To be or not be: Icon Mid Travel or LT
Discussion in 'Suspension' started by opitmus_tundra, Apr 29, 2019.
  1. May 2, 2019 at 1:23 PM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Mine was more than 30k all in. I was guesstimating what a SUA LT set up would cost.
  2. May 2, 2019 at 1:28 PM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Ahhh I gotcha. Because he rounded up
  3. May 3, 2019 at 4:11 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    fck that its never enough keep upgrading the grass is always greener go harder
    tbrown, Sunnier, 5.7TRDProm and 4 others like this.
  4. May 3, 2019 at 7:24 PM
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    MT Squat Life.
    Sunnier, Icon_Adrian, Vizsla and 2 others like this.
  5. May 3, 2019 at 7:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Kevin, what’s your offset? Any spacers? Im thinking about going 37’s with glass.
  6. May 3, 2019 at 11:14 PM
    KevinK
    Tundras to Sedona
    That’s actually an old pic. Those rims were 18x9+25 with a 37x13.5 tire. That’s easy to fit and doesn’t require glass. Here’s a pic with stock fenders on those. That offset is kind of the sweet spot. +25 on a 9”, or +18 on an 8.5” wide rim.
    They stuffed all the way
    What you saw at T2S is 17x8.5 0 offset (-5 effective offset after the beadlocks were welded on) with a 37x12.5 tire. Overall it’s an inch wider track on each side, so it necessitated the glass. It also requires the adjustable uppers and a healthy appetite for metal removal on the body mount.
    Amnesiac, d0zer, 831Tun and 3 others like this.
  7. May 4, 2019 at 4:24 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :eek:
    Ahh, posted about 45 mins before deciding to take life sloooower :boink: :rofl:
    Sunnier and osidepunker[QUOTED] like this.
  8. May 4, 2019 at 6:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I gotta go wheeling right now but I have a few questions when I get back.
  9. May 4, 2019 at 11:40 AM
    M C M
    M C M New Member
    Grass is always greener where you water it, and by water it I mean throwing money at it. LOL
  10. May 4, 2019 at 11:44 AM
    M C M
    M C M New Member
    I would suggest upgrading your rear suspension first, throwing a ton of money at LT up front and staying SOA in the rear is just going to set you up to be disappointed again with less money in your pocket and the rear suspension still being your limiting factor.
  11. May 6, 2019 at 2:20 PM
    Icon_Adrian
    Icon_Adrian New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    @opitmus_tundra
    A well dialed MT is great and can be a TON of fun with out breaking the bank (relatively speaking).
    :anonymous:
    But on the DL:
    I have the inside scoop on your shock setup... You happen to have the only shock configuration we have in our entire production line that can be converted from MT to LT relatively easily.
    -Coilovers will need new shafts, rodends and springs to covert what have to the LT version
    -Secondary shocks will need a new rodend and an internal spacer removed to be converted.
    (so no need to buy all new shock, just service/convert the ones you have)
    Not trying to bring you over to the Dark Side with the rest of us, but rather just sharing info about our product line. lol :thumbsup:
    1UPPER, Ponkus, KarmaKannon and 4 others like this.
  12. May 21, 2019 at 8:03 AM
    opitmus_tundra
    opitmus_tundra [OP] Aka NEED_IT_TUNDRA
    2017 Tundra
    magnusonsuperchargers, sdhq, westinbumper, dougthorleyheaders, rigidlightbar, rigidfoglights, bajadesigns hood scoop lightbar and a pillar, iconstage5 suspension and secondary stage 2, magnaflow exhaust, methodracewheels, nitto 35 ridgegrappler
  13. May 21, 2019 at 10:26 AM
    opitmus_tundra
    2017 Tundra
    How do I go about getting this done? Who do I need to talk to at icon and can you assist?
    Icon_Adrian likes this.
  14. May 21, 2019 at 10:31 AM
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    I can help get you a parts list so you can get them on order. You can then get the parts needed to convert them when your ready if you are a DIY'er OR you can get get the parts through the service center you plan on using.
    Ponkus likes this.
  15. May 21, 2019 at 11:59 AM
    opitmus_tundra
    2017 Tundra
    Can you get me the parts list please and I will get it done with some help of my buddy! Thanks man
    Ponkus and Sunnier like this.
  16. Jun 14, 2019 at 8:00 PM
    Ponkus
    Ponkus New Member
    Hi Adrian. I have the IVD-58750C. Is this one of the models that can be converted to LT?
    Icon_Adrian[QUOTED] likes this.
  17. Jun 14, 2019 at 8:23 PM
    Sunnier
    Sunny
    San Diego, CA
    Always rock mid-travel.
    Unless you can rock Long-travel.
    ALWAYS CHOOSE LONG-TRAVEL.
    Cfincke, Icon_Adrian and theraven like this.
  18. Jun 14, 2019 at 8:36 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Damn you guys pay a shit load for installation haha, for under $20k you could run a MCM kit with 3.0 bypasses and run a trailing arm linked rear with 3.0 bypasses AND 3.0 coilovers and pull 16" up front and like 26+ in the back. Paying $10k on top of that to bolt the front on and throw some link mounts and brace the rear sounds like insanity to me, but to each their own.
    If you can afford it, LT it. Apples to apples more travel is better.
  19. Jun 15, 2019 at 9:44 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Damn you sure are selling out Matt for cheap
    Pinay likes this.
  20. Jun 16, 2019 at 6:17 AM
    #50
    snivilous
    SW UT
    Not sure what your point is, just stating facts. I referenced the highest travel kit I know of (MCM's @ 16") which is $8k on his website fully loaded. Then price out shocks from anyone and it's $6k or less for the fanciest 3.0 coilovers/bypasses for the rear, and maybe somehow you can spend $6k on some brackets and a truss and some tube and trailing arms. Again, seems insane to pay another $10k+ for some pretty simple fab work and bolting the front on.
  21. Jun 16, 2019 at 8:07 AM
    #51
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Technically, it's drilling ;), if you use a spot weld cutter and remove the whole bedside.
    I shoulda been a contract lawyer. :D
  22. Jun 19, 2019 at 2:06 PM
    #52
    KevinK
    Tundras to Sedona
    You might be able to get some brackets and a truss and some tube and trailing arms and just mash them together correctly, but not many people understand things like anti squat or roll center or upper and lower link ratios to maintain pinion angle and shit like that. Let alone being capable of calculating the correct numbers to compensate for tire size vs link length (or choosing between a 3 and 4 link setup when the gas tank is in the way, but maybe we could use a fuel cell instead and relocate that...).
    Basically, a lot of people have to pay for knowledge they either lack time or energy to gain. And I know my fab skills are for fuck all.
  23. Jun 19, 2019 at 5:11 PM
    #53
    GravityGear
    Aurora, CO
    Damn... After we move, I will use this.
    831Tun[QUOTED] likes this.
  24. Jun 19, 2019 at 7:45 PM
    #54
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Don't be modest, We know you got some fab skills. Just no one understands what you're doing
  25. Jun 20, 2019 at 2:20 PM
    #55
    KevinK
    Tundras to Sedona
    Just trying to get back to my home planet. :rofl:
  26. Jun 24, 2019 at 1:41 PM
    #56
    opitmus_tundra
    2017 Tundra
    Sooo I decided on the rear and went with camburg! Such a sweet set up and have 15" travel with the bed still to spare. Still debating to drop another 15k on the front but that back is rad.
  27. Jun 24, 2019 at 1:54 PM
    #57
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Nice . U went fox instead of ur icons?
  28. Jun 24, 2019 at 3:41 PM
    #58
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    Yes, you will need new shafts, rodends, and coil springs, but it CAN be done.
    Ponkus[QUOTED] and TXTundra2722 like this.
  29. Jun 24, 2019 at 4:53 PM
    #59
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    I could be wrong but I’m pretty sure your not getting 15” of travel with the U748s. If you went spring under that’s a different story
    M C M, 831Tun, TRD15559 and 2 others like this.
  30. Jun 25, 2019 at 7:20 AM
    #60
    TXTundra2722
    2015 Black Tundra
    Unless there is another Camburg kit for the tundra that I'm not aware of, it is SUA. The advertisement is 15 inch travel
