Just installed ‘19 Tundra Pro Fox’s on my 2013 CrewMax
Discussion in 'Suspension' started by J.A.T.O., Apr 27, 2019.
  1. Apr 27, 2019 at 1:34 AM
    J.A.T.O.
    J.A.T.O. [OP] New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    Just wanted to give an update. I received the 2019 Fox Pro Kit from Toyota about 4 weeks ago and just got around to installing it today. This setup is replacing SR5 black shocks and a 3/1 spacer kit on a 2013 4wd CrewMax.
    I really hate to say too much just yet because I’ve only driven it about 20 miles so far...but the difference is quite noticeable already!
    I finished the job around 5pm today and had an hour commute through Hawaii traffic to my house. I spent most of my time well under 45mph so my “tests” are unremarkable at best.
    I’ll post up some updates soon
  2. Apr 27, 2019 at 2:02 AM
    atl1glf
    atl1glf New Member
    ‘07 SR5 CM, ‘12 SR5 DC Supercharged, ‘19 Limited CM
    Too many TRD parts
    Any modifications that you had to do or was it all bolt right up
  3. Apr 27, 2019 at 3:04 AM
    J.A.T.O.
    Hawaii
    No mods required, bolted right up. I’m running 275/65r20 terra grapplers on oem 20” wheels. The kit did come with an ABS bracket extension for the rear axle. However I don’t think it’s necessary.
    I did remove the the little mud flaps forward of the front wheels a long time ago to clear my last setup.
    I highly recommend undoing the 2 lower spindle bolts, (22mm),where they connect the spindle to the lower control arm, instead of the upper spindle ball joint as said in Haynes type books. This will prevent any undo strain on brake lines and ABS wires.
    I also disconnected the brake line/ABS wire brackets as applicable.
    Loosening of the lower inner control arm bolts that adjust alignment was absolutely necessary this time. Be sure to mark the cam bolts before you dissemble.
    Overall it was a straightforward job.
    atl1glf[QUOTED] likes this.
  4. Apr 27, 2019 at 6:23 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I wonder if those would void the PCS warranty work. A stock Toyota part but on a model that shouldn’t be lifted.
  5. Apr 27, 2019 at 7:40 AM
    Blueknights75
    Ron
    Clayton, NC
    According to the bulletin it will due to the fact that the VIN # shows an SR5 and not a PRO. But from what we have seen it is all dependent upon the dealership. Some will still perform the work and some will not.
  6. Apr 27, 2019 at 8:15 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Let's see some pics!
    :worthless:
    J.A.T.O.[OP] and TheBeast like this.
  7. Apr 27, 2019 at 1:25 PM
    TheBeast
    TheBeast The Beach
    need pictures ;)
    J.A.T.O.[OP] likes this.
  8. Apr 27, 2019 at 6:03 PM
    J.A.T.O.
    Hawaii
    Truck is dirty but here you go92477262-10AA-439A-96ED-DF6E7E905E39.jpgF0C3CC17-98CB-4DA6-8E05-5DBFEAA1A794.jpg
    atl1glf, JoshuaA, Watt maker and 6 others like this.
  9. Apr 27, 2019 at 6:16 PM
    Same height after install as the spacers that you took out?
  10. Apr 27, 2019 at 6:27 PM
    Kevinapex
    Kevinapex New Member
    Kevin
    Evergreen colorado
    2011 supercharged limited tundra
    Looks nice, good choice
  11. Apr 27, 2019 at 7:00 PM
    J.A.T.O.
    Hawaii
    I didn’t do any measuring but it did drop about an inch.
  12. Apr 27, 2019 at 7:39 PM
    TheBeast
    TheBeast The Beach
    looks great ! quality parts
  13. Apr 27, 2019 at 9:45 PM
  14. Apr 27, 2019 at 10:21 PM
    Yowhatsup
    Yowhatsup New Member
    Jeremiah
    California
    2013 limited Crewmax 4 x 4
    Amp electric steps, lift, 20 fuel rims with 35" tires
    If you don't mind me asking, how much did that set you back? I'm interested in a better ride on my 2013.
  15. Apr 28, 2019 at 12:38 AM
    J.A.T.O.
    Hawaii
    $2880 shipped. Truck rides much more “cushy” on the road. Doesn’t take corners as well as it did but a fair compromise in my book. I’d say it’s probably the most comfortable truck I’ve driven.
    Watt maker likes this.
  16. Apr 28, 2019 at 3:29 AM
    Infamous
    Infamous New Member
    Jon
    NorCal - Alameda
    '19 Limited Crewmax - Cavalry Blue
    Tints Bedrug Husky liners P&P Sliders (coming soon) Tonneau Cover (coming soon)
    I have emailed around about pricing and availability for that parts package to put on my '19 limited and was told they haven't released it for retail yet. Where did you get it from?
  17. Apr 28, 2019 at 4:16 AM
    J.A.T.O.
    Hawaii
    I ordered it from my local dealership in Hawaii. The parts guy has to look it up under “accessories”.
    Black Wolf likes this.
  18. Apr 28, 2019 at 5:15 AM
    Very nice "accessory ".. :thumbsup:
    J.A.T.O.[QUOTED][OP] likes this.
  19. May 4, 2019 at 8:54 PM
    Landonkmiller
    Landonkmiller New Member
    Landon
    2018 Tundra Limited
    3” Toytec Lift, Method MR314 Wheels, 35” Toyo R/Ts, LED External and Internal Lights, Spray in Bed Liner, Amp Research Power Steps.
    Love the red springs. How much did the kit run you?
  20. May 4, 2019 at 9:17 PM
    J.A.T.O.
    Hawaii
    $2880 shipped.
  21. May 4, 2019 at 9:38 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That pic looks suspiciously like Ko Olina
  22. May 5, 2019 at 12:46 AM
    J.A.T.O.
    Hawaii
    Bingo!
  23. May 6, 2019 at 10:14 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    OP has a 2013 so I'm guessing it doesn't matter in this situation. Good info for other folks tho.
  24. May 8, 2019 at 3:33 PM
    trddriver
    trddriver New Member
    '14 1794
    open to discussion
    Amazing.... To be clear this lifts a stock truck about "2 in on the front...right? And the rear you found what level;same or a bit higher than stock?
  25. May 8, 2019 at 3:56 PM
    J.A.T.O.
    Hawaii
    Yes front is approx 2” higher. The rear stayed the same since I only changed the shocks.
    trddriver likes this.
  26. May 8, 2019 at 3:58 PM
    trddriver
    '14 1794
    open to discussion
    Sweet. Mahalo
    Very nice
