Upgrade manual ac to climate control?
Discussion in '2.5 Gen Builds (2014-2021)' started by GaryPC, Apr 12, 2019.
  1. Apr 12, 2019 at 6:50 PM
    GaryPC
    GaryPC [OP] New Member
    2019 Quicksand Tundra SR5+
    I got my 2019 Tundra 3 months ago without climate control ... OOPS!
    I am regularly adjusting it up and down, probably every 15 minutes or so. I never realized how great it is to have automatic temperature control.
    Is it possible to replace the manual ac automatic climate control? I don’t need separately controlled passenger and driver sides, I just want temperature control and wonder can something be added or can I replace the control panel?
    Any suggestions would be much appreciated!
  2. Apr 12, 2019 at 7:31 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I think it is a major mod. At a minimum you would need to swap out the hvac blend door assembly as the auto version is dual zone.
    That is why I had to go with Limited vs SR5, had to have the marriage saver (dual zone auto climate control).
    GaryPC[OP] and Black Wolf like this.
  3. Apr 13, 2019 at 5:56 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    I have been wanted to do the same. The double temp is exactly the same on the back. My question is the amount of wire or them. My guess is that there will me more wires on the double temp. At least one more for the passenger temp.
    GaryPC[OP] likes this.
  4. Apr 13, 2019 at 6:00 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You need to change out all the components behind the dash, including swapping ECUs and wiring with a unit that has it. The programming for the auto climate is in the ecu. It’s not even remotely worth the trouble and cost.
  5. Apr 13, 2019 at 6:33 PM
    FirstTruck
    Stock, for now
    Thats it!!! Lol
  6. Apr 13, 2019 at 6:37 PM
  7. May 3, 2019 at 9:30 PM
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    Do you think it’d be more feasible if you could pull all the parts from a wrecked truck that is being parted out? I was curious if anyone had knowledge of every part needed.
