Abs issue
Discussion in '2nd Gen Tundras (2007-2013)' started by Tmc1129, May 4, 2019.
  1. May 4, 2019 at 11:24 PM
    Tmc1129
    Tmc1129 [OP] New Member
    Tyrel
    Saskatchewan canada
    09 Ltd tundra
    4 hi 4 low no speedo no odometer abs light on I took my truck in to the local dealer to get code looked at and was told they can't read it and that I need to replace my abs ecu module which is quite pricey 3000$ canadian does any body know of a less pricey route
    good online parts site
    Or solution to my issue
  2. May 5, 2019 at 6:29 AM
    Dr_Al
    Dr_Al New Member
    Al
    If the ABS ecu is bad I would call around to some junk yards. I can't imagine them going bad often so they should be cheap.
