Map light issue
Discussion in 'Lighting' started by xtyfighterx, May 4, 2019.
  1. May 4, 2019 at 7:54 PM
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    so I had a bulb out when to change it and the socket inside got popped out of place I took apart the overhead console got it popped back in and tried the bulb it wouldn’t work then if i held it a certain way it would come on so I messed with the prongs holding the bulb in got the bulb to hold tight and stick installed everything now it doesn’t work. Took it back apart and can’t get any type of connection the bulb won’t light up at all. Any way to test the socket? So I know that I have power going to it?
  2. May 4, 2019 at 8:17 PM
    xtyfighterx
    Ty
    North Idaho
    I’m almost positive it doesn’t have power going to it.
  3. May 5, 2019 at 4:29 AM
    xtyfighterx
    Ty
    North Idaho
    Test light shows ground and positive not there on the socket
  4. May 5, 2019 at 5:19 AM
    Jrharvey02
    Jrharvey02 New Member
    You blew a fuse...
  5. May 5, 2019 at 5:38 AM
    This^^^
  6. May 5, 2019 at 6:32 AM
    xtyfighterx
    Ty
    North Idaho
    Nope only one fuse for the circuit and it’s good all other lights work on the circuit so it’s gotta be the switch is fried. To bad they are almost impossible to find. Might have to get a new console or hope for the best at a junk yard
    Black Wolf likes this.
  7. May 5, 2019 at 6:42 AM
    Jrharvey02
    I’d think if you were frying switches a fuse would have blown before that. Are you sure the map light isn’t just switched to “off”, I know those push-in lights are a pain in the ass to get back into place correctly. Think I read a post recently where you gotta replace the whole console as individual parts aren’t sold for it...
  8. May 5, 2019 at 6:48 AM
    xtyfighterx
    Ty
    North Idaho
    Ya whether the button is pressed or not it should light up with doors open. I put the Other switch in its place and it works I found a part number but everywhere is out of stock or discontinued.
  9. May 5, 2019 at 6:49 AM
    At least you know the problem. @Roman ??
    NewImprovedRon likes this.
  10. May 5, 2019 at 6:53 AM
    xtyfighterx
    Ty
    North Idaho
    Like Harvey said I don’t believe they will sell me Individual parts :( maybe I can get it covered under warranty lol
  11. May 5, 2019 at 6:55 AM
    Jrharvey02
    Could be worse, just a map light...least you’re not stuck on the side of the road like a bunch of Ford owners at this exact moment....
  12. May 5, 2019 at 6:59 AM
    .......on fire......
  13. May 5, 2019 at 7:54 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I blew my switch in a similar way. Created a jumper so that pressing one switch activates both lights simultaneously (win win) as one light is never enough and the passengers never know where their side switch is located anyway. I also removed the lens covers from behind and the light is multiplied. 2002 Tundra.
    You could do the jumper even with two good switches.
  14. May 5, 2019 at 8:22 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I fubar'd my footwell circuit somehow, fuse is intact, could be ECM from reading in the Taco forum, maybe the Dome switch but didn't bother getting another one, I tapped the cargo wire for power instead. You can try circuit testing before the dome switch first if everything else is good.
    Black Wolf and xtyfighterx[OP] like this.
  15. May 5, 2019 at 2:35 PM
    xtyfighterx
    Ty
    North Idaho
    That looks less complicated than the newer tundra layout
  16. May 5, 2019 at 2:37 PM
    xtyfighterx
    Ty
    North Idaho
    Ya everything else is good. The company that has the switch just emailed me back and has them they are like $2 so I think I’ll just buy it and hope it fixes it if not I’ll try to get power from somewhere else.
  17. May 5, 2019 at 2:40 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    With the doors flying open...
    JoshuaA and Black Wolf[QUOTED] like this.
  18. May 5, 2019 at 2:51 PM
    Fred
    Hand Protectors
    Too bad. Maybe someone can figure it out. Or, just buy a new switch. KISS.
  19. May 5, 2019 at 4:10 PM
    ....air bags bursting....
    gosolo[QUOTED] and JoshuaA like this.
  20. May 5, 2019 at 4:12 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    ...seats ejecting...
    gosolo and Black Wolf[QUOTED] like this.
  21. May 5, 2019 at 4:13 PM
    xtyfighterx
    Ty
    North Idaho
    New switch is on its way if it doesn’t fix it I’ll check the junk yard periodically for a whole unit but the other switch works in place of the bad one so it should be the culprit
  22. May 5, 2019 at 4:13 PM
    ...gas tank exploding..
    gosolo and JoshuaA[QUOTED] like this.
  23. May 5, 2019 at 4:27 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    ...mail boxes smashing...
  24. May 5, 2019 at 4:42 PM
    map light bulbs melting while going off the cliff........
  25. May 9, 2019 at 11:00 PM
    xtyfighterx
    Ty
    North Idaho
    Jrharvey02 likes this.
