kill you or the truck..Lol
    Newm likes this.
  27. May 11, 2019 at 6:53 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Any self respecting mechanic cleans up after himself.
    Leo's first, 15whtrd and landphil like this.
  28. May 11, 2019 at 6:54 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This. Stop kidding yourself. And anyone else who's reading this and is "on the fence." It ain't worth it. And this is BEFORE we get to the horrid aspects of the insane collateral damage that others are reporting above.
    If I can do some 250 Toyota vehicle oil changes myself (since 1985) then you can do one too yourself. Then two. Then three. Then.............NEVER EVER WONDER IF IT'S DONE RIGHT.
    BTBAKER[QUOTED] likes this.
  29. May 11, 2019 at 7:04 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I do it all myself, if there's a scratch I know I made it the right way.
    Except alignment, that's voodoo stuff.
  30. May 11, 2019 at 8:17 AM
    Professional Hand Model
    Fred
    Hand Protectors
    DIY and remove the worry/hassles of the stealer.
    On a side note, do not wait 10k miles to change your oil. No more than 5k max! Or, 3k max for ‘heavy service’.
