2008 Tundra SR5 Seat Replacement
Discussion in '2nd Gen Tundras (2007-2013)' started by Froon, May 1, 2019.
  1. May 1, 2019 at 5:49 AM
    Froon
    Froon [OP] New Member
    Jeff
    2008 Tundra Crew Cab SR5
    My driver’s side seat is shot in my 2008 Tundra Crew Cab SR5. I found a used OEM leather seat online that they say comes from a 2008 Tundra Platinum Crew Cab with heating and cooling.
    Does anyone know if the power connectors are the same between an SR5 and Platinum seat?
    My current seats are cloth and powered, but don’t have heat or cooling.
  2. May 7, 2019 at 11:41 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    I would think wiring harnesses are the same across the line.
  3. May 7, 2019 at 4:53 PM
    Dr_Al
    Dr_Al New Member
    Al
    It's very possible the heated/ ac is on it's own circuit and has it's own connector. What's wrong with your seat? Most of what I've seen is the fabric and the foam on the lower cushion gets worn out. Sometimes the plastic trim that has the seat switches in it also breaks. The plastic isn't too expensive and the foam is kind of pricey. I think the fabric is the expensive part. Not sure how much that leather seat you found will cost you or just how bad your seat is but you can repair them.
