Backup camera
Discussion in '1st Gen Tundras (2000-2006)' started by darkoverlift, Jul 29, 2014.
  1. Jul 29, 2014 at 5:31 PM
    darkoverlift
    darkoverlift [OP] New Member
    brian
    2004 SR 4 Door
    Factory
    I am looking to add a back up camera to my 04 sr5 double cab. I want a nice setup and would love feedback or opinions on what you all have done.
  2. Jul 30, 2014 at 2:54 PM
    darkoverlift
    brian
    2004 SR 4 Door
    Factory
  3. Jul 30, 2014 at 2:55 PM
    darkoverlift
    brian
    2004 SR 4 Door
    Factory
    This is where I am leaning
  4. Jul 30, 2014 at 5:55 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Wireless and easy install. I like it. I always read reviews carefully to make the decision on stuff like this.
  5. Jul 31, 2014 at 12:36 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Do you have an aftermarket head unit or anything? Something you could wire the camera into?
  6. Jul 31, 2014 at 3:04 AM
    darkoverlift
    brian
    2004 SR 4 Door
    Factory
    Factory JBL setup..
  7. Aug 3, 2014 at 10:27 AM
    darkoverlift
    brian
    2004 SR 4 Door
    Factory
    So no one has added a backup camera?
  8. Aug 4, 2014 at 12:36 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
  9. Jul 3, 2016 at 1:20 PM
    GRS
    GRS New Member
    Where did you attach the reverse wire from the unit to the truck?
  10. Jul 3, 2016 at 5:44 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Do not buy Peak wireless camera. I bought one some years ago. It worked only for a few seconds then the picture would simply freeze. I tried so many different ways to tweak it, but to no avail. I got Pioneer HU and Pioneer camera and it's been flawless so far for the last 4+ years (except when it's drops below -20F).
  11. Jul 3, 2016 at 9:10 PM
    Ryan Mc.
    Ryan Mc. New Member
    Mission Viejo
    2015 Toyota Tundra SR5 Double Cab 5.7L
    Hand made bed divider, bed d-rings
    Try this set up... pearlauto.com
    It's a solar powered back up camera license plate frame and uses any smart phone as the display. It turns any dumb car into a smart car.
  12. Jul 5, 2016 at 8:05 AM
    JMB
    Chesapeake, VA
    Les7311 likes this.
  13. Sep 22, 2016 at 4:45 PM
    davidjmay
    davidjmay New Member
    Nashville, TN
    2021 Tundra Platinum
    Does anyone have any info on which wire is the "reverse signal" one in the vehicle wiring harness? I installed an aftermarket Pioneer head unit and in order for the Camera screen to come on automatically, the (in this case, purple) wire on the head unit has to be connected to some kind of wire that senses when the reverse gear is engaged.
    (Edit: question is for a 1 gen tundra)
  14. Oct 22, 2016 at 1:18 PM
    davidjmay
    Nashville, TN
    Bump? ^ Is it the same blue wire as the second gen posted above?
  15. Dec 20, 2016 at 11:35 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I ran my reverse trigger wire from the head unit back with the camera cable and connected it to the reverse light wire in my tail light and it worked fine. I never did find the wire up in the cab area which did this.
    NewImprovedRon likes this.
  16. Jan 31, 2017 at 4:27 PM
    jmorrill79
    jmorrill79 New Member
    2006 Tundra Limited
    mtntop, did you connect to the white or red wire at the tail light assembly? Thanks!
  17. Feb 5, 2017 at 12:20 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
